Linking error using CUDA + OpenCV
Hi
I’m trying to get this thing work. I’m using OpenCV just to read/write images, but I can’t make it work when compiling with nvcc.
I have 3 files:
[list=1]
[*]Prueba.c: Here I load and image with functions from Image.c then call a function to convert the RGB image to Grayscale and finally save the new image.
[*]Image.c: Here are the functions of load/save images, if I work all with .c-files everything works fine.
[*]Conversion.cu: Here I made a parallel function to convert RGB to Grayscale.
To compile I use the following command:
nvcc Prueba.c Image.c ColorConversion.cu -o test -I/usr/local/include/opencv -L/usr/local/lib -lcxcore -lcv -lhighgui -lcvaux
But a lot of errors appear, some of them are:
ptxas /tmp/tmpxft_000003de_00000000-2_pprColorConversion.ptx, line 87; warning : Double is not supported. Demoting to float
ld: warning: in /usr/local/lib/libcxcore.dylib, file was built for unsupported file format which is not the architecture being linked (i386)
ld: warning: in /usr/local/lib/libcv.dylib, file was built for unsupported file format which is not the architecture being linked (i386)
ld: warning: in /usr/local/lib/libhighgui.dylib, file was built for unsupported file format which is not the architecture being linked (i386)
ld: warning: in /usr/local/lib/libcvaux.dylib, file was built for unsupported file format which is not the architecture being linked (i386)
Undefined symbols:
  "_cvGetRows", referenced from:
      _cvGetRow in tmpxft_000003de_00000000-4_Prueba.o
      _cvGetRow in tmpxft_000003de_00000000-5_Image.o
  "_cvLog", referenced from:
      _cvbFastLog in tmpxft_000003de_00000000-4_Prueba.o
      _cvbFastLog in tmpxft_000003de_00000000-5_Image.o
  "_cvCreateMat", referenced from:
      _cvFindFundamentalMatrix in tmpxft_000003de_00000000-4_Prueba.o
      _cvKMeans in tmpxft_000003de_00000000-4_Prueba.o
      _cvFindFundamentalMatrix in tmpxft_000003de_00000000-5_Image.o
      _cvKMeans in tmpxft_000003de_00000000-5_Image.o
  "_cvBoxPoints", referenced from:
      _cvMinAreaRect in tmpxft_000003de_00000000-4_Prueba.o
      _cvMinAreaRect in tmpxft_000003de_00000000-5_Image.o
  "_cvEllipse", referenced from:
      _cvEllipseBox in tmpxft_000003de_00000000-4_Prueba.o
      _cvEllipseAA in tmpxft_000003de_00000000-4_Prueba.o
      _cvEllipseBox in tmpxft_000003de_00000000-5_pprImage.o
      _cvEllipseAA in tmpxft_000003de_00000000-5_Image.o
Seems that it has something to do with OpenCV functions, but how can I build my application.
P.S. I’m doing it all under Mac OS X 10.6.6
Any ideas?
I tried to compile OpenCV 2.1 with the option -D CMAKE_OSX_ARCHITECTURES=i386 but it can’t be configured with that option.
I also tried OpenCV 2.2 but with this I can’t even compile my programs without CUDA.
Don’t know what to do, any ideas?
