Yes you were right about $(ROOT)/$ , I changed it to what was supposed to be there: $(ROOT)/libs/libutil.a. My Makefile looks like this:
#------------------JACEK---------------------------
MAGMA = /opt/magma
MKLROOT = /opt/intel/compilers_and_libraries_2018.0.128/linux/mkl
CUDADIR = /usr/local/cuda
INCLUDES = -I ~/dftb+_final/libs
-I$(CUDADIR)/include
-I$(MAGMA)/include
-I$(MAGMA)/control
-I$(MAGMA)/sparse/include\
#CFLAGS = -O3 $(FPIC) -mp -fast -Mipa=fast,inline -DNDEBUG -DADD_ -DMAGMA_WITH_MKL -DMKL_ILP64
#FFLAGS = -O3 -DADD_ -Wall -Dmagma_devptr_t=“integer(kind=8)” -mp
-O3 $(FPIC) -fast -Mipa=fast,inline -DNDEBUG -DADD_ -i8
#------ END JACEK----
Fortran 90 compiler
FC90 =pgf95
#/opt/pgi/linux86-64/2017/bin/pgfortran
Options for the Fortran 90 compiler
FC90OPT = -i8 -Mcuda -Mprof -O3 -mp $(INCLUDES)
Preprocessor (leave empty, if the compiler has a built in preprocessor)
CPP = cpp -traditional
Options for preprocessing
CPPOPT = -DDEBUG=$(DEBUG) #-DEXTERNALERFC
Postprocessing of the preprocessor output (add-on pipe)
CPPPOST = $(ROOT)/utils/fpp/fpp.sh general
Linker
LN = $(FC90) $(FC90OPT)
Linker options
#LNOPT = -Bstatic
Override options for different DEBUG modes
ifeq ($(DEBUG),1)
FC90OPT = -g -Wall -std=f2003 -pedantic -fall-intrinsics -fbounds-check
endif
ifeq ($(DEBUG),2)
endif
ifeq ($(DEBUG),3)
endif
How to link specific libraries
LIB_BLAS =-lblas -L$(MAGMA)/lib -rpath $(MAGMA)/lib -lmagma -L$(CUDADIR)/lib64 -lcublas -lcudart -lm LIBS
#-Mcuda -L$(MAGMA)/lib $(LIBS) -rpath $(MAGMA)/lib -lmagma -L$(CUDADIR)/lib64 -lm $(ROOT)/$ -lcublas -lcudart $(INCLUDES)
#LIB_BLAS = $(INCLUDES) $(LIBS) $(INCLUDES2) $(LIBS2)
#LIB_LAPACK = -llapack
#LIB_BLAS = -lacml -lblas -lgfortran -lpthread
This dftb.o is the executable I’m trying to generate.
The error is in bold letters:
cpp -traditional -DDEBUG=0 -I/home/ccevallos/dftb+_final/prg_dftb/ -I/home/ccevallos/dftb+_final/prg_dftb/…/includes /home/ccevallos/dftb+_final/prg_dftb/dftb+.F90 | /home/ccevallos/dftb+_final/prg_dftb/…/utils/fpp/fpp.sh general > dftb+.f90
pgf95 -i8 -Mcuda -Mprof -O3 -mp -I ~/dftb+_final/libs -I/usr/local/cuda/include -I/opt/magma/include -I/opt/magma/control -I/opt/magma/sparse/include -o dftb+.o -c dftb+.f90
pgf95 -i8 -Mcuda -Mprof -O3 -mp -I ~/dftb+final/libs -I/usr/local/cuda/include -I/opt/magma/include -I/opt/magma/control -I/opt/magma/sparse/include -o dftb+ dftb+.o shift.o accuracy.o common_types.o allocate.o geoopt.o conjgrad.o linmin.o constants.o stepdesc.o mainio.o sparse2dense.o memman.o periodic.o lapackroutines.o message.o sort.o bisection.o linkedlist.o simple_algebra.o fileid.o blasroutines.o fifo.o charmanip.o initprogram.o disp_uff.o disp_common.o diis_mixer.o scc.o coulomb.o extcharge.o charge_constraints.o short_gamma.o dummy_thermostat.o md_common.o ranlux.o slako_cont.o slako_eq_grid.o interpolation.o orbital_equiv.o nhc_thermostat.o energies.o temp_profile.o simple_mixer.o numericalDerivs.o thermostat.o berendsen_thermostat.o andersen_thermostat.o spin.o disp_slaterkirkwood.o broyden_mixer.o thirdorder.o md_integrator.o velocity_verlet.o inputdata.o rep_cont.o rep_poly.o rep_spline.o dispersion.o type_geometry.o intrinsicpr.o mixer_adt.o anderson_mixer.o scc_init.o dftb_pls_u.o eigensolver.o flib_wxml.o m_wxml_core.o m_wxml_elstack.o m_wxml_buffer.o m_wxml_dictionary.o m_wxml_text.o nonscc.o sk.o populations.o constraints.o angmomentum.o qm.o potentials.o formatout.o eigenvects.o parser.o stringlist.o m_strings.o hsdutils2.o hsdparser.o xmlutils.o flib_dom.o m_dom_nodelist.o m_dom_types.o m_dom_utils.o m_dom_document.o m_dom_namednodemap.o m_dom_node.o m_dom_error.o m_dom_debug.o m_dom_element.o m_dom_attribute.o m_dom_parse.o flib_sax.o m_xml_parser.o m_elstack.o m_buffer.o m_fsm.o m_entities.o m_dictionary.o m_charset.o m_debug.o m_reader.o m_io.o m_xml_error.o m_converters.o hsdutils.o tokenreader.o unitconversion.o disp_uff_data.o general_list.o oldcompat.o wrapped_pointers.o type_geometry_hsd.o old_sk_data.o stressTensor.o taggedout.o densitymatrix.o etemp.o hermite.o ext_erfc.o fact.o repulsive.o spinorbit.o forces.o -lblas -L/opt/magma/lib -rpath /opt/magma/lib -lmagma -L/usr/local/cuda/lib64 -lcublas -lcudart -lm /home/ccevallos/dftb+final/prg_dftb/…/libs/libutil.a
/usr/bin/ld: /opt/magma/lib/libmagma.a(thread_queue.o): undefined reference to symbol ‘_ZTVSt9exception@@GLIBCXX_3.4’
//usr/lib/x86_64-linux-gnu/libstdc++.so.6: error adding symbols: DSO missing from command line
pgacclnk: child process exit status 1: /usr/bin/ld
/home/ccevallos/dftb+_final/prg_dftb/GNUmakefile:43: recipe for target ‘dftb+’ failed
make[1]: *** [dftb+] Error 2
rm disp_common.f90 md_integrator.f90 short_gamma.f90 spin.f90 taggedout.f90 md_common.f90 geoopt.f90 memman.f90 tokenreader.f90 dftb+.f90 slako_eq_grid.f90 inputdata.f90 fifo.f90 rep_poly.f90 sparse2dense.f90 populations.f90 sort.f90 disp_uff.f90 type_geometry.f90 densitymatrix.f90 fact.f90 eigensolver.f90 hsdutils.f90 dftb_pls_u.f90 andersen_thermostat.f90 allocate.f90 initprogram.f90 broyden_mixer.f90 dispersion.f90 orbital_equiv.f90 xmlutils.f90 qm.f90 sk.f90 forces.f90 wrapped_pointers.f90 ext_erfc.f90 linmin.f90 diis_mixer.f90 mainio.f90 repulsive.f90 formatout.f90 accuracy.f90 mixer_adt.f90 general_list.f90 hermite.f90 shift.f90 hsdparser.f90 lapackroutines.f90 old_sk_data.f90 eigenvects.f90 type_geometry_hsd.f90 berendsen_thermostat.f90 linkedlist.f90 velocity_verlet.f90 charmanip.f90 slako_cont.f90 scc.f90 energies.f90 numericalDerivs.f90 disp_slaterkirkwood.f90 spinorbit.f90 potentials.f90 disp_uff_data.f90 parser.f90 blasroutines.f90 stressTensor.f90 thermostat.f90 angmomentum.f90 constraints.f90 nhc_thermostat.f90 nonscc.f90 stringlist.f90 periodic.f90 bisection.f90 hsdutils2.f90 temp_profile.f90 intrinsicpr.f90 oldcompat.f90 scc_init.f90 unitconversion.f90 extcharge.f90 charge_constraints.f90 simple_algebra.f90 rep_spline.f90 common_types.f90 dummy_thermostat.f90 conjgrad.f90 etemp.f90 message.f90 simple_mixer.f90 thirdorder.f90 stepdesc.f90 rep_cont.f90 fileid.f90 coulomb.f90 constants.f90 interpolation.f90 anderson_mixer.f90 ranlux.f90
make[1]: Leaving directory ‘/home/ccevallos/dftb+_final/prg_dftb/_obj_x86_64-linux-pgi-gpu’
…/Makefile.objdir:69: recipe for target ‘_obj_x86_64-linux-pgi-gpu’ failed
make: *** [_obj_x86_64-linux-pgi-gpu] Error 2
