i would like to link a program against a library consisting of convenience libraries and those using template functions.
i actually got it WORKING!
→ thanks to Mat and the manual
but: it’s handwork
i would like to use the autotools.
what i do now is:
for the (convenience) libraries add
libaclib_la_CXXFLAGS = --one_instantiation_per_object
to Makefile.am
make
then for all the object files do a
pgCC --one_instatiation_per_object --prelink_objects “all other options” *.o
then manually rebuild all libraries
ar cru .libs/libalib.a libalib_la-alib.o .libs/libalib.lax/libaclib.a/libaclib_la-aclib.o Template.dir/q__tm__2_i_db1e5f54.o Template.dir/cq__tm__2__8df8eb98.o
(adding the Temlate.dir objects)
then make the program again
make prog
this time it succeeds…
maybe it would work to set ARFLAGS to Temlate.dir/*.o ?
but i would still need the prelink step!
anybody?
thanks,
markus
