Loading nvidia/NVIDIA-Nemotron-3-Nano-30B-A3B-BF16 on DGX Spark
Platform: DGX Spark, Blackwell GB10, aarch64, Ubuntu 24.04
GPU HBM: 130.7 GB (separate from 121 GB CPU LPDDR5x — NOT unified despite marketing)
CUDA: 13.2 Forward Compatibility mode (driver 580.x, kernel 580.159.03)
Use case: LoRA fine-tuning for the NVIDIA Nemotron Model Reasoning Challenge (Kaggle)
1. Docker flags — --gpus all does not work
The standard NVIDIA container runtime fails on GB10:
# These all fail with:
# "failed to fulfil mount request: open /usr/bin/nvidia-cuda-mps-control: no such file"
--gpus all
--runtime=nvidia
--device nvidia.com/gpu=all
Working pattern:
docker run --privileged \
  -e NVIDIA_VISIBLE_DEVICES=all \
  --ipc=host \
  --ulimit memlock=-1 \
  --ulimit stack=67108864 \
  • --privileged grants full host capabilities, bypassing the failing bind-mount
  • NVIDIA_VISIBLE_DEVICES=all tells the runtime which GPUs to expose
  • --ipc=host shares the host IPC namespace (required for multi-process GPU comms)
  • --ulimit memlock=-1 removes the locked-memory ceiling (needed for CUDA pinned allocations)
2. Base image and Python packages
Base image: nvcr.io/nvidia/pytorch:26.04-py3 (aarch64)
Pinned packages — exact versions matter:
RUN pip install \
    "transformers==5.5.3" \
    "peft==0.14.0" \
    "trl==0.15.2" \
    "accelerate==1.3.0"
Why transformers==5.5.3 specifically: This is the first version with native NemotronHForCausalLM support including the KV-cache fix. Do NOT use trust_remote_code=True — it pulls the model’s bundled code which has the old broken KV-cache implementation.
Source builds required — causal-conv1d and mamba-ssm
Docker RUN steps run in isolated OCI containers with no GPU access, so mamba-ssm silently skips building selective_scan_cuda.so at install time. The extension is absent from the installed package and fails at runtime.
# causal-conv1d — must force-build, must include sm_120 and sm_121 (Blackwell)
RUN CAUSAL_CONV1D_FORCE_BUILD=TRUE \
    TORCH_CUDA_ARCH_LIST="8.0;8.6;8.7;8.9;9.0;12.0;12.1+PTX" \
    CUDA_HOME=/usr/local/cuda \
    MAX_JOBS=8 \
    pip install causal-conv1d --no-binary causal-conv1d --no-build-isolation
# mamba-ssm — same arch list; patch selective_scan_cuda import after build
RUN TORCH_CUDA_ARCH_LIST="8.0;8.6;8.7;8.9;9.0;12.0;12.1+PTX" \
    MAX_JOBS=8 \
    pip install mamba-ssm --no-binary mamba-ssm --no-build-isolation \
 && python3 -c "
f='/usr/local/lib/python3.12/dist-packages/mamba_ssm/ops/selective_scan_interface.py'
c=open(f).read()
needle='\nimport selective_scan_cuda\n'
open(f,'w').write(c.replace(needle,
  '\ntry:\n    import selective_scan_cuda\nexcept ImportError:\n    selective_scan_cuda = None\n',
  1)) if needle in c else None
print('selective_scan_cuda patched OK')"
Why the patch is safe: Nemotron-H uses Mamba-2 Triton kernels exclusively for its forward pass and never calls the legacy Mamba-1 selective_scan_cuda CUDA path. Wrapping the import in try/except is a no-op at runtime — the extension simply isn’t called.
MAX_JOBS=8: Without this, cmake spawns one job per CPU core. The DGX Spark has 72 ARM cores — spawning 72 parallel compile jobs during docker build exhausts memory and kills the build. MAX_JOBS=8 keeps it sane.
bitsandbytes — source build for Blackwell sm_120
Pre-built bitsandbytes wheels don’t include Blackwell compute capabilities:
RUN git clone https://github.com/bitsandbytes-foundation/bitsandbytes.git /opt/bitsandbytes \
 && cd /opt/bitsandbytes \
 && cmake -DCOMPUTE_BACKEND=cuda \
          -DCOMPUTE_CAPABILITY="80;86;87;89;90;120;121" \
          -S . -B build \
 && cmake --build build --config Release -j8 \
 && pip install . --no-build-isolation
3. Model loading code
from transformers import AutoModelForCausalLM, AutoTokenizer
import torch
tokenizer = AutoTokenizer.from_pretrained("nvidia/NVIDIA-Nemotron-3-Nano-30B-A3B-BF16")
if tokenizer.pad_token is None:
    tokenizer.pad_token = tokenizer.eos_token
model = AutoModelForCausalLM.from_pretrained(
    "nvidia/NVIDIA-Nemotron-3-Nano-30B-A3B-BF16",
    dtype=torch.bfloat16,       # NOT torch_dtype= (deprecated in transformers 5.5.3)
    device_map={"": 0},         # single GPU, explicit device assignment
    low_cpu_mem_usage=True,     # REQUIRED — see note below
low_cpu_mem_usage=True is critical. Without it, from_pretrained first allocates the full model as empty CPU tensors (~57 GB), then streams the safetensors data into them. The empty model + mmap page cache + partial GPU allocation stack up to well over 121 GB even halfway through loading → OOM.
With low_cpu_mem_usage=True the meta-device path is used: the model is initialised as an empty shell with no backing memory, and weights stream in one tensor at a time directly to their final device location. This eliminates the empty-model spike.
Do not use trust_remote_code=True — transformers 5.5.3 has native NemotronHForCausalLM support. Using trust_remote_code pulls the model’s bundled code which has the old broken KV-cache implementation and will cause incorrect inference results.
4. CUDA allocator tuning
Pass as an environment variable to the container:
-e PYTORCH_CUDA_ALLOC_CONF="expandable_segments:True,max_split_size_mb:512"
  • expandable_segments:True — allocator grows memory incrementally rather than reserving large contiguous blocks up front; reduces peak RSS and fragmentation
  • max_split_size_mb:512 — prevents large cached blocks from being fragmented into sub-512 MB pieces; reduces the chance of failing a large allocation even when total free memory is sufficient
5. Memory architecture — two separate pools
Despite the “unified memory” marketing, the GB10 has two distinct physical memory pools:
Pool Size What lives here
GPU HBM (Blackwell) 130.7 GB (via torch.cuda.mem_get_info()) CUDA tensors, model weights, activations
CPU LPDDR5x ~121 GB (via free -h) Linux page cache, Python heap, Docker overlays
These pools are linked by NVLink-C2C but do NOT compete for the same physical memory. free -h shows only the CPU-side pool — it tells you nothing about GPU HBM availability. torch.cuda.mem_get_info() is the correct tool to check GPU memory.
6. Pre-loading memory cleanup — the hard part
The failure pattern: After any SIGKILL’d container (OOM, crash, docker stop), the CUDA driver does not release HBM allocations. They persist as orphaned allocations completely invisible to nvidia-smi --query-compute-apps (which only shows running processes). Each subsequent run starts with less available HBM:
Attempt HBM available % of model loaded before OOM
Clean start ~122 GB 100% ✓
After 1 killed run ~116 GB ~97%
After 2 killed runs ~110 GB ~86%
After 3 killed runs ~103 GB ~73%
Required cleanup sequence before every training run:
# Step 1: Stop gnome-remote-desktop — holds ~6 GB HBM CUDA context
systemctl --user stop gnome-remote-desktop.service
# Step 2: Remove stale container
# Driver releases orphaned HBM when the next CUDA context initialises
docker rm -f <previous-container-name> 2>/dev/null || true
# Step 3: Drop Linux page cache + reset swap + tune VM
# Run inside a privileged Alpine container (avoids needing sudo on host)
sync
docker run --rm --privileged -v /:/host alpine sh -c '
  echo 3 > /proc/sys/vm/drop_caches
  echo 1048576 > /proc/sys/vm/min_free_kbytes
  echo 500 > /proc/sys/vm/vfs_cache_pressure
  swapoff /host/swap.img 2>/dev/null
  swapon /host/swap.img 2>/dev/null
  true'
# Step 4: Torch GPU preflight
# Creating a new CUDA context forces the driver to GC orphaned HBM allocations
# from any prior dead containers. Check that free HBM > 70 GB before loading.
docker run --rm --privileged -e NVIDIA_VISIBLE_DEVICES=all <your-image> python3 -c "
import torch
torch.cuda.init()
torch.cuda.empty_cache()
free, total = torch.cuda.mem_get_info()
used = total - free
print(f'GPU free={free/1e9:.1f}GB  total={total/1e9:.1f}GB  used={used/1e9:.1f}GB')
if free < 70e9:
    print('ABORT: less than 70 GB free — stale allocations present, try rebooting')
else:
    print('OK: enough HBM to load 60 GB model')
# Step 5: Second drop_caches pass
# The preflight container itself adds ~8 GB (new CUDA context overhead).
# Without this second pass, training starts with that 8 GB already consumed.
sync
docker run --rm --privileged alpine sh -c '
  echo 500 > /proc/sys/vm/vfs_cache_pressure'
# Step 6: Launch training with lower I/O priority
# safetensors shard reads compete with host I/O during the 6-minute loading window
ionice -c 2 -n 7 docker run --privileged \
  --oom-score-adj 300 \
Why min_free_kbytes=1048576 (1 GB): At the default (45 KB), the kernel barely evicts file-backed pages until near-OOM. During model loading, safetensors mmap pages accumulate in the CPU pool. Setting 1 GB tells the kernel to proactively reclaim pages, keeping the CPU pool clean during the 6-minute load window.
Why vfs_cache_pressure=500: Makes file-backed page eviction 5× more aggressive. Restore defaults after training: min_free_kbytes=45166, vfs_cache_pressure=100.
Why nvidia_uvm module reload doesn’t help: In CUDA Forward Compatibility mode (the GB10’s default — driver 580.x with kernel module 580.x), rmmod nvidia_uvm always fails. The torch preflight + docker rm -f is the only available cleanup path short of a full reboot.
7. During-load CUDA cache dropper thread
Even with low_cpu_mem_usage=True, from_pretrained accumulates ~41 GB of freed-but-cached CUDA blocks by the time loading reaches ~80%. These are temporary tensors from dtype conversion that PyTorch has freed internally but not returned to the driver. Without periodic empty_cache() calls they pile up and cause OOM at ~97% loading despite having plenty of total HBM.
import threading
import torch
def make_cache_dropper(interval: float = 20.0) -> threading.Event:
    """Background thread: drop Linux page cache + return freed CUDA blocks every interval s."""
    stop = threading.Event()
    def _loop():
        while not stop.wait(interval):
            # Drop Linux page cache (CPU pool hygiene)
            try:
                with open("/proc/sys/vm/drop_caches", "w") as f:
                    f.write("3\n")
            except OSError:
                pass
            # Return freed CUDA allocator cache back to the driver
            try:
                free_before = torch.cuda.mem_get_info()[0]
                free_after = torch.cuda.mem_get_info()[0]
                reclaimed = (free_after - free_before) / 1e9
                alloc = torch.cuda.memory_allocated() / 1e9
                print(f"[dropper] reclaimed={reclaimed:+.1f}GB  alloc={alloc:.1f}GB  "
                      f"free={free_after/1e9:.1f}GB", flush=True)
            except Exception:
                pass
    t = threading.Thread(target=_loop, daemon=True, name="cache-dropper")
    t.start()
    return stop
# Usage:
_stop = make_cache_dropper(interval=20.0)
model = AutoModelForCausalLM.from_pretrained(...)
_stop.set()
free_gb = torch.cuda.mem_get_info()[0] / 1e9
print(f"Model loaded. GPU free={free_gb:.1f}GB")
8. Gradient checkpointing bypass (fine-tuning)
NemotronHForCausalLM.supports_gradient_checkpointing = False is set at the class level, which causes TRL/HF to raise ValueError when gradient_checkpointing=True is passed.
However, every NemotronHBlock inherits GradientCheckpointingLayer which fully implements gradient checkpointing. The flag guard is the only blocker. Bypass it directly:
import functools
import torch
_gc_func = functools.partial(
    torch.utils.checkpoint.checkpoint,
    use_reentrant=False
model.base_model.model._set_gradient_checkpointing(
    enable=True,
    gradient_checkpointing_func=_gc_func
model.enable_input_require_grads()
# IMPORTANT: keep gradient_checkpointing=False in SFTConfig / TrainingArguments
# so TRL does not call gradient_checkpointing_enable() again and hit the ValueError.
This reduces activation memory from ~20–40 GB to ~1–5 GB at seq_len=6144, which is the difference between OOM at the first training step and stable training throughout.
9. Mamba fast path (optional but recommended for training speed)
After the model loads, enable the Mamba CUDA fast path:
import sys
for name, mod in sys.modules.items():
    if "modeling_nemotron_h" in name and hasattr(mod, "is_fast_path_available"):
        mod.is_fast_path_available = True
        print("Mamba fast path enabled")
        break
10. Complete memory budget
Component HBM
Base model BF16 ~60 GB
CUDA context overhead ~8 GB
LoRA adapter r=32 (standard PEFT, attention only) ~0.1 GB
LoRA adapter r=32 (Unsloth, all layers incl. 128 MoE experts) ~1.5 GB
Training activations at seq=6144 with gradient checkpointing ~5–10 GB
Total at training step (Unsloth) ~75–80 GB
Available (130.7 GB − 8 GB context) ~122 GB
Headroom ~42–47 GB
The model loads and trains comfortably on DGX Spark once the memory cleanup sequence is followed. Failures happen when stale CUDA allocations from prior killed containers reduce available HBM below the ~75 GB needed.
11. LoRA fine-tuning — Unsloth required for full MoE coverage
Standard PEFT (get_peft_model) cannot add LoRA to Nemotron-H’s MoE expert layers. The 128 experts per MoE block are stored as batched 3-D torch.Parameter tensors, not nn.Linear modules. PEFT’s named_modules() walk misses them entirely — silently, with no error.
Unsloth (FastLanguageModel.from_pretrained) patches the model before get_peft_model runs, replacing the batched expert tensors with individual nn.Linear-like wrappers. This exposes all 128 experts as trainable LoRA targets.
Without Unsloth: ~116 LoRA modules (27M trainable params, attention layers only)
With Unsloth: ~6,004 LoRA modules (883M trainable params, all layers including MoE)
Install note: Unsloth requires GPU at import time — from unsloth import FastLanguageModel fails in Docker RUN steps. Install with --no-deps and verify with pip show at build time; the actual import works at runtime when the GPU is accessible.
RUN pip install unsloth unsloth_zoo --no-deps && \
    pip install \
        "peft==0.14.0" \
        "trl==0.15.2" \
        "accelerate==1.3.0" \
        --force-reinstall --no-deps && \
    pip show unsloth unsloth_zoo | grep -E "^Name|^Version"
# Note: `from unsloth import FastLanguageModel` cannot be tested here —
# unsloth_zoo runs a GPU presence check at import time (device_type.py)
# which raises NotImplementedError in GPU-less build containers.
# Import is guarded by try/except in training script and succeeds at runtime.
Summary checklist
  • Use --privileged -e NVIDIA_VISIBLE_DEVICES=all (not --gpus all)
  • Build causal-conv1d and mamba-ssm from source with TORCH_CUDA_ARCH_LIST including 12.0;12.1+PTX
  • Patch selective_scan_interface.py after mamba-ssm install
  • Pin transformers==5.5.3 — native NemotronH, no trust_remote_code
  • Load with dtype=torch.bfloat16, device_map={"": 0}, low_cpu_mem_usage=True
  • Set PYTORCH_CUDA_ALLOC_CONF="expandable_segments:True,max_split_size_mb:512"
  • Before each run: stop GRD, docker rm -f stale container, drop_caches ×2, torch preflight
  • Wrap from_pretrained with cache dropper thread (20 s interval)
  • Bypass gradient checkpointing flag via _set_gradient_checkpointing() directly
  • Use Unsloth FastLanguageModel if fine-tuning with LoRA on MoE layers
