Hi ,
I am seeing some Linux driver crash , which i have no idea about it. Can anyone help in finding the root cause of it. Please find the driver cash info as below.
] ------------[ cut here ]------------
[ 22.116854] WARNING: at /home/saiprasad/L4T_R21.1_v5/kernel/fs/sysfs/dir.c:530 sysfs_add_one+0x8c/0xac()
[ 22.116855] sysfs: cannot create duplicate filename '/devices/platform/regulators.5/d.regulator/regulator/regulator.32/tegradc.0-avdd_lcd'
[ 22.116864] Modules linked in: dm_crypt dm_mod sd8897 sd8897mlan cfg80211 rfkill nvhost_vi
[ 22.116868] CPU: 0 PID: 1423 Comm: Xorg Tainted: G W 3.10.40-v2 #26
[ 22.116878] [<c00167dc>] (unwind_backtrace+0x0/0x140) from [<c0012f48>] (show_stack+0x18/0x1c)
[ 22.116884] [<c0012f48>] (show_stack+0x18/0x1c) from [<c0062dc4>] (warn_slowpath_common+0x54/0x70)
[ 22.116890] [<c0062dc4>] (warn_slowpath_common+0x54/0x70) from [<c0062e8c>] (warn_slowpath_fmt+0x38/0x48)
[ 22.116895] [<c0062e8c>] (warn_slowpath_fmt+0x38/0x48) from [<c01aa32c>] (sysfs_add_one+0x8c/0xac)
[ 22.116900] [<c01aa32c>] (sysfs_add_one+0x8c/0xac) from [<c01aaf34>] (sysfs_do_create_link_sd+0xb8/0x200)
[ 22.116907] [<c01aaf34>] (sysfs_do_create_link_sd+0xb8/0x200) from [<c03848fc>] (create_regulator+0xb4/0x228)
[ 22.116913] [<c03848fc>] (create_regulator+0xb4/0x228) from [<c0384ba8>] (_regulator_get+0x138/0x1b8)
[ 22.116918] [<c0384ba8>] (_regulator_get+0x138/0x1b8) from [<c0054f34>] (dalmore_dsi_regulator_get+0x30/0x104)
[ 22.116923] [<c0054f34>] (dalmore_dsi_regulator_get+0x30/0x104) from [<c0055018>] (dsi_p_wuxga_10_1_enable+0x10/0x214)
[ 22.116927] [<c0055018>] (dsi_p_wuxga_10_1_enable+0x10/0x214) from [<c0336638>] (_tegra_dc_controller_enable+0x58/0x1054)
[ 22.116932] [<c0336638>] (_tegra_dc_controller_enable+0x58/0x1054) from [<c0337698>] (_tegra_dc_enable+0x64/0xa0)
[ 22.116936] [<c0337698>] (_tegra_dc_enable+0x64/0xa0) from [<c03379ac>] (tegra_dc_enable+0xe4/0x104)
[ 22.116941] [<c03379ac>] (tegra_dc_enable+0xe4/0x104) from [<c036f634>] (tegra_fb_blank+0xcc/0x18c)
[ 22.116947] [<c036f634>] (tegra_fb_blank+0xcc/0x18c) from [<c02f4f18>] (fb_blank+0x5c/0xa0)
[ 22.116952] [<c02f4f18>] (fb_blank+0x5c/0xa0) from [<c02f5ca4>] (do_fb_ioctl+0x450/0x66c)
[ 22.116957] [<c02f5ca4>] (do_fb_ioctl+0x450/0x66c) from [<c015b110>] (do_vfs_ioctl+0x80/0x2bc)
[ 22.116961] [<c015b110>] (do_vfs_ioctl+0x80/0x2bc) from [<c015b3a4>] (SyS_ioctl+0x58/0x180)
[ 22.116966] [<c015b3a4>] (SyS_ioctl+0x58/0x180) from [<c000ee80>] (ret_fast_syscall+0x0/0x30)
[ 22.116987] ---[ end trace 14739398b0e7f09b ]---
[ 22.116991] as3722-gpio4-supply: could not add device link tegradc.0 err -17
[ 22.116998] as3722-gpio4-supply: Failed to create debugfs directory
[ 22.117009] ------------[ cut here ]------------
[ 22.117013] WARNING: at /home/saiprasad/L4T_R21.1_v5/kernel/fs/sysfs/dir.c:530 sysfs_add_one+0x8c/0xac()
[ 22.117014] sysfs: cannot create duplicate filename '/devices/platform/regulators.5/a.regulator/regulator/regulator.29/tegradc.0-dvdd_lcd'
[ 22.117020] Modules linked in: dm_crypt dm_mod sd8897 sd8897mlan cfg80211 rfkill nvhost_vi
[ 22.117023] CPU: 0 PID: 1423 Comm: Xorg Tainted: G W 3.10.40-orwl_v2 #26
[ 22.117028] [<c00167dc>] (unwind_backtrace+0x0/0x140) from [<c0012f48>] (show_stack+0x18/0x1c)
[ 22.117033] [<c0012f48>] (show_stack+0x18/0x1c) from [<c0062dc4>] (warn_slowpath_common+0x54/0x70)
[ 22.117038] [<c0062dc4>] (warn_slowpath_common+0x54/0x70) from [<c0062e8c>] (warn_slowpath_fmt+0x38/0x48)
[ 22.117042] [<c0062e8c>] (warn_slowpath_fmt+0x38/0x48) from [<c01aa32c>] (sysfs_add_one+0x8c/0xac)
[ 22.117046] [<c01aa32c>] (sysfs_add_one+0x8c/0xac) from [<c01aaf34>] (sysfs_do_create_link_sd+0xb8/0x200)
[ 22.117051] [<c01aaf34>] (sysfs_do_create_link_sd+0xb8/0x200) from [<c03848fc>] (create_regulator+0xb4/0x228)
[ 22.117056] [<c03848fc>] (create_regulator+0xb4/0x228) from [<c0384ba8>] (_regulator_get+0x138/0x1b8)
[ 22.117060] [<c0384ba8>] (_regulator_get+0x138/0x1b8) from [<c0054f4c>] (dalmore_dsi_regulator_get+0x48/0x104)
[ 22.117064] [<c0054f4c>] (dalmore_dsi_regulator_get+0x48/0x104) from [<c0055018>] (dsi_p_wuxga_10_1_enable+0x10/0x214)
[ 22.117068] [<c0055018>] (dsi_p_wuxga_10_1_enable+0x10/0x214) from [<c0336638>] (_tegra_dc_controller_enable+0x58/0x1054)
[ 22.117072] [<c0336638>] (_tegra_dc_controller_enable+0x58/0x1054) from [<c0337698>] (_tegra_dc_enable+0x64/0xa0)
[ 22.117076] [<c0337698>] (_tegra_dc_enable+0x64/0xa0) from [<c03379ac>] (tegra_dc_enable+0xe4/0x104)
[ 22.117080] [<c03379ac>] (tegra_dc_enable+0xe4/0x104) from [<c036f634>] (tegra_fb_blank+0xcc/0x18c)
[ 22.117084] [<c036f634>] (tegra_fb_blank+0xcc/0x18c) from [<c02f4f18>] (fb_blank+0x5c/0xa0)
[ 22.117089] [<c02f4f18>] (fb_blank+0x5c/0xa0) from [<c02f5ca4>] (do_fb_ioctl+0x450/0x66c)
[ 22.117093] [<c02f5ca4>] (do_fb_ioctl+0x450/0x66c) from [<c015b110>] (do_vfs_ioctl+0x80/0x2bc)
[ 22.117096] [<c015b110>] (do_vfs_ioctl+0x80/0x2bc) from [<c015b3a4>] (SyS_ioctl+0x58/0x180)
[ 22.117100] [<c015b3a4>] (SyS_ioctl+0x58/0x180) from [<c000ee80>] (ret_fast_syscall+0x0/0x30)
[ 22.117101] ---[ end trace 14739398b0e7f09c ]---
