Linux not recognizing the Nvidia 1660ti GPU
nvidia-bug-report.log.gz (844.7 KB)
What the report establishes:
  • The laptop detects the GPU at PCI address 01:00.0.
  • NVIDIA reads its model, IRQ, and unique GPU ID.
  • PCIe BARs are assigned and the device remains in the active D0 power state.
  • There are no PCIe AER, lane, or “GPU fallen off the bus” errors.
  • Driver 580.173.02 built and loaded correctly.
  • GSP firmware is definitely disabled.
  • Nevertheless, GPU initialization times out:
    • Xid 154: GPU Reset Required
    • RmInitAdapter failed (0x23:0x65:1587)
    • NVIDIA display-engine allocation times out.
    • The NVIDIA HDMI-audio function also times out.
    • The driver cannot read the video BIOS version—it reports ??.??.??.??.??.
how do i solve this
I’m aware that this GPU is not capable of using GSP firmware, but have tried not forcibly disabling it? Maybe then the driver will figure it out on its own and just move on?
Also, check if there’s maybe some firmware update available for you laptop from its manufacturer.
UPDATE: I’ve just noticed that you are using the open flavor of the driver: this flavor ignores NVreg_EnableGpuFirmware as it’s not able to function without GSP firmware. If the previous hints don’t help, then try the proprietary flavor instead.
Also, you GPU is supported by newer versions of the driver, so try these as well.
the laptop is HP omen 15 en, the laptop is on the current firmware update.
i have done this processes
still not being seen by the nvidia-smi
what do logs say on the proprietary flavor with GSP disabled? (bug report files from the latest version of the driver (610.x.x) could probably be useful)
