Livestream not working and omni USD not foundd error
Hello, I recently installed Isaac Sim and after successfully installing it and also downloading the datasets I tried teleoperating one of the robots given in the examples using this command:
python -m omnigibson.examples.robots.robot_control_example
And I got a module error that omni.usd is not found. Attached is the photo of the error I am getting.
Here is my log
Choose a robot (enter a number from 1 to 11): 10
[INFO] [omnigibson.simulator] ----- Starting OmniGibson. This will take 10-30 seconds… -----
Starting kit application with the following args: [‘/home/Austine/.local/share/ov/pkg/isaac-sim-2023.1.0-hotfix.1/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py’, ‘/home/Austine/.local/share/ov/pkg/isaac-sim-2023.1.0-hotfix.1/apps/omnigibson.kit’, ‘–/app/tokens/exe-path=/home/Austine/.local/share/ov/pkg/isaac-sim-2023.1.0-hotfix.1/kit’, ‘–/persistent/app/viewport/displayOptions=3094’, ‘–/rtx/materialDb/syncLoads=True’, ‘–/rtx/hydra/materialSyncLoads=True’, ‘–/omni.kit.plugin/syncUsdLoads=True’, ‘–/app/renderer/resolution/width=1280’, ‘–/app/renderer/resolution/height=720’, ‘–/app/window/width=1440’, ‘–/app/window/height=900’, ‘–/renderer/multiGpu/enabled=False’, ‘–/app/fastShutdown=True’, ‘–ext-folder’, ‘/home/Austine/.local/share/ov/pkg/isaac-sim-2023.1.0-hotfix.1/exts’, ‘–ext-folder’, ‘/home/Austine/.local/share/ov/pkg/isaac-sim-2023.1.0-hotfix.1/apps’, ‘–/physics/cudaDevice=0’, ‘–portable’]
Passing the following args to the base kit application:
[Info] [carb] Logging to file: /home/Austine/.local/share/ov/pkg/isaac-sim-2023.1.0-hotfix.1/kit/logs/Kit/Isaac-Sim/2023.1/kit_20240927_180926.log
2024-09-27 22:09:26 [0ms] [Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn’t available.
[0.027s] Failed to solve some dependencies locally, syncing with extension registry…
[0.028s] [ext: omni.kit.async_engine-0.0.0] startup
[DEBUG] [asyncio] Using selector: EpollSelector
[0.029s] [ext: omni.assets.plugins-0.0.0] startup
[0.030s] [ext: omni.client-1.0.1] startup
[0.034s] [ext: omni.kit.registry.nucleus-0.0.0] startup
2024-09-27 22:09:58 [32,085ms] [Error] [omni.ext.plugin] Failed to resolve extension dependencies. Failure hints:
[omnigibson-2023.1.1] dependency: (name: ‘omni.kit.streamsdk.plugins’, tag: ‘’, version: ‘2.5.2’, exact: 1, optional: 0) can’t be satisfied. Available versions:
- [omni.kit.streamsdk.plugins-2.6.2+105.1.lx64.r] (registry)
- [omni.kit.streamsdk.plugins-2.5.1+105.1.lx64.r] (registry)
- [omni.kit.streamsdk.plugins-2.5.0+105.1.lx64.r] (registry)
- [omni.kit.streamsdk.plugins-2.3.7+105.1.lx64.r] (/home/Austine/.local/share/ov/pkg/isaac-sim-2023.1.0-hotfix.1/extscache/omni.kit.streamsdk.plugins-2.3.7+105.1.lx64.r)
- [omni.kit.streamsdk.plugins-2.1.3+105.1.lx64.r] (/home/Austine/.local/share/ov/pkg/isaac-sim-2023.1.0-hotfix.1/extscache/omni.kit.streamsdk.plugins-2.1.3+105.1.lx64.r)
- [omni.kit.streamsdk.plugins-2.0.3+105.0.lx64.r] (registry)
2024-09-27 22:09:58 [32,086ms] [Error] [omni.kit.app.plugin] Exiting app because of dependency solver failure…
[32.093s] Simulation App Starting
File “/home/Austine/anaconda3/envs/omnigibson/lib/python3.10/runpy.py”, line 196, in _run_module_as_main
return _run_code(code, main_globals, None,
File “/home/Austine/anaconda3/envs/omnigibson/lib/python3.10/runpy.py”, line 86, in _run_code
exec(code, run_globals)
File “/home/Austine/OmniGibson/omnigibson/examples/robots/robot_control_example.py”, line 154, in
main()
File “/home/Austine/OmniGibson/omnigibson/examples/robots/robot_control_example.py”, line 93, in main
env = og.Environment(configs=cfg)
File “/home/Austine/OmniGibson/omnigibson/utils/python_utils.py”, line 90, in wrapper
func(*values.args, **values.kwargs)
File “/home/Austine/OmniGibson/omnigibson/envs/env_base.py”, line 41, in init
launch_simulator()
File “/home/Austine/OmniGibson/omnigibson/simulator.py”, line 173, in launch_simulator
og.app = _launch_app()
File “/home/Austine/OmniGibson/omnigibson/simulator.py”, line 90, in _launch_app
app = lazy.omni.isaac.kit.SimulationApp(config_kwargs, experience=str(kit_file_target.resolve(strict=True)))
File “/home/Austine/.local/share/ov/pkg/isaac-sim-2023.1.0-hotfix.1/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py”, line 214, in init
create_new_stage()
File “/home/Austine/.local/share/ov/pkg/isaac-sim-2023.1.0-hotfix.1/exts/omni.isaac.kit/omni/isaac/kit/utils.py”, line 65, in create_new_stage
import omni.usd
ModuleNotFoundError: No module named ‘omni.usd’
2024-09-27 22:09:58 [32,087ms] [Warning] [carb] Recursive unloadAllPlugins() detected!
cc: @VickNV
cc: @MatColgrove
Is your problem the same as How to resolve ModuleError Omni.usd not found? Could you check if the response from another user there helps?
Thank you for reaching out about this issue. I apologize, but OmniGibson is not maintained or officially supported by NVIDIA. For questions regarding Isaac Sim version compatibility with OmniGibson, I recommend consulting the OmniGibson community directly.
Please see if How to download old versions of Isaac Sim - #6 by liujk0725 is helpful.
