Hi friends,
I’m new to CUDA, and there is a problem I face.
I always failed linking a program with int main() placed in .cpp file, but if I moved int main() to .cu file, the linking has no problem.
Currently I’m using Jared’s custom build rule.
It seemed strange to me. Is there anyone can explain?
I would suggest that you take a look at the cppIntegration SDK sample to see how to compile and link together .cu files with .cpp files.
Dear Cyril,
It works, thank you very much. I didn’t know that example projects contain many helpful things. If I can draw some conclusions, best practices are:
Kernels are typed like .h files, but in .cu files
Kernel stubs are typed like .cpp files, but in .cu files
Kernel stubs must be preceded by extern “C”
Am I right?
