cuda_problem_example.zip (2.06 KB)
Hi, I am a new to cuda and I would like to create a statical cuda library for the gpu-part of my program, and then I would like to link this with c/c++ objects generated with qt or mingw-gcc/g++ later.
I created a minimal representation of my problem and attached here.
I have win7 x64, cuda, mingw installed
I have visual studio as well, but i dont want to use that, because I am planning to do this with Qt later.
As you can see in the attached example (or below), I would like to create a statical library for the cuda-part of my application. This can be done with the MakeStatlib.bat, which’s first call is to setup the environment for the visual compiler (I read this in the nvcc manual)
Then, I would like to create a runnable app, which would call the call() function which takes place in cudalib.lib
I can successfully create cudalib.lib, but unfortunately cannot link it together with main.o, the linker says:
gcc main.o cudalib.lib -o app
main.o:main.c:(.text+0xc): undefined reference to ‘call’
collect2: ld returned 1 exit status
The content of the uploaded example:
files:
kernel.cu
caller.cu
kernel.h
caller.h
main.c
MakeStatlib
MakeStatlib.bat
MakeRunnable
MakeRunnable.bat
in kernel.cu:
__global__ void calculateKernel()
in caller.cu:
#include <cuda.h> /* dim3 */
#include "kernel.h" /* calculateKernel() */
void call()
dim3 dimBlock(1,1);
dim3 dimGrid(1,1);
calculateKernel<<< dimGrid, dimBlock >>>();
in kernel.h:
#ifndef KERNEL_H
#define KERNEL_H
__global__ void calculateKernel();
#endif /* KERNEL_H */
in caller.h:
#ifndef CALLER_H
#define CALLER_H
void call();
#endif /* CALLER_H */
in main.c:
#include "caller.h" /* call() */
int main()
call();
return 0;
in MakeStatlib:
cudalib.lib: kernel.obj caller.obj
nvcc -lib kernel.obj caller.obj -o cudalib.lib
kernel.obj: kernel.cu kernel.h
nvcc -c kernel.cu -o kernel.obj
caller.obj: caller.cu caller.h kernel.h
nvcc -c caller.cu -o caller.obj
in MakeStatlib.bat:
call "c:\Program Files (x86)\Microsoft Visual Studio 9.0\Common7\Tools\vsvars32.bat"
mingw32-make -f MakeStatlib
in MakeRunnable:
app: main.o cudalib.lib
main.o: main.c caller.h
gcc -c main.c -o main.o
cudalib.lib: kernel.cu caller.h caller.cu
MakeStatlib.bat
in MakeRunnable.bat:
mingw32-make -f MakeRunnable
PAUSE
Any help appreciated.
My email is kottalovag[TA]gmail[TOD]com, if easier
David
