Linux, Solaris, and FreeBSD driver 440.44 [long-lived branch release]
Release highlights since 440.36:
  • Added support for the following GPU:
    • GeForce GTX 1650 SUPER
    • Quadro T2000 with Max-Q Design
  • Added support for the __GL_SYNC_DISPLAY_DEVICE environment variable for Vulkan applications.
  • Fixed a bug that caused applications running directly on a display (such as VR HMDs) to tear when a G-SYNC or G-SYNC Compatible monitor is plugged in the system.
  • Fixed a bug in an error handling path that could cause a kernel crash while loading nvidia.ko.
  • Fixed driver installation failure on Oracle Linux 7.7 systems, where the NVIDIA kernel module failed to build with error "unknown type name 'vm_fault_t'"
[README | Linux x86_64 | Solaris | FreeBSD x86_64]
