I have two Samsung displays here and both of them do support the resolution I want to use: 1600x900. The primary display is connected to my GT 710 DVI output and is working fine, but the second one connected to the VGA output is not presenting the correct resolution as shown in the first picture. In the second and third pictures, as you can see, the resolutions are properly configured and yes, I double checked the second display built in configurations. Can someone help me with this?
Also I tested the second display with my old laptop using a VGA cable and it’s working just fine
Driver version: nvidia-455.45.01-7
Kernel version: 5.9.14
And that’s my xrandr output:
xrandr
Screen 0: minimum 8 x 8, current 3200 x 900, maximum 16384 x 16384
VGA-0 connected 1600x900+1600+0 (normal left inverted right x axis y axis) 0mm x 0mm
1024x768 60.00 +
1600x900 59.82*
1400x900 59.88
1368x768 59.88 59.85
1280x800 59.91 59.81
1280x720 59.86 59.74
1024x576 59.90 59.82
960x540 59.82 59.63
864x486 59.92 59.57
800x600 72.19 60.32 56.25
800x450 59.82
700x450 59.88
684x384 59.88 59.85
640x480 59.94
640x400 59.98 59.88
640x360 59.86 59.83
512x384 60.00
512x288 60.00 59.92
480x270 59.82 59.63
432x243 59.92 59.57
400x300 72.19
320x240 60.05
DVI-D-0 connected primary 1600x900+0+0 (normal left inverted right x axis y axis) 443mm x 249mm
1600x900 60.00*+
1440x900 74.98 59.89
1280x800 59.81
1280x720 60.00 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP1 disconnected (normal left inverted right x axis y axis)
HDMI1 disconnected (normal left inverted right x axis y axis)
VGA1 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
