Loading time difference between windows and ubuntu 22.04
Continuing the discussion from Issac Sim GUI Freezes
Hey @pranav7296, for the Windows system, is it the first time to load JetBot in Isaac Sim within 10 seconds?
Ya, It was the first attempt. I am still not able to load Jetbot via python script on Ubuntu 22.04 LTS. The screen is frozen even after waiting for 30 min.
Does the terminal give any messages like warnings or errors?
I have specified the warning message in the original post.
Oh thanks… I checked mine, besides that your loading time is much slower than mine and missing one last warning, everything else is the same as mine.
Here is the last warning from my terminal.
2024-09-10 23:10:23 [15,120ms] [Warning] [omni.physx.plugin] Detected an articulation at /World/Fancy_Robot with more than 4 velocity iterations being added to a TGS scene.The related behavior changed recently, please consult the changelog. This warning will only print once.
Could you also run top in your terminal and show me the printout?
Let me reach out to our internal team and see what else could affect loading.
I can see there are few other warnings in the terminal:
2024-09-10 23:21:30 [723ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) Graphics (RPL-S)
2024-09-10 23:21:38 [8,647ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
2024-09-10 23:21:39 [9,742ms] [Warning] [omni.kit.profiler.window] remove _SpanInstance.__lt__ and use insort 'key' arg instead
Output of top:
Tasks: 560 total,   1 running, 559 sleeping,   0 stopped,   0 zombie
%Cpu(s):  0.1 us,  0.1 sy,  0.0 ni, 99.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :  64038.7 total,  50581.9 free,   8142.6 used,   5314.3 buff/cache
MiB Swap: 143051.0 total, 143051.0 free,      0.0 used.  55108.6 avail Mem
    PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
   7899 pranav    20   0  126.8g   5.1g   1.8g S   4.7   8.2   2:02.66 kit
   1719 pranav     9 -11 3072748  28456  20008 S   1.3   0.0   0:06.85 pulseaudio
     61 root      20   0       0      0      0 I   0.3   0.0   0:00.09 kworker/14:0-events
   1347 root     -51   0       0      0      0 S   0.3   0.0   0:04.47 irq/234-nvidia
   2695 pranav    20   0   32.8g 170248  93576 S   0.3   0.3   0:01.84 skypeforlinux
   2750 pranav    20   0  998124  34816  13312 S   0.3   0.1   0:00.64 omni-system-mon
   2845 pranav    20   0  178132  74440  20736 S   0.3   0.1   0:00.64 omni-cache-serv
   4656 pranav    20   0   33.0g 283892 168248 S   0.3   0.4   0:05.93 chrome
   9637 pranav    20   0   13640   4096   3072 R   0.3   0.0   0:00.01 top
      1 root      20   0  166956  10240   7680 S   0.0   0.0   0:00.94 systemd
      2 root      20   0       0      0      0 S   0.0   0.0   0:00.00 kthreadd
      3 root      20   0       0      0      0 S   0.0   0.0   0:00.00 pool_workqueue_release
      4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-rcu_g
      5 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-rcu_p
      6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-slub_
      7 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-netns
      8 root      20   0       0      0      0 I   0.0   0.0   0:00.01 kworker/0:0-events
      9 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/0:0H-events_highpri
     12 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-mm_pe
     13 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_kthread
     14 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_rude_kthread
     15 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_trace_kthread
     16 root      20   0       0      0      0 S   0.0   0.0   0:00.00 ksoftirqd/0
     17 root      20   0       0      0      0 I   0.0   0.0   0:00.09 rcu_preempt
     18 root      rt   0       0      0      0 S   0.0   0.0   0:00.03 migration/0
     19 root     -51   0       0      0      0 S   0.0   0.0   0:00.00 idle_inject/0
     20 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/0
     21 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/2
     22 root     -51   0       0      0      0 S   0.0   0.0   0:00.00 idle_inject/2
     23 root      rt   0       0      0      0 S   0.0   0.0   0:00.16 migration/2
     24 root      20   0       0      0      0 S   0.0   0.0   0:00.00 ksoftirqd/2
     25 root      20   0       0      0      0 I   0.0   0.0   0:00.00 kworker/2:0-events
     26 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/2:0H-events_highpri
     27 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/4
     28 root     -51   0       0      0      0 S   0.0   0.0   0:00.00 idle_inject/4
     29 root      rt   0       0      0      0 S   0.0   0.0   0:00.16 migration/4
     30 root      20   0       0      0      0 S   0.0   0.0   0:00.00 ksoftirqd/4
     32 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/4:0H-events_highpri
     33 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/6
     34 root     -51   0       0      0      0 S   0.0   0.0   0:00.00 idle_inject/6
     35 root      rt   0       0      0      0 S   0.0   0.0   0:00.17 migration/6
     36 root      20   0       0      0      0 S   0.0   0.0   0:00.00 ksoftirqd/6
     37 root      20   0       0      0      0 I   0.0   0.0   0:00.00 kworker/6:0-cgroup_destroy
     38 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/6:0H-events_highpri
     39 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/8
     40 root     -51   0       0      0      0 S   0.0   0.0   0:00.00 idle_inject/8
     41 root      rt   0       0      0      0 S   0.0   0.0   0:00.17 migration/8
     42 root      20   0       0      0      0 S   0.0   0.0   0:00.00 ksoftirqd/8
     43 root      20   0       0      0      0 I   0.0   0.0   0:00.00 kworker/8:0-cgroup_destroy
     44 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/8:0H-events_highpri
It might be related to local nucleus server being stuck.
Could you please try killing all omni services running on the machine and then start the launcher again?
It worked!! Did the following steps to resolve the issue:
  1. Reinstalled the Nucleus Service
  2. Killed All Omni Services and restarted the launcher.
After this, I was able to load JetBot in a few seconds via a python script.
Thanks for your(@zhengwang ) suggestions.
