英伟达团队您好,如何在linux系统下查看重启原因,在刚启动uefi阶段能重启原因,比如rst_source: 0x0, rst_level: 0x0
刚启动阶段uefi:
linux系统下如何查看类似信息?
Hi 1516775545,
Are you using the devkit or custom board for Thor?
We would suggest checking the full serial console log when you hit the unexpected reboot issue instead.
Current version: R38 (release), REVISION: 4.0; future upgrade target: R39 (release), REVISION: 2.0
Custom Thor board; serial port difficult to access on mass production hardware.
On Jetson AGX Thor with R38.4 or R39.2, there is currently no supported Linux sysfs interface to read the previous reset source.
If you need to identify the reset cause, please capture the early serial boot log and check the rst_source field like the screenshot you shared, because that information is reported during early boot rather than through sysfs.
