Hello!
We’re trying to install NVIDIA-GRID-Linux-KVM-470.63.01-471.68. But the kernel interfaces seem to have changed.
Prior to upgrading this server using vGPUs we used linux 5.4. No problem there. In 5.11.22 we’re getting:
/var/lib/dkms/nvidia/470.63/build/nvidia/nv-dma.c:963: warning: "IMPORT_SGT_STUBS_NEEDED" redefined
963 | #define IMPORT_SGT_STUBS_NEEDED 0
/var/lib/dkms/nvidia/470.63/build/nvidia/nv-dma.c:957: note: this is the location of the previous definition
957 | #define IMPORT_SGT_STUBS_NEEDED 1
CC [M] /var/lib/dkms/nvidia/470.63/build/nvidia/nv-caps.o
CC [M] /var/lib/dkms/nvidia/470.63/build/nvidia/nv-frontend.o
CC [M] /var/lib/dkms/nvidia/470.63/build/nvidia/nv_uvm_interface.o
CC [M] /var/lib/dkms/nvidia/470.63/build/nvidia/nv-vgpu-vfio-interface.o
CC [M] /var/lib/dkms/nvidia/470.63/build/nvidia/nvlink_linux.o
CC [M] /var/lib/dkms/nvidia/470.63/build/nvidia/nvlink_caps.o
CC [M] /var/lib/dkms/nvidia/470.63/build/nvidia/linux_nvswitch.o
CC [M] /var/lib/dkms/nvidia/470.63/build/nvidia/procfs_nvswitch.o
CC [M] /var/lib/dkms/nvidia/470.63/build/nvidia/i2c_nvswitch.o
CC [M] /var/lib/dkms/nvidia/470.63/build/nvidia-vgpu-vfio/nvidia-vgpu-vfio.o
CC [M] /var/lib/dkms/nvidia/470.63/build/nvidia-vgpu-vfio/vgpu-devices.o
CC [M] /var/lib/dkms/nvidia/470.63/build/nvidia-vgpu-vfio/nv-pci-table.o
/var/lib/dkms/nvidia/470.63/build/nvidia-vgpu-vfio/nvidia-vgpu-vfio.c: In function ‘vgpu_msix_handler’:
/var/lib/dkms/nvidia/470.63/build/nvidia-vgpu-vfio/nvidia-vgpu-vfio.c:2730:18: error: implicit declaration of function ‘get_fs’; did you mean ‘sget_fc’? [-Werror=implicit-function-declaration]
2730 | old_fs = get_fs();
| sget_fc
/var/lib/dkms/nvidia/470.63/build/nvidia-vgpu-vfio/nvidia-vgpu-vfio.c:2730:18: error: incompatible types when assigning to type ‘mm_segment_t’ from type ‘int’
/var/lib/dkms/nvidia/470.63/build/nvidia-vgpu-vfio/nvidia-vgpu-vfio.c:2731:9: error: implicit declaration of function ‘set_fs’; did you mean ‘sget_fc’? [-Werror=implicit-function-declaration]
2731 | set_fs(KERNEL_DS);
| sget_fc
/var/lib/dkms/nvidia/470.63/build/nvidia-vgpu-vfio/nvidia-vgpu-vfio.c:2731:16: error: ‘KERNEL_DS’ undeclared (first use in this function); did you mean ‘KERNEL_3’?
| KERNEL_3
/var/lib/dkms/nvidia/470.63/build/nvidia-vgpu-vfio/nvidia-vgpu-vfio.c:2731:16: note: each undeclared identifier is reported only once for each function it appears in
/var/lib/dkms/nvidia/470.63/build/nvidia-vgpu-vfio/nvidia-vgpu-vfio.c: In function ‘nv_vgpu_inject_interrupt’:
/var/lib/dkms/nvidia/470.63/build/nvidia-vgpu-vfio/nvidia-vgpu-vfio.c:3020:14: error: incompatible types when assigning to type ‘mm_segment_t’ from type ‘int’
3020 | old_fs = get_fs();
/var/lib/dkms/nvidia/470.63/build/nvidia-vgpu-vfio/nvidia-vgpu-vfio.c:3021:12: error: ‘KERNEL_DS’ undeclared (first use in this function); did you mean ‘KERNEL_3’?
3021 | set_fs(KERNEL_DS);
| KERNEL_3
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:288: /var/lib/dkms/nvidia/470.63/build/nvidia-vgpu-vfio/nvidia-vgpu-vfio.o] Error 1
make[2]: *** Waiting for unfinished jobs....
/var/lib/dkms/nvidia/470.63/build/nvidia-vgpu-vfio/vgpu-devices.c: In function ‘nv_vfio_vgpu_get_attach_device’:
/var/lib/dkms/nvidia/470.63/build/nvidia-vgpu-vfio/vgpu-devices.c:729:1: warning: the frame size of 1040 bytes is larger than 1024 bytes [-Wframe-larger-than=]
729 | }
/var/lib/dkms/nvidia/470.63/build/nvidia-vgpu-vfio/vgpu-devices.c: In function ‘nv_vgpu_dev_ioctl’:
/var/lib/dkms/nvidia/470.63/build/nvidia-vgpu-vfio/vgpu-devices.c:356:1: warning: the frame size of 1120 bytes is larger than 1024 bytes [-Wframe-larger-than=]
356 | }
make[1]: *** [Makefile:1849: /var/lib/dkms/nvidia/470.63/build] Error 2
Any help to address this is appreciated :)
EDIT
Just noticed that they removed set_fs/get_fs in 5.10. So will there be an updated driver to address this issue?
Best regards
Marcus Nordenberg
