I tried to install three different versions of drivers on my laptop (Dell G3 with GTX 1660 Ti max-q card), 440, 430 and 418, and all resulted in black screen (gnome server w/o display).
I didn’t see any errors in Xorg log file, but the display was gone.
Card was detected fine:
[ 369.495] (II) Module glxserver_nvidia: vendor=“NVIDIA Corporation”
[ 369.495] compiled for 4.0.2, module version = 1.0.0
[ 369.495] Module class: X.Org Server Extension
[ 369.495] (II) NVIDIA GLX Module 418.113 Sun Oct 27 00:12:38 UTC 2019
[ 370.435] (–) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 370.435] (–) NVIDIA(0): DFP-0
[ 370.441] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 1660 Ti with Max-Q Design (TU116-A) at
[ 370.441] (II) NVIDIA(0): PCI:1:0:0 (GPU-0)
[ 370.441] (–) NVIDIA(0): Memory: 6291456 kBytes
[ 370.441] (–) NVIDIA(0): VideoBIOS: 90.16.25.40.ab
[ 370.441] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 370.441] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 370.441] (–) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 370.441] (–) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 370.441] (==) NVIDIA(0):
[ 370.441] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
I tried a couple of things like blacklisting nouveau drivers, adding modeset (or amdgpu) module and setting AllowEmptyInitialConfiguration option, but that did not help.
Xorg.log had no errors just a couple of warnings:
[ 370.441] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 370.441] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 370.441] (II) UnloadModule: “amdgpu”
[ 370.441] (II) Unloading amdgpu
[ 402.966] (WW) xf86CloseConsole: KDSETMODE failed: Input/output error
[ 402.966] (WW) xf86CloseConsole: VT_GETMODE failed: Input/output error
[ 402.966] (WW) xf86CloseConsole: VT_ACTIVATE failed: Input/output error
Are there documented issues with 1660 Ti drivers for Linux, or is that card supposed to work?
I’d appreciate any info on how to set this up.
