Hi, in 34.1.1 jetson_uefi.bin could load BOOTAA64.efi from other partitions than esp but this doesn’t seem to work anymore in 35.1.0.
I’m currently storing BOOTAA64.efi in
resin-boot/EFI/BOOT/BOOTAA64.efi to avoid having a different esp partition solely for the L4T launcher. The partition table looks like this:
Number Start End Size File system Name Flags
1 40s 262183s 262144s A_kernel msftdata
2 262184s 262951s 768s A_kernel-dtb msftdata
3 262952s 525095s 262144s B_kernel msftdata
4 525096s 525863s 768s B_kernel-dtb msftdata
5 525864s 2491943s 1966080s fat16 resin-boot msftdata
6 2491944s 5416487s 2924544s ext4 resin-rootA msftdata
7 5416488s 8341031s 2924544s ext4 resin-rootB msftdata
8 8341032s 8381991s 40960s ext4 resin-state msftdata
9 8381992s 124321758s 115939767s ext4 resin-data msftdata
Where I need to edit some code to have BOOTAA64.efi loaded from resin-boot/EFI/BOOT/ by default?
I should mention that I can boot the L4TLauncher if I select it in the Boot Manager using the Test Key, but I would like to have it loaded automatically after the device is flashed.
I’m building edk2-nividia from sources using the nvidia toolchain and recommended build steps, and in the logs I see that the efi firmware proceeds to loading the kernel from it’s partition without attempting the L4T launcher:
PROGRESS CODE: V02010000 I0
PROGRESS CODE: V02010004 I0
DeviceDiscoveryBindingStart, driver returned Unsupported to start notification
PROGRESS CODE: V02020000 I0
RefreshAutoEnumeratedBootOptions: Using DTB Kernel Command Line
RefreshAutoEnumeratedBootOptions: Cmdline:
console=ttyTCU0,115200 RefreshAutoEnumeratedBootOptions: Using DTB Kernel Command Line
console=ttyTCU0,115200 PROGRESS CODE: V02020000 I0
Found 640x480
Found 1280x720
Found 1920x1080
** WARNING: Test Key is used. **
PROGRESS CODE: V03051007 I0
InstallFdt: Installing Kernel DTB
Processing "L4T Configuration Settings" DTB overlay
Deleting fragment fragment@0
Processing "Add PCIe C5 dual mode support" DTB overlay
Deleting fragment fragment@1
Processing "Jetson Concord (40Pin RT5658)" DTB overlay
Deleting fragment fragment@2
Deleting fragment fragment@3
Deleting fragment fragment@4
Deleting fragment fragment@5
Deleting fragment fragment@6
Deleting fragment fragment@7
Deleting fragment fragment@8
Deleting fragment fragment@9
Deleting fragment fragment@12
Deleting fragment fragment@13
Deleting fragment fragment@14
Deleting fragment fragment@15
Processing "Add P3737 A03 Overlay Support" DTB overlay
Processing "Add P3737 A04 Overlay Support" DTB overlay
Processing "L4T Rootfs Information" DTB overlay
Processing "Jetson Camera Dual-IMX274" DTB overlay
[Bds]Booting UEFI NVIDIA eMMC L4T Boot 2 <-----------------------------
PROGRESS CODE: V03058000 I0
Loading driver at 0x007F9930000 EntryPoint=0x007FB0C9F44
PROGRESS CODE: V03058001 I0
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Exiting boot services and installing virtual address map...
ConfigureOutputGpios: could not find compatible GPIO node in DT: not on SLT board?
PROGRESS CODE: V03101019 I0
and when use Boot Maintainance Manager I see the following log from Bds:
Deleting fragment fragment@27
UpdateRamOopsMemory: RamOopsBase: 0x82C200000, RamOopsSize: 0x200000
PROGRESS CODE: V03051001 I0
[Bds]Booting BOOTAA64.efi
add-symbol-file /home/acotsach/Downloads/simplehttp/edk2/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Application/L4TLauncher/L4TLauncher/DEBUG/L4TLauncher.dll 0x822880000
Loading driver at 0x0082287F000 EntryPoint=0x00822889410 L4TLauncher.efi
So I suspect that loading L4TLauncher by default is somehow configurable but I don’t know how to enforce this.
Thank you
