Release highlights since 340.24:
- Added support for the following GPUs:
- Quadro K420
- Quadro K620
- Quadro K2200
- Quadro K4200
- Quadro K5200
- GeForce 830A
- GeForce 810M
- Fixed a regression that prevented the internal stereo infrared emitter built into some 3D Vision monitors from working.
- Fixed a bug that could cause some Java-based OpenGL applications using JOGL to crash on startup on systems with Xinerama enabled.
- Fixed a bug that could prevent OpenGL Framebuffer Objects (FBOs) from being properly redrawn after a modeswitch.
- Fixed a memory leak that occurred when starting OpenGL applications.
- Fixed a bug that prevented the EDID-Like Data (ELD) of audio-capable displays from being updated when hotplugged/unplugged.
- Fixed a bug that caused Xid errors when using stereo mode 12 (HDMI 3D) on Quadro boards without an onboard stereo DIN connector.
- Fixed a video corruption issue for VDPAU decoding of VC-1 and WMV video streams utilizing range remapping on Maxwell GPUs.
- Fixed a "black window" bug in Ubuntu 14.04 when using the Xinerama and Composite extensions.
- Fixed a bug that caused the screen's contents to be shifted downward when a G-SYNC monitor is unplugged and replaced by a non-G-SYNC monitor.
- Fixed a bug that prevented G-SYNC from working when a G-SYNC monitor was unplugged and plugged back in without a modeset.
- Fixed a bug that could cause framelock status to be incorrectly reported in the nvidia-settings control panel on some multi-GPU framelock configurations.
- Improved the performance of OpenGL applications that request a large number of GPU mappings via the GL_NV_shader_buffer_load extension.
- Fixed a bug that could cause a system crash when killing applications that use NVIDIA GPUs on multiple-GPU systems with IOMMU functionality enabled.
- Fixed a bug that caused the NVIDIA kernel module to leak memory for DMA mappings on some configurations.
[README | Linux x86 | Linux x86_64 | Linux ARM | Solaris | FreeBSD x86 | FreeBSD x86_64]
