Now when I use sdk-manager, it shows the options above 4.6. How do I install older jetpack versions ? I have one jetson with JetPack 4.3 flashed. Can I save this image and boot my newer device with it ?
may I know what’s the actual use-case?
are you going to flash the target with JP-4.6 but boot-up with your JP-4.3 image? this is impossible due to roll-back protection.
what’s your CAN bus issue, why don’t you refer to that dtsi changes to resolve your issue on latest release?
please go Jetson Linux Archive | NVIDIA Developer and please download public sources package, [L4T Driver Package (BSP) Sources].
that device tree sources is within kernel_src.tbz2 package.
Thanks for the link Jerry. I still need some help here.
For getting CAN working on JetPack 4.6.1, I have understood that I need to modify the device tree file by modifying the binaries but the step involving flash.sh is still unclear. The suggested answer says that I must flash JP using sdkmanager but not complete it. And then proceed with the flash.sh before finishing with login. Is this correct?
assume you’ve already download JetPack release via NVIDIA SDK Manager.
it’ll also install all necessary scripts and binaries to your local host machine,
the default path looks like following, ~/nvidia/nvidia_sdk/JetPack_<version>_Linux_<platform>/Linux_for_Tegra/
please enter the installation path, you’ll able to execute flash script for running partition flash.
here’s developer guide, Flashing a Specific Partition for your reference, thanks
