First of all, great framework. Thank you Nvidia team!
I trained a custom model using NeMo on my own dataset and was able to succesfully build and deploy it to a local Jarvis server with Docker.
However, when I run the example transcribe_file.py client, I cannot specify the model name in the RecognitionConfig
I keep getting the following error:
grpc._channel._MultiThreadedRendezvous: <_MultiThreadedRendezvous of RPC that terminated with:
status = StatusCode.INVALID_ARGUMENT
details = "Error: Model QN15x5-TL-0.1 is not available on server"
debug_error_string = "{"created":"@1625238474.234893929","description":"Error received from peer ipv6:[::1]:50051","file":"src/core/lib/surface/call.cc","file_line":1066,"grpc_message":"Error: Model QN15x5-TL-0.1 is not available on server","grpc_status":3}"
My model is built using the following script:
jarvis-build speech_recognition /servicemaker-dev/QuartzNet15x5-TlEa_IU-SpecCutAug-last.jmir \
/servicemaker-dev/QuartzNet15x5-TlEa_IU-SpecCutAug-last.enemo \
--chunk_size=0.8 \
--padding_factor=4 \
--padding_size=1.6 \
--ms_per_timestep=80 \
--lm_decoder_cpu.asr_model_delay=-1 \
--featurizer.use_utterance_norm_params=False \
--featurizer.precalc_norm_time_steps=0 \
--featurizer.precalc_norm_params=False \
--lm_decoder_cpu.decoder_type=greedy \
--acoustic_model_name=qn15x5-arabic \
--name=QN15x5-TL-0.1
I tried using the name I set in acoustic_model_name
, name
, the name of the file (QuartzNet15x5-TlEa_IU-SpecCutAug-last
), the name of the directory in /data/models/
Nothing works. Is there more documentation on how to properly use the model
field in the config and extra params?
And is there a way to get all model names available for the client?
