Edit: Might have just figured it out, will request delete if I did otherwise update post in a little bit.
The comment on your similar question here is correct:
You are using the -L switch incorrectly. You might want to study how to specify libraries and library search paths to gcc. You can look at example makefiles in any of the CUDA sample projects.
