Dear All
I want to do Dynamic Parallelism in a K40. I have the bellow code. This code gives two times the following message:
Error: a pointer to local memory cannot be stored into the parameter buffer, obtained at…/mix.cu(1649)
The error gives in line 25 in the bellow code.
Does anyone know How I have to proceed to not allocate “FR” and “coef” in the main GPU memory?
Because if I allocate FR and coef in the main GPU memory the performance degrades very much.
Luis Gonçalves
__global__ void process1(int nusersvirt, int iter,float *real_codigo,float *imag_codigo,complex1 *out1,
float *fft_in_real,float *fft_in_imag,int nredund,float *eqin, int varu,int baixo,int cima)
int banda1=threadIdx.x+blockIdx.x*blockDim.x;
int brwidth=blockDim.x*gridDim.x;
int i,form1,INFO=0,i1;
float d1,d2,d3,d4;
complex1 m1, m2,m5,m6;
complex1 a[171];
complex1 RO[18];
int form,z,z1,banda4,banda5;
int banda3,ind2;
int shift=0;
int index1;
complex1 FR[(MAXUSERS-1)*MAXREDUND];
float coef[MAXREDUND];
banda3=nredund*(nusersvirt-1);
fr1<<<banda3/32+(((banda3 % 32)==0) ? 0:1),32>>>(FR,coef,eqin,real_codigo, imag_codigo, varu, baixo, cima, nusersvirt,iter,banda1,SYMB);
