Description
I want to use the local TensorRT8 in my C project.
I’am trying to install the TensorRT8.4 into my local Ubuntu18.04 machine (not the docker env).
The CUDA11.4 and cuDNN8.2 were installed by using the local run/tgz file, so I had to install the TensorRT by “tgz file”.
I’ve downloaded the “tar file” and unzipped.
Nextly, added the LD_LIBRARY_PATH to ~/.bashrc file below and updated it(source ~/.bashrc)
export LD_LIBRARY_PATH=/home/han/TensorRT-8.2.1.8/lib:$LD_LIBRARY_PATH
But the thing is that,
the example_mnist runs well, but including the tensorrt header “NvInfer.h” is occurring the “No such file or directory” error when my C project compilation.
(I’ve checked LD_LIBRARY_PATH is correctly added by typing “echo $LD_LIBRARY_PATH” in the ubuntu terminal)
How can I fix the problem??
Even I included the header by "#include “correct/path/to/NvInfer.h” but occurs the another including path problem in “NvInfer.h” file.
Please help me guys :)
Environment
TensorRT Version: 8.4
GPU Type: Quadro RTX4000
Nvidia Driver Version: 470.94
CUDA Version: 11.4
CUDNN Version: 8.2
Operating System + Version: Ubuntu 18.04 LTS
Python Version (if applicable): python3
TensorFlow Version (if applicable): x
PyTorch Version (if applicable): x
Baremetal or Container (if container which image + tag): x
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
