Llama 3.1 nemotron 70b instruct API access not working correctly
I started a project over a year ago using the Llama 3.1 nemotron 70b model as the nvidia build site suggested. This was the code I used to generate a response from the model:
client = OpenAI(
    base_url = "https://integrate.api.nvidia.com/v1",
    api_key = MY_API_KEY
completion = client.chat.completions.create(
    model="nvidia/llama-3.1-nemotron-70b-instruct",
    messages=PREV_MESSAGES,
    temperature=0.6,
    top_p=0.85,
    max_tokens=1024,
    stream=True
There was other code involved if needed, but I believe the problem is within this section of code. I’ve had to renew my API key twice in the past and I hadn’t messed with my project in a while. When I came back it was not working due to the API key expiring so I renewed it the same way I did the other 2 times, made sure I’m using the same library versions as before, and didn’t change anything else. I received the following error code and was not able to diagnose the problem:
File ā€œC:\Users\isaac\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.13_qbz5n2kfra8p0\LocalCache\local-packages\Python313\site-packages\openai_base_client.pyā€, line 1034, in request
raise self._make_status_error_from_response(err.response) from None
openai.NotFoundError: Error code: 404 - {ā€˜status’: 404, ā€˜title’: ā€˜Not Found’, ā€˜detail’: ā€œFunction ā€˜9b96341b-9791-4db9-a00d-4e43aa192a39’: Not found for account ā€˜xhOhm8Fuo43Dj1yZv-6EspU97tp_SVoh5tcZbgEz6-cā€™ā€}
Hi @isaac78 , we no longer host the Llama 3.1 nemotron 70b model. I’d suggest you use either Llama 3.3 Nemotron Super 49b or Nemotron nano 9b v2.
