Hardware: Jetson AGX Thor
JetPack / L4T: 7.2 / R39.2
DeepStream: 9.1
GStreamer: 1.24.2
Cameras: RTSP IP cameras, H.264, 2688x1520 (4MP), 20fps, ~6 Mbps
Symptom — Dual-camera DeepStream pipeline shows intermittent, sudden blocky/mosaic corruption in decoded frames, live cameras only, never reproduced on file-replay of identical recorded footage. GStreamer’s bus reports zero errors/warnings during confirmed corruption. Episodes aren’t single-frame — a logged episode on 2026-08-14 shows continuous corruption sustained for ~8 minutes with a matching fps drop.
Evidence — instrumented the unfixed uridecodebin baseline with NVIDIA’s nvds_logger, a GStreamer bus watch, a 10s heartbeat, and tegrastats hardware telemetry. Captured a full episode (12:49–12:57 IST) gap-free: fps drops from steady ~4-5fps to erratic 1.4-2.4fps during corruption and recovers after; zero bus ERROR/WARNING/EOS the entire time despite the watch being confirmed active; no thermal/memory correlation.
Root cause — uridecodebin’s auto-negotiated internal pipeline for rtsp:// sources.
Additional layer — NVIDIA’s own unapplied update_rtpmanager.sh (4 patches), including a real deadlock fix and a packaging gap where one patch is missing from both the SDK install and the release tarball.
What did NOT fix it — nvurisrcbin, CPU decode (works but not viable), VIC exhaustion (ruled out), decoder property tweaks, and — notably — raising rtspsrc latency made it worse.
Open questions:
- Can anyone confirm uridecodebin as root cause on AGX Thor specifically?
- Is the missing rtpmanager patch (#2, the deadlock fix) intentionally excluded from the DS9.1 tarball, or an oversight?
- Guidance on backporting DS9.1-only patches to DS8.0 without a JetPack upgrade?
- Is the fps-drop signature during corruption a known symptom, or a separate contributing factor (jitterbuffer under packet loss)
- nvurisrcbin, did not fix this corruption on two separate Jetson AGX Thor devices, even though it’s the officially recommended RTSP source element for DeepStream. Is this a known limitation of nvurisrcbin, and if so, is manually constructing the RTSP pipeline from individual elements (rtspsrc, rtph264depay, h264parse, nvv4l2decoder) instead of using a bundled source-bin element the currently recommended approach for live RTSP on this hardware/DeepStream version?
Please refer these logs and the NVIDIA forum threads reviewed + what we tried from each:
02_corruption_episode_1249_1258.log (38.7 KB)
01_full_run_startup_to_1238.log (177.8 KB)
FORUM_LINKS_AND_FIXES_TRIED.txt (7.8 KB)
