ZhaoWS
November 27, 2024, 12:06pm
1
My nano (8g) is flashed with jetpack6.0 (cuda=12.2, gcc=11.4). When I compile the source code of llama.cpp(with cuda) on orin nano, the following error occurs. Has anyone successfully compiled on nano? Does anyone know how to solve this error?
/usr/lib/gcc/aarch64-linux-gnu/11/include/arm_neon.h(38): error: identifier “__Int8x8_t” is undefined
typedef __Int8x8_t int8x8_t;
/usr/lib/gcc/aarch64-linux-gnu/11/include/arm_neon.h(39): error: identifier “__Int16x4_t” is undefined
typedef __Int16x4_t int16x4_t;
/usr/lib/gcc/aarch64-linux-gnu/11/include/arm_neon.h(40): error: identifier “__Int32x2_t” is undefined
typedef __Int32x2_t int32x2_t;
/usr/lib/gcc/aarch64-linux-gnu/11/include/arm_neon.h(41): error: identifier “__Int64x1_t” is undefined
typedef __Int64x1_t int64x1_t;
/usr/lib/gcc/aarch64-linux-gnu/11/include/arm_neon.h(42): error: identifier “__Float16x4_t” is undefined
typedef __Float16x4_t float16x4_t;
/usr/lib/gcc/aarch64-linux-gnu/11/include/arm_neon.h(43): error: identifier “__Float32x2_t” is undefined
typedef __Float32x2_t float32x2_t;
/usr/lib/gcc/aarch64-linux-gnu/11/include/arm_neon.h(44): error: identifier “__Poly8x8_t” is undefined
typedef __Poly8x8_t poly8x8_t;
/usr/lib/gcc/aarch64-linux-gnu/11/include/arm_neon.h(45): error: identifier “__Poly16x4_t” is undefined
typedef __Poly16x4_t poly16x4_t;
Error limit reached.
100 errors detected in the compilation of “/home/nano8g-1/llama.cpp/ggml/src/ggml-cuda/ggml-cuda.cu”.
Compilation terminated.
gmake[2]: *** [ggml/src/ggml-cuda/CMakeFiles/ggml-cuda.dir/build.make:314: ggml/src/ggml-cuda/CMakeFiles/ggml-cuda.dir/ggml-cuda.cu.o] Error 4
gmake[1]: *** [CMakeFiles/Makefile2:1760: ggml/src/ggml-cuda/CMakeFiles/ggml-cuda.dir/all] Error 2
gmake: *** [Makefile:146: all] Error 2
It looks like you encountered an issue similar to the one in the link below.
Could you give their solution a try?
opened 12:56PM - 26 Mar 23 UTC
closed 03:12PM - 30 Dec 23 UTC
i am trying to build bitsandbytes on a Nvidia Jetson AGX Xavier Kit, but … it fails, not finding emmintrin.h:
`/home/g/bitsandbytes# CUDA_VERSION=114 make cuda11x_nomatmul`
>ENVIRONMENT
CUDA_VERSION: 114
NVCC path: /usr/local/cuda/bin/nvcc
GPP path: /usr/bin/g++ VERSION: g++ (Ubuntu 9.4.0-1ubuntu1~20.04.1) 9.4.0
CUDA_HOME: /usr/local/cuda
CONDA_PREFIX:
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/local/cuda/bin/
LD_LIBRARY_PATH:
/usr/local/cuda/bin/nvcc -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_72,code=sm_72 -gencode arch=compute_75,code=sm_75 -gencode arch=compute_80,code=sm_80 -gencode arch=compute_86,code=sm_86 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -Xcompiler '-fPIC' --use_fast_math -Xptxas=-v -dc /home/g/bitsandbytes/csrc/ops.cu /home/g/bitsandbytes/csrc/kernels.cu -I /home/g/sse2neon -I /usr/local/cuda/include -I /home/g/bitsandbytes/csrc -I /include -I /home/g/bitsandbytes/include -L /usr/local/cuda/lib64 -lcudart -lcublas -lcublasLt -lcurand -lcusparse -L /lib --output-directory /home/g/bitsandbytes/build -D NO_CUBLASLT
nvcc warning : The 'compute_35', 'compute_37', 'compute_50', 'sm_35', 'sm_37' and 'sm_50' architectures are deprecated, and may be removed in a future release (Use -Wno-deprecated-gpu-targets to suppress warning).
In file included from /home/g/bitsandbytes/include/BinSearch.h:5,
from /home/g/bitsandbytes/csrc/ops.cu:10:
/home/g/bitsandbytes/include/SIMD.h:32:10: fatal error: emmintrin.h: No such file or directory
32 | #include <emmintrin.h>
compilation terminated.
make: *** [Makefile:83: cuda11x_nomatmul] Error 1
Did a bit of research and, not knowing what i am doing, I changed SMID.h to include sse2neon.h instead of emmintrin.h. NOW it fails again, catastrophically, not finding builtin functions:
>/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(38): error: identifier "__Int8x8_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(39): error: identifier "__Int16x4_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(40): error: identifier "__Int32x2_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(41): error: identifier "__Int64x1_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(42): error: identifier "__Float16x4_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(43): error: identifier "__Float32x2_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(44): error: identifier "__Poly8x8_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(45): error: identifier "__Poly16x4_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(46): error: identifier "__Uint8x8_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(47): error: identifier "__Uint16x4_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(48): error: identifier "__Uint32x2_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(49): error: identifier "__Float64x1_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(50): error: identifier "__Uint64x1_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(51): error: identifier "__Int8x16_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(52): error: identifier "__Int16x8_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(53): error: identifier "__Int32x4_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(54): error: identifier "__Int64x2_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(55): error: identifier "__Float16x8_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(56): error: identifier "__Float32x4_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(57): error: identifier "__Float64x2_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(58): error: identifier "__Poly8x16_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(59): error: identifier "__Poly16x8_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(60): error: identifier "__Poly64x2_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(61): error: identifier "__Poly64x1_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(62): error: identifier "__Uint8x16_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(63): error: identifier "__Uint16x8_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(64): error: identifier "__Uint32x4_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(65): error: identifier "__Uint64x2_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(67): error: identifier "__Poly8_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(68): error: identifier "__Poly16_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(69): error: identifier "__Poly64_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(70): error: identifier "__Poly128_t" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(72): error: identifier "__fp16" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(795): error: identifier "__builtin_aarch64_saddlv8qi" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(802): error: identifier "__builtin_aarch64_saddlv4hi" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(809): error: identifier "__builtin_aarch64_saddlv2si" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(816): error: identifier "__builtin_aarch64_uaddlv8qi" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(824): error: identifier "__builtin_aarch64_uaddlv4hi" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(832): error: identifier "__builtin_aarch64_uaddlv2si" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(840): error: identifier "__builtin_aarch64_saddl2v16qi" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(847): error: identifier "__builtin_aarch64_saddl2v8hi" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(854): error: identifier "__builtin_aarch64_saddl2v4si" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(861): error: identifier "__builtin_aarch64_uaddl2v16qi" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(869): error: identifier "__builtin_aarch64_uaddl2v8hi" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(877): error: identifier "__builtin_aarch64_uaddl2v4si" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(885): error: identifier "__builtin_aarch64_saddwv8qi" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(892): error: identifier "__builtin_aarch64_saddwv4hi" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(899): error: identifier "__builtin_aarch64_saddwv2si" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(906): error: identifier "__builtin_aarch64_uaddwv8qi" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(914): error: identifier "__builtin_aarch64_uaddwv4hi" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(922): error: identifier "__builtin_aarch64_uaddwv2si" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(930): error: identifier "__builtin_aarch64_saddw2v16qi" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(937): error: identifier "__builtin_aarch64_saddw2v8hi" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(944): error: identifier "__builtin_aarch64_saddw2v4si" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(951): error: identifier "__builtin_aarch64_uaddw2v16qi" is undefined
/usr/lib/gcc/aarch64-linux-gnu/9/include/arm_neon.h(959): error: identifier "__builtin_aarch64_uaddw2v8hi" is undefined
SETUP:
>nvcc: NVIDIA (R) Cuda compiler driver
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Sun_Oct_23_22:16:07_PDT_2022
Cuda compilation tools, release 11.4, V11.4.315
Build cuda_11.4.r11.4/compiler.31964100_0
Flashed using JetPack 5.1 (Ubuntu 20.04)
> R35 (release), REVISION: 2.1, GCID: 32413640, BOARD: t186ref, EABI: aarch64, DATE: Tue Jan 24 23:38:33 UTC 2023
> Linux ubuntu 5.10.104-tegra #1 SMP PREEMPT Tue Jan 24 15:09:44 PST 2023 aarch64 aarch64 aarch64 GNU/Linux
[full_output_nvcc-verbose.txt](https://github.com/TimDettmers/bitsandbytes/files/11071624/full_output_nvcc-verbose.txt)
# Any help would be greatly appreciated, thank you!
We also have a container with llama.cpp preinstalled. You don’t need to build it manually.
ZhaoWS
December 2, 2024, 2:16pm
4
Thanks, sir!
It is not the problem of Orin nano. I have solved it by updating the CMake to the latest version, although I still don’t know why.
I am facing the same issue while trying to build llama.cpp in the Jetson Orin nano.
The issue is the llama.cpp can not directly install everything for the Cortex A78 CPU. It has an option up to cortex A77.
I am trying to update the CmakeList.txt so that it can work.
@ZhaoWS , when you compiled the llama.cpp (with cuda) source code, what instructions did you follow? Which makefile?
system
Closed
January 13, 2025, 11:23am
9
