I am trying to compile one program package on the Opteron using pgf90 compiler. If the tp=k8-32 flag is used, everything is OK. But when the tp=k8-64 flag is used, two different linker warnings are displayed:
1.
usr/bin/ld: Warning: alignment 16 of symbol pghpf_type_' in /usr/pgi/linux86/5.2/lib/libpgf902.a(const.o) is smaller than 32 in mc.o 2. /usr/bin/ld: warning: i386:x86-64 architecture of input file mc.o’ is incompatible with i386 output
(and more similar messages as the second one for each f90 file)
There is one message of type 1 and several of type 2 (for each f90 file compiled).
For 1, this is the wrong library for 64-bit. You should be using the “linux86-64/5.2/lib/libpgf902.a” library. For 2, you most likely compiled this as a 32-bit object but are linking with “-tp k8-64”.
Try cleaning all the objects and executable(s) and re-build everything with “-tp k8-64”. I suspect you build everything with k8-32 but didn’t clean before trying to relink with k8-64.
Using -m64 flag does not help.
“-m64” is a gcc flag.
What flags should be used ?
We typically recommend using “-fastsse -Mipa=fast,inline”. For most programs this flag set gives the best performance. You can also try “-fast”, “-fastsse”, “-fast -Mipa=fast”, “-fastsse -O3 -Mipa=fast”, etc.
While you can create 32-bit executables on a AMD x86-64 using the “-tp k8-32” flag, you can not mix 32 and 64-bit objects. The objects in the libraries your using were compiled as 64-bit objects, so you may not use them to link with your 32-bit application. You must either re-compile your program as a 64-bit object (ie “-tp k8-64”) or obtain 32-bit versions of these libraries.
