I am linking objects compiled with -mcmodel=medium with mpif90, from pgi cdk, modified with the -fpic removed from the scrpit , but I get the following error…
I understood it was possible to use mpich1 (from pgi) with -mcmodel=medium, if so what I mistake I made? regards
mpif90 -v -r8 -O3 -mcmodel=medium -o …/…/…/bin/opa model.o
…/…/…/lib/oce/libopa.a …/…/…/lib/libioipsl.a
-L/home/grieco/netcdf/lib/ -lnetcdf
mpif90 for 1.2.7 (release) of : 2005/06/22 16:33:49
/usr/bin/ld /usr/lib64/crt1.o /usr/lib64/crti.o
/opt/cluster/pgi/linux86-64/7.1-3/libso/trace_init.o
/usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/crtbegin.o
/opt/cluster/pgi/linux86-64/7.1-3/libso/f90main.o -m elf_x86_64
-dynamic-linker /lib64/ld-linux-x86-64.so.2
/opt/cluster/pgi/linux86-64/7.1-3/lib/pgi.ld
-L/opt/cluster/pgi/linux86-64/7.1/mpi/mpich/lib
-L/home/grieco/netcdf/lib/ -L/opt/cluster/pgi/linux86-64/7.1-3/libso
-L/opt/cluster/pgi/linux86-64/7.1-3/lib -L/usr/lib64
-L/usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3 model.o
…/…/…/lib/oce/libopa.a …/…/…/lib/libioipsl.a -lnetcdf -lmpichf90nc
-lmpich -lpthread -lrt -rpath /opt/cluster/pgi/linux86-64/7.1-3/libso
-rpath /opt/cluster/pgi/linux86-64/7.1-3/lib -o …/…/…/bin/opa -lpgf90
-lpgf90_rpm1 -lpgf902 -lpgf90rtl -lpgftnrtl -lnspgc -lpgc -lrt -lpthread
-lm -lgcc -lc -lgcc /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/crtend.o
/usr/lib64/crtn.o
/opt/cluster/pgi/linux86-64/7.1/mpi/mpich/lib/libmpich.a(debugutil.o)(.text+0x2c):
In function MPIR_Breakpoint': /home/sw/cdk/cdk/mpich-1.2.7/mpich-1.2.7/src/env/debugutil.c:113: relocation truncated to fit: R_X86_64_PC32 .bss /opt/cluster/pgi/linux86-64/7.1/mpi/mpich/lib/libmpich.a(debugutil.o)(.text+0x48):/home/sw/cdk/cdk/mpich-1.2.7/mpich-1.2.7/src/env/debugutil.c:114: relocation truncated to fit: R_X86_64_PC32 .bss /opt/cluster/pgi/linux86-64/7.1/mpi/mpich/lib/libmpich.a(debugutil.o)(.text+0x64):/home/sw/cdk/cdk/mpich-1.2.7/mpich-1.2.7/src/env/debugutil.c:115: relocation truncated to fit: R_X86_64_PC32 .bss /opt/cluster/pgi/linux86-64/7.1/mpi/mpich/lib/libmpich.a(debugutil.o)(.text+0x80):/home/sw/cdk/cdk/mpich-1.2.7/mpich-1.2.7/src/env/debugutil.c:116: relocation truncated to fit: R_X86_64_PC32 .bss /opt/cluster/pgi/linux86-64/7.1/mpi/mpich/lib/libmpich.a(debugutil.o)(.text+0x9c):/home/sw/cdk/cdk/mpich-1.2.7/mpich-1.2.7/src/env/debugutil.c:117: relocation truncated to fit: R_X86_64_PC32 .bss /opt/cluster/pgi/linux86-64/7.1/mpi/mpich/lib/libmpich.a(debugutil.o)(.text+0xb8):/home/sw/cdk/cdk/mpich-1.2.7/mpich-1.2.7/src/env/debugutil.c:118: relocation truncated to fit: R_X86_64_PC32 .bss /opt/cluster/pgi/linux86-64/7.1/mpi/mpich/lib/libmpich.a(debugutil.o)(.text+0xd4):/home/sw/cdk/cdk/mpich-1.2.7/mpich-1.2.7/src/env/debugutil.c:119: relocation truncated to fit: R_X86_64_PC32 .bss /opt/cluster/pgi/linux86-64/7.1/mpi/mpich/lib/libmpich.a(debugutil.o)(.text+0xf0):/home/sw/cdk/cdk/mpich-1.2.7/mpich-1.2.7/src/env/debugutil.c:120: relocation truncated to fit: R_X86_64_PC32 .bss /opt/cluster/pgi/linux86-64/7.1/mpi/mpich/lib/libmpich.a(debugutil.o)(.text+0x10c):/home/sw/cdk/cdk/mpich-1.2.7/mpich-1.2.7/src/env/debugutil.c:121: relocation truncated to fit: R_X86_64_PC32 .bss /opt/cluster/pgi/linux86-64/7.1/mpi/mpich/lib/libmpich.a(debugutil.o)(.text+0x113):/home/sw/cdk/cdk/mpich-1.2.7/mpich-1.2.7/src/env/debugutil.c:122: relocation truncated to fit: R_X86_64_PC32 .bss /opt/cluster/pgi/linux86-64/7.1/mpi/mpich/lib/libmpich.a(initutil.o)(.text+0x53b): In function
MPIR_Init’:
: additional relocation overflows omitted from the output
pgf90-Fatal-linker completed with exit code
