Release highlights since 352.30:
- Fixed a bug that could cause data from one texture level to overwrite data from the next lowest level, when creating a texture view that did not include the higher of the two levels.
- Fixed a bug that could cause the nvidia-settings control panel to crash when updating the display layout.
- Corrected some erroneous reporting of support for GLX extensions: several extensions were being reported as supported for indirect GLX, which were in fact only supported under direct rendering.
- Added support for the following EGL extensions:
- EGL_KHR_swap_buffers_with_damage
- EGL_NV_stream_consumer_gltexture_yuv
- Replaced the build system for the NVIDIA kernel modules and updated the installer package and nvidia-installer to use the new build system and kernel module source code layout. For more information about the new build system and layout, see the README document at: ftp://download.nvidia.com/XFree86/packaging/linux/new-kbuild-for-355/
- Added experimental full OpenGL support to EGL.
- Marked the DeleteUnusedDP12Displays option as deprecated.
Version 1.5.0 of the X Resize and Rotate specification added a note that dynamically-created outputs will not be destroyed, so this option is deprecated and will be removed in a future driver release.
- Added support for VDPAU profiles added in VDPAU 0.9:
- VDP_DECODER_PROFILE_H264_BASELINE
- VDP_DECODER_PROFILE_H264_CONSTRAINED_BASELINE
- VDP_DECODER_PROFILE_H264_EXTENDED
- VDP_DECODER_PROFILE_H264_PROGRESSIVE_HIGH
- VDP_DECODER_PROFILE_H264_CONSTRAINED_HIGH
- Fixed a bug that prevented more than one RandR output from sharing user-added modes.
- Fixed a bug that caused application-specified swap intervals to be ignored on some screens when using Xinerama.
- Fixed a bug that caused user-supplied RandR modes with nonsensical combinations of the +HSync, -HSync, +VSync, and -VSync flags to corrupt the mode list.
- Added support to make an OpenGL 3.0 and above context current without making current to any drawable.
- Fixed a bug that caused VDPAU to only display the top half of a video frame when decoding and displaying H.265/HEVC encoded video streams.
[README | Linux x86 | Linux x86_64 | Linux ARM | Solaris | FreeBSD x86 | FreeBSD x86_64]
