Like for GCC, you can use -dM
with nvc
to dump predefined macros. Is there a similar option for Fortran? (If not, as seems the case, will there be?)
It’s the same, though you do need to have preprocessing enabled, either via the flag “-Mpreprocess”, or by default when using capitols in the suffix like “.F90”.
% nvfortran hello.f90 -dM -Mpreprocess
#define __STDC_HOSTED__ 1
#define __CHAR_UNSIGNED__ 1
#define __arm64__ 1
#define __aarch64__ 1
#define __LP64__ 1
#define __PGLLVM__ 1
#define __NVCOMPILER_LLVM__ 1
#define __extension__
#define __linux__ 1
#define __linux 1
#define __ELF__ 1
#define linux 1
#define unix 1
#define __ARM_ARCH_8__ 1
#define __ARM_ARCH_8A__ 1
#define __ARM_ARCH 8
#define __ARM_PCS_VFP 1
#define __VFP_FP__ 1
#define __ARM_FEATURE_FMA 1
#define __ARM_NEON 1
#define __ARM_NEON__ 1
#define __ARM_FP 0x0C
#define __LITTLE_ENDIAN__ 1
#define __AARCH64EL__ 1
#define __ARM_FEATURE_DIRECTED_ROUNDING 1
#define __ARM_FEATURE_SVE_MATMUL_INT8 1
#define __ARM_FEATURE_SVE_MATMUL_FP32 1
#define __ARM_FEATURE_SVE_MATMUL_FP64 1
#define __NVCOMPILER_GPU_SEPARATE_MEM 1
#define __PGI 1
#define __NVCOMPILER 1
#define __LINE__ 0
#define __FILE__ 1
#define __DATE__ "Sep 24 2024"
#define __TIME__ "11:37:24"
#define __STDC__ 1
#define __PGIC__ 24
#define __NVCOMPILER_MAJOR__ 24
#define __PGIF90__ 24
#define __PGIC_MINOR__ 7
#define __NVCOMPILER_MINOR__ 7
#define __PGIF90_MINOR__ 7
#define __PGIC_PATCHLEVEL__ 0
#define __NVCOMPILER_PATCHLEVEL__ 0
#define __PGIF90_PATCHLEVEL__ 0
Thanks, Mat! Embarrassing I didn’t make the preprocessor connection :)
Is there a way to #ifdef that it’s nvfortran? (Other than using the old PGI macros and presumably this will change in the not distant future)
I’d use “__NVCOMPILER”.
OK, thanks. That’s what I was doing in the interim, anyway
