Loading Raw Training data in Text-Generation-Webui
Good evening all.
I’m running Text Generation Webui from the NVIDIA Container. I want to do some training, but am unable to locate the training/datasets folder where I am supposed to - per the oobooga instructions - put the raw text file. I’ve tried to create it as a subfolder of the Text-generation-webui folder, and so on.
This is frustrating because it should be very simple. Any suggestions?
Thank you!
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
3. Tutorial
Startup deep learning tutorial:
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
Hi Harrison.schramm:
Can you please share more info about how you setup the env?
Like, if you are using jetson-ai-lab, you might need to modify the start up script to mount your dataset folder to the docker?
PS: AI rookie here. I don’t think using Jetson Orin to train an AI model is OK. Orin indeed have a large GPU memory, but the CUDA cores is pretty poor compare to other GPU cards.
Could you share the steps you run and the output error log so we can know more about your issue?
