Just patched the 325.08 driver to get compiled against 3.11_rc1. I made two patches. One includes the 3.10 patch, and the other is incremental to it.
WARNING:
I am not very familar with nvidia-drivers code and/or kernel code. So I really do not know what my patch exactly does. My GPU reports some degrees more temperature with it applied. But actualy it is running! Well, you have been warned.
Linux 3.11_rcX compatibility
Your error is caused by the extra debugging symbols in the git kernel, build a nodebug kernel and it should work. Here’s a link to the patch I used (works with 3.10.0 and 3.11.0 rc1) http://cvs.rpmfusion.org/viewvc/checkout/rpms/nvidia-kmod/devel/kernel_v3.10.patch?revision=1.4&root=nonfree
Posted in Linux
Then i uncheck the option “debug kernel” in kernel hacking with make menu_config
with the last 3.15 kernel, re compile and boot this new compilation and i can
install the nvidia driver, this option block the nvidia driver and solve the issue
