We are facing issues on using Bluetooth in version 24.2 but it seems to be worked in 24.0 and we found that BlueZ package is missing in 24.2. How to fix this now?
NOTE: This should be in the TX1 forum instead of TK1, but since R24.x is for TX1, it appears this is for a TX1 and not a TK1.
I’m looking at R24.2.1, I see bluez is installed. If you don’t have this it should still be available through the standard Ubuntu packages. You can search for anything related to bluez via:
apt search bluez
I have several Ubuntu apt repositories enabled, here’s a subset of what I see:
blueman/xenial 2.0.4-1ubuntu2 arm64
Graphical bluetooth manager
bluetooth/xenial 5.37-0ubuntu5 all
Bluetooth support
bluez/xenial,now 5.37-0ubuntu5 arm64 [installed,automatic]
Bluetooth tools and daemons
bluez-btsco/xenial 1:0.50-0ubuntu6 arm64
Bluez Bluetooth SCO tool
bluez-cups/xenial,now 5.37-0ubuntu5 arm64 [installed,automatic]
Bluetooth printer driver for CUPS
bluez-dbg/xenial 5.37-0ubuntu5 arm64
Bluetooth tools and daemons (with debugging symbols)
bluez-hcidump/xenial 5.37-0ubuntu5 arm64
Analyses Bluetooth HCI packets
bluez-obexd/xenial,now 5.37-0ubuntu5 arm64 [installed,automatic]
bluez obex daemon
bluez-tests/xenial 5.37-0ubuntu5 arm64
BlueZ test tools and scripts
bluez-tools/xenial 0.2.0~20140808-5 arm64
Set of tools to manage Bluetooth devices for linux
btscanner/xenial 2.1-5.1build1 arm64
ncurses-based scanner for Bluetooth devices
And then there is of course the install via something like:
sudo apt-get install bluez bluez-tools
- Moving to TX1 forum.
