Hi, everyone. I need help finding working linux display driver X86 for my quadro fx 2000. Nvidia website suggested the last two releases (304.64 and 310.19)… but when i read through supported products, my gpu is not listed!!! I also tried installing them anyway but they failed!
WARNING: The NVIDIA Quadro FX 2000 GPU installed in this system is supported through the NVIDIA 173.14.xx legacy Linux graphics drivers. Please visit http://www.nvidia.com/object/unix.html for more information. The 310.19 NVIDIA Linux graphics driver will ignore this GPU.
WARNING: You do not appear to have an NVIDIA GPU supported by the 310.19 NVIDIA Linux graphics driver installed in this system. For further details, please see the appendix SUPPORTED NVIDIA GRAPHICS CHIPS in the README available on the Linux driver download page at www.nvidia.com.
-> License accepted.
-> Installing NVIDIA driver version 310.19.
-> Running distribution scripts
executing: ‘/usr/lib/nvidia/pre-install’…
-> done.
-> The distribution-provided pre-install script failed! Continue installation anyway? (Answer: Yes)
ERROR: The Nouveau kernel driver is currently in use by your system. This driver is incompatible with the NVIDIA driver, and must be disabled before proceeding. Please consult the NVIDIA driver README and your Linux distribution’s documentation for details on how to correctly disable the Nouveau kernel driver.
-> For some distributions, Nouveau can be disabled by adding a file in the modprobe configuration directory. Would you like nvidia-installer to attempt to create this modprobe file for you? (Answer: Yes)
-> The modprobe configuration file to disable Nouveau, /etc/modprobe.d/nvidia-installer-disable-nouveau.conf, has been written. For some distributions, this may be sufficient to disable Nouveau; other distributions may require modification of the initial ramdisk. Please reboot your system and attempt NVIDIA driver installation again. Note if you later wish to reenable Nouveau, you will need to delete the file /etc/modprobe.d/nvidia-installer-disable-nouveau.conf.
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
