I’m installing linuxcan for Kvaser Leaf Light V2 on Jetpack 3.1 Ubuntu. It got built fine. But I got error when installing it,
nvidia@tegra-ubuntu:/media/nvidia/SD32G/sw/linuxcan$ sudo make installInstalling common
Installing leaf
install: failed to access ‘/lib/modules/4.4.38-tegra/kernel/drivers/usb/misc/leaf.ko’: Not a directory
Makefile:119: recipe for target ‘install’ failed
make: *** [install] Error 1
On TX1, usb/misc is a file, not a binary,
nvidia@tegra-ubuntu:/lib/modules/4.4.38-tegra/kernel/drivers/usb$ ll misc
-rw-r–r-- 1 root root 968400 Nov 17 18:26 misc
On my Ubuntu 16.04 PC, usr/misc is a directory and I can install linuxcan without any issue.
I would suggest to use the below steps to setup CAN communication on your TX1/TX2 board.
Steps to enable and check CAN on Tegra:
Enable kernel support for mttcan (Other required modules are already supported)
Insert CAN BUS subsystem support module.
modprobe can
Insert Raw CAN protocol module (CAN-ID filtering)
modprobe can_raw
Real CAN interface support (for our case, it is: mttcan)
modprobe mttcan (dependent module is can_dev: can driver with netlink support)
CAN interface settings for both the controllers
ip link set can0 type can bitrate 500000 dbitrate 2000000 berr-reporting on fd on
ip link set up can0
ip link set can1 type can bitrate 500000 dbitrate 2000000 berr-reporting on fd on
ip link set up can1
Installation of user app to check CAN communication
sudo apt-get install can-utils
Commands to run to check CAN packet send/receive
broadcasting a can data packet:
cansend <can_interface> <can_frame>
e.g. cansend can0 123#abcdabcd
Receiving a can data packet:
candump can_interface
e.g. candump can1
Different tools (i.e. cangen, cangw etc) can be used for various filtering options.
To check the interface statistics
ip -details -statistics link show can0
ip -details -statistics link show can1
Thanks for the detailed reply. I figured out how to run linuxcan. Basically I reinstalled JetPack 3.1 and make sure kernel header files are installed in /usr/src and /lib/modules properly. Then everything just works, thanks,
