Hi I want to ping test about “PC -> target”, but I don’t konw what something is wrong.
The current situation is below.
ping : PC -> Target(localhost) (X)
ping : Target(localhost) -> Target(localhost) (O)
ping : Target(localhost) -> PC (X)
arping : Target(localhost) -> Target(localhost) (X)
arping : Target(localhost) -> PC (O)
As I checked tcpdump log, it appears as below, but I don’t know where to correct it.
connect: Network is unreachable
14:04:16.334495 IP localhost > localhost: ICMP localhost udp port domain unreachable, length 82
As can be seen in the target service list, ipables has already been turned off.
root# service list
Found 26 services:
0 display: [android.hardware.display.IDisplayManager]
1 recovery: [android.os.IRecoverySystem]
2 power: [android.os.IPowerManager]
3 appops: [com.android.internal.app.IAppOpsService]
4 batterystats: [com.android.internal.app.IBatteryStats]
5 device_identifiers: [android.os.IDeviceIdentifiersPolicyService]
6 wificond: [android.net.wifi.IWificond]
7 media.extractor.update: [android.media.IMediaExtractorUpdateService]
8 media.extractor: [android.media.IMediaExtractorService]
9 storaged_pri: [android.os.storaged.IStoragedPrivate]
10 storaged: [android.os.IStoraged]
11 media.resource_manager: [android.media.IResourceManagerService]
12 media.player: [android.media.IMediaPlayerService]
13 stats: [android.os.IStatsManager]
14 android.security.keystore: [android.security.IKeystoreService]
15 media.metrics: [android.media.IMediaAnalyticsService]
16 media.audio_flinger: [android.media.IAudioFlinger]
17 android.service.gatekeeper.IGateKeeperService: [android.service.gatekeeper.IGateKeeperService]
18 perfprofd: [android.os.IPerfProfd]
19 drm.drmManager: [drm.IDrmManagerService]
20 media.drm: [android.media.IMediaDrmService]
21 incident: [android.os.IIncidentManager]
22 installd: [android.os.IInstalld]
23 thermalservice: [android.os.IThermalService]
24 netd: [android.net.INetd]
25 vold: [android.os.IVold]
And I tried all valuesof /proc/sys/net/netfilter have been modified to be ACCEPT.
Please let me know advice or idea.
Detail log is below.
Thank you for reading.
PC ipconfig value is below.
Ethernet adaptor 2:
C:\Users\administer>ipconfig
DNS . . . . :
IPv4 address . . . . . . . . . : 192.168.200.200
subnet mask . . . . . . . : 255.255.255.0
default gateway . . . . . . :
uname -a
Linux localhost 4.14.56 #104 SMP PREEMPT Fri Nov 27 09:08:07 KST 2020 aarch64
ip addr show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: ip_vti0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1000
link/ipip 0.0.0.0 brd 0.0.0.0
3: ip6_vti0@NONE: <NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/tunnel6 :: brd ::
4: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1000
link/sit 0.0.0.0 brd 0.0.0.0
5: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default qlen 1000
6: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 98:20:8f:5e:84:3a brd ff:ff:ff:ff:ff:ff
inet 192.168.200.201/24 brd 192.168.200.255 scope global eth0
inet6 fe80::9a20:8fff:fe5e:843a/64 scope link
# ifconfig
eth0 Link encap:Ethernet HWaddr 98:20:8f:5e:84:3a Driver r8168
inet addr:192.168.200.201 Bcast:192.168.200.255 Mask:255.255.255.0
inet6 addr: fe80::9a20:8fff:fe5e:843a/64 Scope: Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:156 errors:0 dropped:0 overruns:0 frame:0
TX packets:22 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:12306 TX bytes:1356
Interrupt:72 Base address:0xd000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope: Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:752 errors:0 dropped:0 overruns:0 frame:0
TX packets:752 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2850160 TX bytes:2850160
tcpdump -i any & ping 192.168.200.200 ( Target -> PC )
tcpdump -i any & ping 192.168.200.201 (Target -> Target)
PING 192.168.200.201 (192.168.200.201) 56(84) bytes of data.
64 bytes from 192.168.200.201: icmp_seq=1 ttl=64 time=0.403 ms
14:04:13.925516 IP 192.168.200.201 > 192.168.200.201: ICMP echo request, id 1, seq 1, length 64
14:04:13.925647 IP 192.168.200.201 > 192.168.200.201: ICMP echo reply, id 1, seq 1, length 64
14:04:13.932064 IP localhost.39755 > localhost.domain: 49518+ PTR? 201.200.168.192.in-addr.arpa. (46)
14:04:13.932185 IP localhost > localhost: ICMP localhost udp port domain unreachable, length 82
14:04:14.938479 IP 192.168.200.201 > 192.168.200.201: ICMP echo request, id 1, seq 2, length 64
64 bytes from 192.168.200.201: icmp_seq=2 ttl=64 time=0.967 ms
14:04:14.938987 IP 192.168.200.201 > 192.168.200.201: ICMP echo reply, id 1, seq 2, length 64
14:04:15.940267 IP 192.168.200.201 > 192.168.200.201: ICMP echo request, id 1, seq 3, length 64
14:04:15.940641 IP 192.168.200.201 > 192.168.200.201: ICMP echo reply, id 1, seq 3, length 64
64 bytes from 192.168.200.201: icmp_seq=3 ttl=64 time=0.826 ms
14:04:16.328060 IP 192.168.200.200.netbios-ns > 192.168.200.255.netbios-ns: NBT UDP PACKET(137): QUERY; REQUEST; BROADCAST
14:04:16.329222 IP 192.168.200.200.54182 > 224.0.0.252.hostmon: UDP, length 22
14:04:16.329515 IP 192.168.200.200.61425 > 224.0.0.252.hostmon: UDP, length 22
14:04:16.334358 IP localhost.58416 > localhost.domain: 56320+ PTR? 200.200.168.192.in-addr.arpa. (46)
14:04:16.739947 IP 192.168.200.200.61425 > 224.0.0.252.hostmon: UDP, length 22
14:04:16.740183 IP 192.168.200.200.54182 > 224.0.0.252.hostmon: UDP, length 22
14:04:16.942388 IP 192.168.200.201 > 192.168.200.201: ICMP echo request, id 1, seq 4, length 64
14:04:16.942756 IP 192.168.200.201 > 192.168.200.201: ICMP echo reply, id 1, seq 4, length 64
64 bytes from 192.168.200.201: icmp_seq=4 ttl=64 time=0.805 ms
14:04:17.078507 IP 192.168.200.200.netbios-ns > 192.168.200.255.netbios-ns: NBT UDP PACKET(137): QUERY; REQUEST; BROADCAST
--- 192.168.200.201 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3016ms
rtt min/avg/max/mdev = 0.403/0.750/0.967/0.210 ms
14:04:17.829226 IP 192.168.200.200.netbios-ns > 192.168.200.255.netbios-ns: NBT UDP PACKET(137): QUERY; REQUEST; BROADCAST
tcpdump -i any & arping 192.168.200.201 (Target->Target)
WARNING: using default broadcast address.
ARPING 192.168.200.201 from 192.168.200.201 eth0
14:04:23.919526 ARP, Request who-has 192.168.200.201 (Broadcast) tell 192.168.200.201, length 28
14:04:24.920390 ARP, Request who-has 192.168.200.201 (Broadcast) tell 192.168.200.201, length 28
14:04:25.921618 ARP, Request who-has 192.168.200.201 (Broadcast) tell 192.168.200.201, length 28
14:04:26.922615 ARP, Request who-has 192.168.200.201 (Broadcast) tell 192.168.200.201, length 28
Sent 4 probes (4 broadcast(s))
Received 0 response(s)
tcpdump -i any & arping 192.168.200.200(Target->PC)
ARPING 192.168.200.200 from 192.168.200.201 eth0
14:04:30.177403 ARP, Request who-has 192.168.200.200 (Broadcast) tell 192.168.200.201, length 28
14:04:30.178734 ARP, Reply 192.168.200.200 is-at 00:e0:4c:36:13:64 (oui Unknown), length 46
Unicast reply from 192.168.200.200 [00:E0:4C:36:13:64] 2.161ms
14:04:31.178063 ARP, Request who-has 192.168.200.200 (00:e0:4c:36:13:64 (oui Unknown)) tell 192.168.200.201, length 28
14:04:31.179186 ARP, Reply 192.168.200.200 is-at 00:e0:4c:36:13:64 (oui Unknown), length 46
Unicast reply from 192.168.200.200 [00:E0:4C:36:13:64] 2.881ms
14:04:32.178984 ARP, Request who-has 192.168.200.200 (00:e0:4c:36:13:64 (oui Unknown)) tell 192.168.200.201, length 28
14:04:32.179989 ARP, Reply 192.168.200.200 is-at 00:e0:4c:36:13:64 (oui Unknown), length 46
Unicast reply from 192.168.200.200 [00:E0:4C:36:13:64] 2.808ms
14:04:33.179939 ARP, Request who-has 192.168.200.200 (00:e0:4c:36:13:64 (oui Unknown)) tell 192.168.200.201, length 28
14:04:33.181041 ARP, Reply 192.168.200.200 is-at 00:e0:4c:36:13:64 (oui Unknown), length 46
Unicast reply from 192.168.200.200 [00:E0:4C:36:13:64] 3.155ms
Sent 4 probes (1 broadcast(s))
Received 4 response(s)
14:04:37.210015 IP 192.168.200.200 > 192.168.200.201: ICMP echo request, id 1, seq 56, length 40
14:04:42.021530 ARP, Request who-has 192.168.200.201 (98:20:8f:5e:84:3a (oui Unknown)) tell 192.168.200.200, length 46
14:04:42.021896 ARP, Reply 192.168.200.201 is-at 98:20:8f:5e:84:3a (oui Unknown), length 28
14:04:42.026636 IP 192.168.200.200 > 192.168.200.201: ICMP echo request, id 1, seq 57, length 40
14:04:47.025793 IP 192.168.200.200 > 192.168.200.201: ICMP echo request, id 1, seq 58, length 40
14:04:52.025172 IP 192.168.200.200 > 192.168.200.201: ICMP echo request, id 1, seq 59, length 40
14:04:55.673862 IP6 fe80::9a20:8fff:fe5e:843a > ff02::2: ICMP6, router solicitation, length 16
14:04:55.680413 IP localhost.48891 > localhost.domain: 59458+ PTR? 2.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.2.0.f.f.ip6.arpa. (90)
14:04:55.680570 IP localhost > localhost: ICMP localhost udp port domain unreachable, length 126
14:04:55.681140 IP localhost.62416 > localhost.domain: 59458+ PTR? 2.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.2.0.f.f.ip6.arpa. (90)
