I compiled kernel 5.8.0 rc-3.1 and tried to get nvidia beta drivers 450.51 from aur(nvidia-beta the dkms branch) and I got this error https://pastebin.com/raw/6jjxcYZE . The commit that breaks vmalloc() is this one here https://github.com/torvalds/linux/commit/88dca4ca5a93d2c09e5bbc6a62fbfc3af83c4fca
Commit da1c55f1b272f4bd54671d459b39ea7b54944ef9 is also a problem to get the driver to compile.
As you seem to already be using Tk-Glitchās kernel, consider using the nvidia-all package as well.
I posted the below which was with the 450.51 driver, and it fails as well.
Iām running Fedora 31. Just tried the beta driver, NVIDIA-Linux-x86_64-450.51.run with vmlinuz-5.8.0-0.rc3.20200630git7c30b859a947.1.vanilla.1.fc32.x86_64
I tried to install running NVIDIA-Linux-x86_64-450.51.run --kernel-source-path=/usr/src/kernels/5.8.0-0.rc3.20200630git7c30b859a947.1.vanilla.1.fc32.x86_64/
The last thing that works for me is NVIDIA-Linux-x86_64-440.82.run with vmlinuz-5.7.0-0.rc0.git6.1.vanilla.knurd.1.fc31.x86_64
Iām attaching the log file from the latest attempt. Any suggestions most welcome.nvidia-installer.log (1.2 MB)
Thanks,
Fred
Edited to add first error message, which is:
In file included from /tmp/selfgz1307/NVIDIA-Linux-x86_64-450.51/kernel/nvidia/nv-front
end.c:13:
/tmp/selfgz1307/NVIDIA-Linux-x86_64-450.51/kernel/common/inc/nv-linux.h: In function ān
v_vmallocā:
In file included from /tmp/selfgz1307/NVIDIA-Linux-x86_64-450.51/kernel/nvidia/nv-acpi.
c:15:
v_vmallocā:
/tmp/selfgz1307/NVIDIA-Linux-x86_64-450.51/kernel/common/inc/nv-linux.h:508:17: error: too many arguments to function ā__vmallocā
508 | void *ptr = __vmalloc(size, GFP_KERNEL, PAGE_KERNEL);
The driver needs to be patched on the 5.8 kernel. For Arch I recommend the above package, for Fedora youāll need to manually patch the driver.
Edit: The instructions is for the 440.100 version of the driver, but it works for the 450.51 series as well, just change the referenced name.
Does Nvidia have a tenth of a person that cares about Linux? If so perhaps that person could give a hand here.
$ inxi -GS
System: Host: leigh Kernel: 5.8.0-0.rc3.20200630git7c30b859a947.1.fc33.x86_64 x86_64 bits: 64
Desktop: Cinnamon 4.6.5 Distro: Fedora release 33 (Rawhide)
Graphics: Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nvidia v: 450.51
Display: x11 server: Fedora Project X.org 1.20.8 driver: nvidia unloaded: fbdev,modesetting,nouveau,vesa
resolution: 3840x2160~60Hz
OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 450.51
The patch works for me
I appreciate the patch, but evidently I have a lot to learn in order to take advantage of it. I tried
rpm -U /f/Downloads/akmod-nvidia-450.51-2.fc33.x86_64.rpm
and got
warning: /f/Downloads/akmod-nvidia-450.51-2.fc33.x86_64.rpm: Header V3 RSA/SHA1 Signature, key ID 94843c65: NOKEY
error: Failed dependencies:
nvidia-kmod-common >= 3:450.51 is needed by akmod-nvidia-3:450.51-2.fc33.x86_64
xorg-x11-drv-nvidia-kmodsrc >= 3:450.51-1 is needed by akmod-nvidia-3:450.51-2.fc33.x86_64
I have NVIDIA-Linux-x86_64-450.51.run*
but it will not run, giving the errors Iāve posted previously. So is this something I might be capable of making work? Thanks.
Hi all, thanks for reporting this issue.
This bug has been fixed. It will be available in the upcoming driver release.
Many Thanks. Just ran
/f/Downloads/NVIDIA-Linux-x86_64-450.57.run --kernel-source-path=/usr/src/kernels/5.8.0-0.rc4.20200709git0bddd227f3dc.1.vanilla.1.fc32.x86_64/
And for the first time in months I have a working system with a current kernel. Note for others, the āpath=ā part should point to your current kernel. (And this displays with linebreaks where you should not have spaces.)
Hi guys, do you if its a version for Ubuntu?
@gilvbp You could probably apply the patch to the driver source (in /usr/src/nvidia*, I believe), but Iām not sure about that. For now though youāre probably better off waiting for an official release.
@samantas5855 You should mark the thread as solved, since, as of 450.57, this problem has been fixed.
