Hi All,
I would like to boot Linux mainline on the Xavier. Unfortunately, I get stuck here. Any pointers are welcome. Logs below.
binary ratchet value 4 is too large than ratchet level 1 from HW fuses.
[0000.093] I> MB1 (prd-version: 1.5.1.2-t194-41334769-9ec1833d)
[0000.098] I> Boot-mode: Coldboot
[0000.101] I> Chip revision : A02
[0000.104] I> Bootrom patch version : 7 (correctly patched)
[0000.109] I> ATE fuse revision : 0x200
[0000.113] I> Ram repair fuse : 0x0
[0000.116] I> Ram Code : 0x2
[0000.118] I> rst_source : 0x0
[0000.121] I> rst_level : 0x0
[0000.124] I> Boot-device: eMMC
[0000.139] I> sdmmc DDR50 mode
[0000.144] W> No valid slot number is found in scratch register
[0000.149] W> Return default slot: _a
[0000.152] I> Active Boot chain : 0
[0000.155] I> Boot-device: eMMC
[0000.159] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.167] I> Temperature = 34000
[0000.170] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.174] W> Skipping boost for clk: BPMP_APB
[0000.178] W> Skipping boost for clk: AXI_CBB
[0000.182] W> Skipping boost for clk: AON_CPU_NIC
[0000.187] W> Skipping boost for clk: CAN1
[0000.190] W> Skipping boost for clk: CAN2
[0000.195] I> Boot-device: eMMC
[0000.197] I> Boot-device: eMMC
[0000.207] I> Sdmmc: HS400 mode enabled
[0000.211] I> ECC region[0]: Start:0x0, End:0x0
[0000.215] I> ECC region[1]: Start:0x0, End:0x0
[0000.219] I> ECC region[2]: Start:0x0, End:0x0
[0000.224] I> ECC region[3]: Start:0x0, End:0x0
[0000.228] I> ECC region[4]: Start:0x0, End:0x0
[0000.232] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.238] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.242] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.247] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.251] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.256] E> FAILED: Thermal config
[0000.264] E> FAILED: MEMIO rail config
[0000.282] I> Boot-device: eMMC
[0000.292] I> sdmmc bdev is already initialized
[0000.359] I> MB1 done\FD\FD\FD\FDmain enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
\FD\FD
[0000.367] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-fc4604fb)
[0000.368] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.368] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.369] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.375] W> device prod register failed
[0000.379] I> Boot-device: eMMC
[0000.381] I> Boot_device: SDMMC_BOOT instance: 3
[0000.387] I> sdmmc-3 params source = boot args
[0000.390] I> sdmmc bdev is already initialized
[0000.394] I> sdmmc-3 params source = boot args
[0000.401] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.408] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.410] W> No valid slot number is found in scratch register
[0000.415] W> Return default slot: _a
[0000.419] I> Active Boot chain : 0
[0000.422] I> parsing oem signed section of bpmp-fw header done
[0000.428] I> bpmp-fw binary init read from storage
[0000.433] I> oem authentication of bpmp-fw header done
[0000.439] I> bpmp-fw binary done read from storage
[0000.442] I> bpmp-fw: Authentication init Done
[0000.447] I> parsing oem signed section of cpubl header done
[0000.452] I> cpubl binary init read from storage
[0000.456] I> bpmp-fw: Authentication Finalize Done
[0000.461] I> oem authentication of cpubl header done
[0000.466] I> cpubl binary done read from storage
[0000.470] I> cpubl: Authentication init Done
[0000.475] I> parsing oem signed section of rce header done
[0000.480] I> rce binary init read from storage
[0000.484] I> Relocating BR-BCT
[0000.487] I> cpubl: Authentication Finalize Done
[0000.492] I> oem authentication of rce header done
[0000.496] I> rce binary done read from storage
[0000.500] I> rce: Authentication init Done
[0000.505] I> parsing oem signed section of ape header done
[0000.509] I> ape binary init read from storage
[0000.514] I> rce: Authentication Finalize Done
[0000.518] I> oem authentication of ape header done
[0000.523] I> ape binary done read from storage
[0000.527] I> ape: Authentication init Done
[0000.532] I> parsing oem signed section of tos header done
[0000.536] I> tos binary init read from storage
[0000.541] I> ape: Authentication Finalize Done
[0000.545] I> oem authentication of tos header done
[0000.549] I> tos binary done read from storage
[0000.554] I> tos: Authentication init Done
[0000.558] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.564] I> bpmp-fw-dtb binary init read from storage
[0000.569] I> tos: Authentication Finalize Done
[0000.574] I> oem authentication of bpmp-fw-dtb header done
[0000.578] I> bpmp-fw-dtb binary done read from storage
[0000.583] I> bpmp-fw-dtb: Authentication init Done
[0000.589] I> parsing oem signed section of cpubl-dtb header done
[0000.594] I> cpubl-dtb binary init read from storage
[0000.599] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.635] I> oem authentication of cpubl-dtb header done
[0000.636] I> cpubl-dtb binary done read from storage
[0000.637] I> cpubl-dtb: Authentication init Done
[0000.638] I> parsing oem signed section of eks header done
[0000.639] I> eks binary init read from storage
[0000.640] I> cpubl-dtb: Authentication Finalize Done
[0000.640] I> oem authentication of eks header done
[0000.644] I> eks binary done read from storage
[0000.648] I> eks: Authentication init Done
[0000.652] I> eks: Authentication Finalize Done
[0000.656] I> EKB detected (length: 0x410) @ VA:0x5270a400
\FD\FDNOTICE: BL31: v1.3(release):23b153a63
NOTICE: BL31: Built : 22:43:07, Dec 9 2019
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
keystore-demo: 141: Hello world from keystore-demo app
keystore-demo: 207: main: EKB contents match expected value
exit called, thread 0xffffffffea88ed58, name trusty_app_2_7d18fc60-e9fc-11e8
platform_bootstrap_epilog: trusty bootstrap complete
\FD\FDwelcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is c1b4e372932429f2737cf722e1219e71
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg initialized
mrq initialized
\FD\FD
[0001.071] I> Welcome to Cboot
[0001.071] I> Cboot Version: t194-8a9e8a5a
\FD\FDfmon_post initialized
\FD\FD[0001.072] I> CPU-BL Params @ 0xf2820000
[0001.072] I> 0) Base:0x00000000 Size:0x00000000
[0001.073] I> 1) Base:0xf1100000 Size:0x00100000
[0001.078] I> 2) Base:0xf2000000 Size:0x00200000
[0001.082] I> 3) Base:0xf1200000 Size:0x00200000
[0001.087] I> 4) Base:0xf1000000 Size:0x00100000
[0001.091] I> 5) Base:0xf0f00000 Size:0x00100000\FD\FDclk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
\FD\FD
[0001.160] I> 6) Base:0xf3800000 Size:0x00400000
[0001.165] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.169] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.174] I> 9) Base:0xf0d00000 Size:0x00100000\FD\FDemc_debugfs initialized
dvs_debugfs initialized
\FD\FD
[0001.183] I> 10) Base:0xf3000000 Size:0x00800000
\FD\FDfmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] \FD\FD[0001.187] I> 11) Base:0x40000000 Size:0x00040000
[0001.238] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.242] I> 13) Base:0x40046000 Size:0x00002000
[0001.247] I> 14) Base:0x40048000 Size:0x00002000
[0001.251] I> 15) Base:0xac000000 Size:0x00004000
[0001.256] I> 16) Base:0x4004a000 Size:0x00002000
[0001.260] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.265] I> 18) Base:0x4004c000 Size:0x00002000
[0001.269] I> 19) Base:0xf2200000 Size:0x00600000
[0001.274] I> 20) Base:0x4004e000 Size:0x00002000
[0001.278] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.283] I> 22) Base:0x00000000 Size:0x00000000
[0001.287] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.291] I> 24) Base:0xf6000000 Size:0x02000000
[0001.296] I> 25) Base:0x40050000 Size:0x00002000
[0001.300] I> 26) Base:0x40040000 Size:0x00006000
[0001.305] I> 27) Base:0xf1800000 Size:0x00400000
[0001.309] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.314] I> 29) Base:0xf1400000 Size:0x00400000
[0001.318] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.323] I> 31) Base:0x00000000 Size:0x00000000
[0001.327] I> 32) Base:0xf8000000 Size:0x08000000
[0001.332] I> 33) Base:0x00000000 Size:0x00000000
[0001.336] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.341] I> 35) Base:0xab000000 Size:0x01000000
[0001.345] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.350] I> 37) Base:0xf2800000 Size:0x00800000
[0001.354] I> 38) Base:0x80000000 Size:0x20000000
[0001.358] I> 39) Base:0xb0000000 Size:0x08000000
[0001.363] I> 40) Base:0x00000000 Size:0x00000000
[0001.367] I> 41) Base:0x00000000 Size:0x00000000
[0001.372] I> 42) Base:0x00000000 Size:0x00000000
[0001.376] I> 43) Base:0x00000000 Size:0x00000000
[0001.381] I> 44) Base:0x00000000 Size:0x00000000
[0001.385] I> 45) Base:0x00000000 Size:0x00000000
[0001.390] GIC-SPI Target CPU: 0
[0001.393] Interrupts Init done
[0001.396] calling constructors
[0001.398] initializing heap
[0001.401] I> Heap: [0xa0690588 … 0xab000000]
[0001.405] initializing threads
[0001.408] initializing timers
[0001.411] creating bootstrap completion thread
[0001.415] top of bootstrap2()
[0001.418] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.423] initializing platform
[0001.426] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.431] W> device prod register failed
[0001.435] I> Bl_dtb @0xaaf00000
[0001.442] E> “plugin-manager” doesn’t exist, creating
[0001.443] E> “ids” doesn’t exist, creating
[0001.447] E> “connection” doesn’t exist, creating
[0001.451] E> “configs” doesn’t exist, creating
[0001.463] I> Find /i2c@3160000’s alias i2c0
[0001.463] I> Reading eeprom i2c=0 address=0x50
[0001.489] I> Device at /i2c@3160000:0x50
[0001.490] I> Reading eeprom i2c=0 address=0x56
[0001.514] I> Device at /i2c@3160000:0x56
[0001.516] I> Find /i2c@3180000’s alias i2c2
[0001.516] I> Reading eeprom i2c=2 address=0x54
[0001.518] E> I2C: slave not found in slaves.
[0001.518] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.519] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.520] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.528] E> eeprom: Failed to read I2C slave device
[0001.533] I> Eeprom read failed 0x3526070d
[0001.537] I> Reading eeprom i2c=2 address=0x57
[0001.541] E> I2C: slave not found in slaves.
[0001.545] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.553] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.559] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.568] E> eeprom: Failed to read I2C slave device
[0001.573] I> Eeprom read failed 0x3526070d
[0001.577] I> Reading eeprom i2c=2 address=0x52
[0001.581] E> I2C: slave not found in slaves.
[0001.585] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.593] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.599] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.608] E> eeprom: Failed to read I2C slave device
[0001.613] I> Eeprom read failed 0x3526070d
[0001.619] I> Find /i2c@c240000’s alias i2c1
[0001.621] I> Reading eeprom i2c=1 address=0x52
[0001.627] E> I2C: slave not found in slaves.
[0001.629] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.637] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.643] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.652] E> eeprom: Retry to read I2C slave device.
[0001.657] E> I2C: slave not found in slaves.
[0001.661] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.669] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.675] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.684] E> eeprom: Failed to read I2C slave device
[0001.689] I> Eeprom read failed 0x3526070d
[0001.693] I> Reading eeprom i2c=1 address=0x50
[0001.697] E> I2C: slave not found in slaves.
[0001.701] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.709] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.715] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.724] E> eeprom: Retry to read I2C slave device.
[0001.729] E> I2C: slave not found in slaves.
[0001.733] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.741] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.746] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.756] E> eeprom: Failed to read I2C slave device
[0001.761] I> Eeprom read failed 0x3526070d
[0001.765] I> create_pm_ids: id: 2888-0004-400-G, len: 15
[0001.770] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.781] I> create_pm_ids: id: 2822-0000-700-G, len: 15
[0001.786] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.797] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0001.805] E> “i2c@3160000” doesn’t exist, creating
[0001.809] E> “module@0x50” doesn’t exist, creating
[0001.814] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0001.821] E> “module@0x56” doesn’t exist, creating
[0001.828] I> Adding plugin-manager/cvm
[0001.829] E> “chip-id” doesn’t exist, creating
[0001.833] I> Adding plugin-manager/chip-id/A02
[0001.837] I> Plugin-manager override starting
[0001.843] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.853] I> node /plugin-manager/fragement-soft-wdt matches
[0001.863] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.869] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0001.892] I> Disable plugin-manager status in FDT
[0001.892] I> Plugin-manager override finished successfully
[0001.893] I> gpio framework initialized
[0001.896] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
[0001.898] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0001.899] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.904] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.912] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.917] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.923] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.931] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.939] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.945] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.953] I> fixed regulator driver initialized
[0001.963] I> register ‘maxim’ power off handle
[0001.964] I> virtual i2c enabled
[0001.965] I> registered ‘maxim,max20024’ pmic
[0001.967] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0001.974] I> Boot-device: eMMC
[0001.977] I> Boot_device: SDMMC_BOOT instance: 3
[0001.985] I> sdmmc-3 params source = boot args
[0001.986] I> sdmmc bdev is already initialized
[0001.990] I> sdmmc-3 params source = boot args
[0002.020] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.033] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.044] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.050] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.050] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.051] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.056] E> invalid display type
[0002.061] E> invalid display type
[0002.062] E> cannot find any other nvdisp nodes
[0002.062] E> no valid display unit config found in dtb
[0002.064] W> display init failed
[0002.064] I> Load in CBoot Boot Options partition and parse it
[0002.067] E> Cannot read beyond partition boundary for CPUBL-CFG
[0002.073] E> tegrabl_read_cbo Failed to read CPUBL-CFG partition
[0002.079] W> platform_init: tegrabl_read_cbo failed with error 0xd0d0104
[0002.085] I> Hit any key to stop autoboot: 4 3 2 1
[0004.093] initializing target
[0004.093] calling apps_init()
[0004.094] starting app kernel_boot_app
[0004.113] I> found decompressor handler: lz4-legacy
[0004.114] I> decompressing BMP blob …
[0004.119] I> Kernel type = Normal
[0004.119] I> Loading partition kernel-bootctrl at 0xa42b0000 from device(0x1)
[0004.125] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.126] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.126] I> ########## SD boot ##########
[0004.127] I> No sdcard
[0004.127] I> -0 params source =
[0004.130] E> Blockdev open: exit error
[0004.134] E> SD boot failed, err: 724238353
[0004.138] I> ########## USB boot ##########
[0004.147] W> No valid slot number is found in scratch register
[0004.147] W> Return default slot: _a
[0004.163] I> USB Firmware Version: 60.06 release
[0004.219] I> regulator of usb2-0 already enabled
[0004.228] I> regulator of usb2-1 already enabled
[0004.237] I> regulator of usb2-2 already enabled
[0004.248] I> enabling ‘vdd-5v-sata’ regulator
[0005.254] E> failed to initialize xhci controller
[0005.255] E> Error in init of XUSB host driver, err: 79790026
[0005.255] E> Failed to initialize device 5-0
[0005.255] E> USB boot failed, err: 2037973030
[0005.256] I> ########## Fixed storage boot ##########
[0005.256] I> Already published: 00010003
[0005.256] I> Look for boot partition
[0005.260] I> Fallback: assuming 0th partition is boot partition
[0005.265] I> Detect filesystem
[0005.292] I> Loading extlinux.conf …
[0005.293] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0005.336] I> L4T boot options
[0005.336] I> [1]: “primary kernel”
[0005.336] I> [2]: “upstream kernel”
[0005.336] I> [3]: “test kernel”
[0005.337] I> Enter choice:
[0006.295] I> Selected option: 2
[0006.296] I> Loading kernel sig file from rootfs …
[0006.296] I> rootfs path: /sdmmc_user/boot/Image-upstream.sig
[0006.321] I> Loading kernel binary from rootfs …
[0006.321] I> rootfs path: /sdmmc_user/boot/Image-upstream
[0006.508] I> Validate kernel …
[0006.509] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0006.760] E> digest on binary did not match!!
[0006.760] C> OEM authentication of kernel payload failed!
[0006.761] W> Failed to validate kernel binary (err=1077936152)
[0006.761] W> Security fuse not burned, continue to boot
[0006.767] I> Loading kernel-dtb sig file from rootfs …
[0006.767] I> rootfs path: /sdmmc_user/boot/tegra194-p2972-0000.dtb.sig
[0006.786] I> Loading kernel-dtb binary from rootfs …
[0006.786] I> rootfs path: /sdmmc_user/boot/tegra194-p2972-0000.dtb
[0006.805] I> Validate kernel-dtb …
[0006.805] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0006.806] E> digest on binary did not match!!
[0006.806] C> OEM authentication of kernel-dtb payload failed!
[0006.807] W> Failed to validate kernel-dtb binary (err=1077936152)
[0006.807] W> Security fuse not burned, continue to boot
[0006.811] W> Ramdisk image path not found
[0006.815] I> Kernel hdr @0xa42b0000
[0006.818] I> Kernel dtb @0x90000000
[0006.821] I> decompressor handler not found
[0006.825] I> Copying kernel image (27574784 bytes) from 0xa42b0000 to 0x80080000 … [0006.838] I> Done
[0006.839] I> Updated bpmp info to DTB
[0006.839] I> Ramdisk: Base: 0x0; Size: 0x0
[0006.842] I> Updated initrd info to DTB
[0006.846] W> WARN: Fail to override “console=none” in commandline
[0006.852] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0006.859] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0006.866] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0006.873] W> No valid slot number is found in scratch register
[0006.879] W> Return default slot: _a
[0006.883] I> Active slot suffix:
[0006.886] I> add_boot_slot_suffix: slot_suffix =
[0006.890] I> Linux Cmdline: console=ttyS0,115200n8 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boo
t.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0006.915] I> Updated bootarg info to DTB
[0006.919] W> MAC addr invalid!
[0006.921] E> Failed to get WIFI MAC address
[0006.925] W> MAC addr invalid!
[0006.928] E> Failed to get Bluetooth MAC address
[0006.933] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:cc:31:ad
[0006.939] E> “plugin-manager” doesn’t exist, creating
[0006.944] I> Adding /chosen/plugin-manager/cvm
[0006.948] E> “chip-id” doesn’t exist, creating
[0006.952] I> Adding /chosen/plugin-manager/chip-id
[0006.957] E> “configs” doesn’t exist, creating
[0006.961] I> Adding /chosen/plugin-manager/configs
[0006.966] E> “ids” doesn’t exist, creating
[0006.970] I> Adding /chosen/plugin-manager/ids
[0006.974] E> “odm-data” doesn’t exist, creating
[0006.978] I> Adding /chosen/plugin-manager/odm-data
[0006.984] E> “memory” doesn’t exist, creating
[0006.987] I> [0] START: 0x80000000, END: 0xac000000
[0006.992] I> [1] START: 0xac004000, END: 0xf09d0000
[0006.997] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0007.002] I> dram_block larger than 80000000
[0007.006] I> [3] START: 0x100000000, END: 0x880000000
[0007.011] I> added [base:0x80000000, size:0x2c000000] to /memory
[0007.016] I> added [base:0xac200000, size:0x44600000] to /memory
[0007.022] I> added [base:0x100000000, size:0x780000000] to /memory
[0007.029] I> Updated memory info to DTB
[0007.032] E> “reserved-memory” doesn’t exist, creating
[0007.037] E> add_disp_param: failed to get display params for du=0
[0007.043] E> “reset” doesn’t exist, creating
[0007.047] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0007.052] I> Enabled cpu-0 (mpidr: 0x0) node in FDT
[0007.057] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0007.061] I> Enabled cpu-1 (mpidr: 0x1) node in FDT
[0007.066] E> Couldn’t find /cpu/cpu@2
[0007.070] E> tegrabl_linuxboot_update_dtb: 0xa063da7c failed
[0007.075] E> Error (724238349) extracting the kernel DTB
[0007.080] E> kernel boot failed
