I am creating a project that captures images continuously and performs a fast fourier transforms on the images. I have created a simple outline of the project with a c++ file that captures images, a cuda file that will (hopefully) perform the fast fourier transform, and a header file that will link the two so I can call the function “fastft” from the main.cpp. I am using cuds’s cuFFT library. After creating two object files main.o and fft.o, when I go to compile with g++ I receive the error:
“In function main': main.cpp:(.text+0x47c): undefined reference to
fastft(int, int, unsigned char*)”
This might be a simple fix, but I was unable to find help elsewhere. Also, feel free to make any recommendations that can improve the cuda program. I am new to cuda programming so any advice helps.
header.h
// header.h
#ifndef _HEADER_H
#define _HEADER_H
#include <iostream>
void fastft(int width, int height, unsigned char* image);
#endif
fft.cu
#include <cufft.h>
#include <cuda_runtime.h>
#include <cuda.h>
#include <cuda_device_runtime_api.h>
#include <iostream>
#include <stdlib.h>
#include <stdio.h>
#include "header.h"
void fastft(int width, int height, cufftReal* data)
cufftHandle plan;
cufftComplex *transform;
//Allocate memory
cudaMallocManaged((void**)&data, sizeof(cufftReal)*width*height);
cudaMallocManaged((void**)&transform, sizeof(cufftComplex)*width*height);
//Create Plan
cufftPlan2d(&plan, width, height, CUFFT_R2C)
//Execute fft
cufftExecR2C(plan, data, transform);
//Destroy plan
cufftDestroy(plan);
//Free memory
cudaFree(data);
cudaFree(transform);
//Message
std::cout << "This program may have worked" << std::endl;
main.cpp
#include <opencv2/core/core.hpp>
#include <opencv2/highgui/highgui.hpp>
#include <opencv2/opencv.hpp>
#include "FlyCapture2.h"
#include <iostream>
#include "header.h"
using namespace FlyCapture2;
int main()
Camera camera;
Error error;
CameraInfo camInfo;
// Connect the camera
error = camera.Connect( 0 );
if ( error != PGRERROR_OK )
std::cout << "Failed to connect to camera" << std::endl;
return false;
// Get the camera info and print it out
error = camera.GetCameraInfo( &camInfo );
std::cout << "Failed to get camera info from camera" << std::endl;
return false;
std::cout << camInfo.vendorName << " "
<< camInfo.modelName << " "
<< camInfo.serialNumber << std::endl;
// Start Capture
error = camera.StartCapture();
if ( error == PGRERROR_ISOCH_BANDWIDTH_EXCEEDED )
std::cout << "Bandwidth exceeded" << std::endl;
return false;
else if ( error != PGRERROR_OK )
std::cout << "Failed to start image capture" << std::endl;
return false;
// capture loop
char key = 0;
while(key != 'q')
// Get the image
Image rawImage;
Error error = camera.RetrieveBuffer( &rawImage );
std::cout << "capture error" << std::endl;
continue;
// Convert the raw image
Image convertedImage;
rawImage.Convert( FlyCapture2::PIXEL_FORMAT_MONO8, &convertedImage);
// convert to OpenCV Mat
unsigned int rowBytes = (double)convertedImage.GetReceivedDataSize()/(double)convertedImage.GetRows();
cv::Mat image = cv::Mat(convertedImage.GetRows(), convertedImage.GetCols(), CV_8UC1 , convertedImage.GetData(),rowBytes);
cv::imshow("image", image);
key = cv::waitKey(30);
// Call cuda function
int height, width;
height = 964;
width = 1288;
fastft(width, height, image.data);
error = camera.StopCapture();
// This may fail when the camera was removed, so don't show
// an error message
camera.Disconnect();
return 0;
