Dear All,
I’m trying to train a new policy that determines more abstract actions using two learned policies. I referred to the navigation demo code and tried to adapt it for the two policies, but the observation of the first loaded policy is being applied to the second policy as well. Is there a way to avoid this error?
Probably, rolling_low_level_obs = self._rolling_low_level_obs_manager.compute_group("rolling_policy")
is not being processed correctly.
Thank you!
Error Code:
Error executing job with overrides: []
File "/home/robot/IsaacLab_v1.2.0/IsaacLab/source/extensions/omni.isaac.lab_tasks/omni/isaac/lab_tasks/utils/hydra.py", line 99, in hydra_main
func(env_cfg, agent_cfg, *args, **kwargs)
File "/home/robot/IsaacLab_v1.2.0/IsaacLab/source/standalone/workflows/rsl_rl/train.py", line 144, in main
runner.learn(num_learning_iterations=agent_cfg.max_iterations, init_at_random_ep_len=True)
File "/home/robot/anaconda3/envs/iccar2025/lib/python3.10/site-packages/rsl_rl/runners/on_policy_runner.py", line 112, in learn
obs, rewards, dones, infos = self.env.step(actions.to(self.env.device))
File "/home/robot/IsaacLab_v1.2.0/IsaacLab/source/extensions/omni.isaac.lab_tasks/omni/isaac/lab_tasks/utils/wrappers/rsl_rl/vecenv_wrapper.py", line 177, in step
obs_dict, rew, terminated, truncated, extras = self.env.step(actions)
File "/home/robot/anaconda3/envs/iccar2025/lib/python3.10/site-packages/gymnasium/wrappers/record_video.py", line 166, in step
) = self.env.step(action)
File "/home/robot/anaconda3/envs/iccar2025/lib/python3.10/site-packages/gymnasium/wrappers/order_enforcing.py", line 56, in step
return self.env.step(action)
File "/home/robot/IsaacLab_v1.2.0/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/envs/manager_based_rl_env.py", line 169, in step
self.action_manager.apply_action()
File "/home/robot/IsaacLab_v1.2.0/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/managers/action_manager.py", line 328, in apply_action
term.apply_actions()
File "/home/robot/IsaacLab_v1.2.0/IsaacLab/source/extensions/omni.isaac.lab_tasks/omni/isaac/lab_tasks/manager_based/locomotion_selector/mdp/pre_trained_policy_action.py", line 119, in apply_actions
self.rolling_low_level_actions[:] = self.policy_2(rolling_low_level_obs)
File "/home/robot/.local/share/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.ml_archive/pip_prebundle/torch/nn/modules/module.py", line 1553, in _wrapped_call_impl
return self._call_impl(*args, **kwargs)
File "/home/robot/.local/share/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.ml_archive/pip_prebundle/torch/nn/modules/module.py", line 1562, in _call_impl
return forward_call(*args, **kwargs)
RuntimeError: The following operation failed in the TorchScript interpreter.
Traceback of TorchScript, serialized code (most recent call last):
File "code/__torch__/omni/isaac/lab_tasks/utils/wrappers/rsl_rl/exporter.py", line 13, in forward
actor = self.actor
normalizer = self.normalizer
_0 = (actor).forward((normalizer).forward(x, ), )
~~~~~~~~~~~~~~ <--- HERE
return _0
def reset(self: __torch__.omni.isaac.lab_tasks.utils.wrappers.rsl_rl.exporter._TorchPolicyExporter) -> NoneType:
File "code/__torch__/torch/nn/modules/container.py", line 22, in forward
_5 = getattr(self, "5")
_6 = getattr(self, "6")
input0 = (_0).forward(input, )
input1 = (_1).forward(input0, )
input2 = (_2).forward(input1, )
File "code/__torch__/torch/nn/modules/linear.py", line 14, in forward
weight = self.weight
bias = self.bias
return torch.linear(input, weight, bias)
class Identity(Module):
__parameters__ = []
Traceback of TorchScript, original code (most recent call last):
File "/home/robot/IsaacLab_v1.2.0/IsaacLab/source/extensions/omni.isaac.lab_tasks/omni/isaac/lab_tasks/utils/wrappers/rsl_rl/exporter.py", line 76, in forward
def forward(self, x):
return self.actor(self.normalizer(x))
File "/home/robot/.local/share/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.ml_archive/pip_prebundle/torch/nn/modules/container.py", line 219, in forward
def forward(self, input):
for module in self:
input = module(input)
~~~~~~ <--- HERE
return input
File "/home/robot/.local/share/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.ml_archive/pip_prebundle/torch/nn/modules/linear.py", line 117, in forward
def forward(self, input: Tensor) -> Tensor:
return F.linear(input, self.weight, self.bias)
~~~~~~~~ <--- HERE
RuntimeError: mat1 and mat2 shapes cannot be multiplied (1024x147 and 66x512)
My modified code:
# Copyright (c) 2022-2024, The Isaac Lab Project Developers.
# All rights reserved.
# SPDX-License-Identifier: BSD-3-Clause
from __future__ import annotations
import torch
from dataclasses import MISSING
from typing import TYPE_CHECKING
import omni.isaac.lab.utils.math as math_utils
from omni.isaac.lab.assets import Articulation
from omni.isaac.lab.managers import ActionTerm, ActionTermCfg, ObservationGroupCfg, ObservationManager, CommandManager
from omni.isaac.lab.markers import VisualizationMarkers
from omni.isaac.lab.markers.config import BLUE_ARROW_X_MARKER_CFG, GREEN_ARROW_X_MARKER_CFG
from omni.isaac.lab.utils import configclass
from omni.isaac.lab.utils.assets import check_file_path, read_file
if TYPE_CHECKING:
from omni.isaac.lab.envs import ManagerBasedRLEnv
class PreTrainedPolicyAction(ActionTerm):
r"""Pre-trained policy action term.
This action term infers a pre-trained policy and applies the corresponding low-level actions to the robot.
The raw actions correspond to the commands for the pre-trained policy.
cfg: PreTrainedPolicyActionCfg
"""The configuration of the action term."""
def __init__(self, cfg: PreTrainedPolicyActionCfg, env: ManagerBasedRLEnv) -> None:
# initialize the action term
super().__init__(cfg, env)
self.robot: Articulation = env.scene[cfg.asset_name]
#self.env = env
# load policy
#if not check_file_path(cfg.policy_path):
# raise FileNotFoundError(f"Policy file '{cfg.policy_path}' does not exist.")
#file_bytes = read_file(cfg.policy_path)
#self.policy = torch.jit.load(file_bytes).to(env.device).eval()
for i, policy_path in enumerate([cfg.policy_path_1, cfg.policy_path_2], start=1):
if not check_file_path(policy_path):
raise FileNotFoundError(f"Policy file '{policy_path}' does not exist.")
file_bytes = read_file(policy_path)
setattr(self, f"policy_{i}", torch.jit.load(file_bytes).to(env.device).eval())
self._raw_actions = torch.zeros(self.num_envs, self.action_dim, device=self.device)
#self.random_indices = torch.randint(0, 2, (self.num_envs,))
# prepare low level actions
# walking policy
self._walking_low_level_action_term: ActionTerm = cfg.walking_low_level_actions.class_type(cfg.walking_low_level_actions, env)
self.walking_low_level_actions = torch.zeros(self.num_envs, self._walking_low_level_action_term.action_dim, device=self.device)
# rolling policy
self._rolling_low_level_action_term: ActionTerm = cfg.rolling_low_level_actions.class_type(cfg.rolling_low_level_actions, env)
self.rolling_low_level_actions = torch.zeros(self.num_envs, self._rolling_low_level_action_term.action_dim, device=self.device)
# remap some of the low level observations to internal observations
# walking policy
cfg.walking_low_level_observations.actions.func = lambda dummy_env: self.walking_low_level_actions
cfg.walking_low_level_observations.actions.params = dict()
cfg.walking_low_level_observations.velocity_commands.func = lambda dummy_env: self._raw_actions
cfg.walking_low_level_observations.velocity_commands.params = dict()
# rolling policy
cfg.rolling_low_level_observations.actions.func = lambda dummy_env: self.rolling_low_level_actions
cfg.rolling_low_level_observations.actions.params = dict()
cfg.rolling_low_level_observations.velocity_commands.func = lambda dummy_env: self._raw_actions
cfg.rolling_low_level_observations.velocity_commands.params = dict()
# add the low level observations to the observation manager
# walking policy
self._walking_low_level_obs_manager = ObservationManager({"walking_policy": cfg.walking_low_level_observations}, env)
# rolling policy
self._rolling_low_level_obs_manager = ObservationManager({"rolling_policy": cfg.rolling_low_level_observations}, env)
self._counter = 0
Properties.
@property
def action_dim(self) -> int:
return 3
@property
def raw_actions(self) -> torch.Tensor:
return self._raw_actions
@property
def processed_actions(self) -> torch.Tensor:
return self.raw_actions
Operations.
def process_actions(self, actions: torch.Tensor):
self._raw_actions[:] = actions
def apply_actions(self):
if self._counter % self.cfg.low_level_decimation == 0:
walking_low_level_obs = self._walking_low_level_obs_manager.compute_group("walking_policy")
self.walking_low_level_actions[:] = self.policy_1(walking_low_level_obs)
#print(f"get_command: {self.env.command_manager.get_command('pose_command')}")
#print(f"get_command.shape: {self.env.command_manager.get_command('pose_command').shape}")
self._walking_low_level_action_term.process_actions(self.walking_low_level_actions)
self._rolling_low_level_action_term.process_actions(self.rolling_low_level_actions)
#self._walking_low_level_action_term.process_actions(result)
self._counter = 0
self._walking_low_level_action_term.apply_actions()
self._counter += 1
Debug visualization.
def _set_debug_vis_impl(self, debug_vis: bool):
# set visibility of markers
# note: parent only deals with callbacks. not their visibility
if debug_vis:
# create markers if necessary for the first tome
if not hasattr(self, "base_vel_goal_visualizer"):
# -- goal
marker_cfg = GREEN_ARROW_X_MARKER_CFG.copy()
marker_cfg.prim_path = "/Visuals/Actions/velocity_goal"
marker_cfg.markers["arrow"].scale = (0.5, 0.5, 0.5)
self.base_vel_goal_visualizer = VisualizationMarkers(marker_cfg)
# -- current
marker_cfg = BLUE_ARROW_X_MARKER_CFG.copy()
marker_cfg.prim_path = "/Visuals/Actions/velocity_current"
self.base_vel_visualizer = VisualizationMarkers(marker_cfg)
# set their visibility to true
self.base_vel_goal_visualizer.set_visibility(True)
self.base_vel_visualizer.set_visibility(True)
else:
if hasattr(self, "base_vel_goal_visualizer"):
self.base_vel_goal_visualizer.set_visibility(False)
self.base_vel_visualizer.set_visibility(False)
def _debug_vis_callback(self, event):
# check if robot is initialized
# note: this is needed in-case the robot is de-initialized. we can't access the data
if not self.robot.is_initialized:
return
# get marker location
# -- base state
base_pos_w = self.robot.data.root_pos_w.clone()
base_pos_w[:, 2] += 0.5
# -- resolve the scales and quaternions
vel_des_arrow_scale, vel_des_arrow_quat = self._resolve_xy_velocity_to_arrow(self.raw_actions[:, :2])
vel_arrow_scale, vel_arrow_quat = self._resolve_xy_velocity_to_arrow(self.robot.data.root_lin_vel_b[:, :2])
# display markers
self.base_vel_goal_visualizer.visualize(base_pos_w, vel_des_arrow_quat, vel_des_arrow_scale)
self.base_vel_visualizer.visualize(base_pos_w, vel_arrow_quat, vel_arrow_scale)
Internal helpers.
def _resolve_xy_velocity_to_arrow(self, xy_velocity: torch.Tensor) -> tuple[torch.Tensor, torch.Tensor]:
"""Converts the XY base velocity command to arrow direction rotation."""
# obtain default scale of the marker
default_scale = self.base_vel_goal_visualizer.cfg.markers["arrow"].scale
# arrow-scale
arrow_scale = torch.tensor(default_scale, device=self.device).repeat(xy_velocity.shape[0], 1)
arrow_scale[:, 0] *= torch.linalg.norm(xy_velocity, dim=1) * 3.0
# arrow-direction
heading_angle = torch.atan2(xy_velocity[:, 1], xy_velocity[:, 0])
zeros = torch.zeros_like(heading_angle)
arrow_quat = math_utils.quat_from_euler_xyz(zeros, zeros, heading_angle)
# convert everything back from base to world frame
base_quat_w = self.robot.data.root_quat_w
arrow_quat = math_utils.quat_mul(base_quat_w, arrow_quat)
return arrow_scale, arrow_quat
@configclass
class PreTrainedPolicyActionCfg(ActionTermCfg):
"""Configuration for pre-trained policy action term.
See :class:`PreTrainedPolicyAction` for more details.
class_type: type[ActionTerm] = PreTrainedPolicyAction
""" Class of the action term."""
asset_name: str = MISSING
"""Name of the asset in the environment for which the commands are generated."""
#policy_path: str = MISSING
policy_path_1: str = MISSING
policy_path_2: str = MISSING
"""Path to the low level policy (.pt files)."""
low_level_decimation: int = 4
"""Decimation factor for the low level action term."""
#low_level_actions: ActionTermCfg = MISSING
walking_low_level_actions: ActionTermCfg = MISSING
rolling_low_level_actions: ActionTermCfg = MISSING
"""Low level action configuration."""
#low_level_observations: ObservationGroupCfg = MISSING
walking_low_level_observations: ObservationGroupCfg = MISSING
rolling_low_level_observations: ObservationGroupCfg = MISSING
"""Low level observation configuration."""
debug_vis: bool = True
"""Whether to visualize debug information. Defaults to False."""
The information of the learned policies is passed from the main code as shown below.
selector_env_cfg.py:
import math
from omni.isaac.lab.envs import ManagerBasedRLEnvCfg
from omni.isaac.lab.managers import EventTermCfg as EventTerm
from omni.isaac.lab.managers import ObservationGroupCfg as ObsGroup
from omni.isaac.lab.managers import ObservationTermCfg as ObsTerm
from omni.isaac.lab.managers import RewardTermCfg as RewTerm
from omni.isaac.lab.managers import SceneEntityCfg
from omni.isaac.lab.managers import TerminationTermCfg as DoneTerm
from omni.isaac.lab.utils.assets import ISAACLAB_NUCLEUS_DIR
from omni.isaac.lab.managers import ManagerTermBase
#import omni.isaac.lab_tasks.manager_based.navigation.mdp as mdp
import omni.isaac.lab_tasks.manager_based.locomotion_selector.mdp as mdp
#from omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.anymal_c.flat_env_cfg import AnymalCFlatEnvCfg
from omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.AT3R.rough_walking_env_cfg import AT3RRoughEnvCfg as WalkingEnvCfg
from omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.AT3R.rough_rolling_env_cfg import AT3RRoughEnvCfg as RollingEnvCfg
#LOW_LEVEL_ENV_CFG = AnymalCFlatEnvCfg()
WALKING_ENV_CFG = WalkingEnvCfg()
ROLLING_ENV_CFG = RollingEnvCfg()
@configclass
class EventCfg:
"""Configuration for events."""
reset_base = EventTerm(
func=mdp.reset_root_state_uniform,
mode="reset",
params={
"pose_range": {"x": (-0.0, 0.0), "y": (-0.0, 0.0), "yaw": (-3.14, 3.14)},
"velocity_range": {
"x": (-0.0, 0.0),
"y": (-0.0, 0.0),
"z": (-0.0, 0.0),
"roll": (-0.0, 0.0),
"pitch": (-0.0, 0.0),
"yaw": (-0.0, 0.0),
@configclass
class ActionsCfg:
"""Action terms for the MDP."""
#pre_trained_policy_action: mdp.PreTrainedPolicyActionCfg = mdp.PreTrainedPolicyActionCfg(
# asset_name="robot",
# policy_path=f"{ISAACLAB_NUCLEUS_DIR}/Policies/ANYmal-C/Blind/policy.pt",
# low_level_decimation=4,
# low_level_actions=LOW_LEVEL_ENV_CFG.actions.joint_pos,
# low_level_observations=LOW_LEVEL_ENV_CFG.observations.policy,
pre_trained_policy_action = mdp.PreTrainedPolicyActionCfg = mdp.PreTrainedPolicyActionCfg(
asset_name="robot",
policy_path_1=f"/home/robot/IsaacLab_v1.2.0/IsaacLab/logs/policies/walking_policy/2024-12-11_15-33-54/exported/policy.pt",
policy_path_2=f"/home/robot/IsaacLab_v1.2.0/IsaacLab/logs/policies/rolling_policy/2024-12-13_13-41-19/exported/policy.pt",
walking_low_level_actions=WALKING_ENV_CFG.actions.joint_pos,
walking_low_level_observations=WALKING_ENV_CFG.observations.policy,
rolling_low_level_actions=ROLLING_ENV_CFG.actions.joint_pos,
rolling_low_level_observations=WALKING_ENV_CFG.observations.policy,
@configclass
class ObservationsCfg:
"""Observation specifications for the MDP."""
@configclass
class PolicyCfg(ObsGroup):
"""Observations for policy group."""
# observation terms (order preserved)
base_lin_vel = ObsTerm(func=mdp.base_lin_vel)
projected_gravity = ObsTerm(func=mdp.projected_gravity)
pose_command = ObsTerm(func=mdp.generated_commands, params={"command_name": "pose_command"})
# observation groups
policy: PolicyCfg = PolicyCfg()
@configclass
class RewardsCfg:
"""Reward terms for the MDP."""
termination_penalty = RewTerm(func=mdp.is_terminated, weight=-400.0)
position_tracking = RewTerm(
func=mdp.position_command_error_tanh,
weight=0.5,
params={"std": 2.0, "command_name": "pose_command"},
position_tracking_fine_grained = RewTerm(
weight=0.5,
params={"std": 0.2, "command_name": "pose_command"},
orientation_tracking = RewTerm(
func=mdp.heading_command_error_abs,
weight=-0.2,
params={"command_name": "pose_command"},
@configclass
class CommandsCfg:
"""Command terms for the MDP."""
pose_command = mdp.UniformPose2dCommandCfg(
asset_name="robot",
simple_heading=False,
resampling_time_range=(8.0, 8.0),
debug_vis=False,
ranges=mdp.UniformPose2dCommandCfg.Ranges(pos_x=(-3.0, 3.0), pos_y=(-3.0, 3.0), heading=(-math.pi, math.pi)),
#pose_command = mdp.NullCommandCfg()
#print(f"num_envs: {ManagerTermBase.num_envs}")
@configclass
class TerminationsCfg:
"""Termination terms for the MDP."""
time_out = DoneTerm(func=mdp.time_out, time_out=True)
base_contact = DoneTerm(
func=mdp.illegal_contact,
params={"sensor_cfg": SceneEntityCfg("contact_forces", body_names="MainBody"), "threshold": 1.0},
@configclass
#class NavigationEnvCfg(ManagerBasedRLEnvCfg):
class SelectorEnvCfg(ManagerBasedRLEnvCfg):
"""Configuration for the navigation environment."""
# environment settings
#scene: SceneEntityCfg = LOW_LEVEL_ENV_CFG.scene
scene: SceneEntityCfg = WALKING_ENV_CFG.scene
actions: ActionsCfg = ActionsCfg()
observations: ObservationsCfg = ObservationsCfg()
events: EventCfg = EventCfg()
# mdp settings
commands: CommandsCfg = CommandsCfg()
rewards: RewardsCfg = RewardsCfg()
terminations: TerminationsCfg = TerminationsCfg()
def __post_init__(self):
"""Post initialization."""
#self.sim.dt = LOW_LEVEL_ENV_CFG.sim.dt
#self.sim.render_interval = LOW_LEVEL_ENV_CFG.decimation
#self.decimation = LOW_LEVEL_ENV_CFG.decimation * 10
self.sim.dt = WALKING_ENV_CFG.sim.dt
self.sim.render_interval = WALKING_ENV_CFG.decimation
self.decimation = WALKING_ENV_CFG.decimation * 10
self.episode_length_s = self.commands.pose_command.resampling_time_range[1]
if self.scene.height_scanner is not None:
self.scene.height_scanner.update_period = (
self.actions.pre_trained_policy_action.low_level_decimation * self.sim.dt
if self.scene.contact_forces is not None:
self.scene.contact_forces.update_period = self.sim.dt
#class NavigationEnvCfg_PLAY(NavigationEnvCfg):
class SelectorEnvCfg_PLAY(SelectorEnvCfg):
def __post_init__(self) -> None:
# post init of parent
super().__post_init__()
# make a smaller scene for play
self.scene.num_envs = 16
self.scene.env_spacing = 2.5
# disable randomization for play
self.observations.policy.enable_corruption = False
Isaac Sim Version
4.2.0
4.1.0
4.0.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Isaac Lab Version (if applicable)
1.2
1.1
1.0
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model: RTX A4000
- Driver Version:
