• Tesla T4 • DeepStream 6.1 • TensorRT 8.2.5.1
**• NVIDIA GPU Driver Version 510.47.03 ** • Find source files
I am right now using sample deepstream-app. And I am using config files. I have printed the delay measurement for my basic-sample pipeline. There are 5 components:
src_bin_muxer;
primary_gie;
tiled_display_tiler;
osd_conv;
nvosd0.
If possible, I would like to know the source code of each component above. I know that primary_gie and nvosd0 are at:
/opt/nvidia/deepstream/deepstream-6.1/sources/gst-plugins/(gst-nvinfer and gst-nvdsosd).
I tried to search for others by searching for “nvds_set_input_system_timestamp” function. But I couldn’t find them. Or I might have missed them. I am asking for my own research. I just would like to conduct some tests.
Thank you in advance.
I know that .so files are at “/opt/nvidia/deepstream/deepstream-6.1/lib/gst-plugins”, but I wanted to look at source files. Thank you in advance
you can find that source code in opt\nvidia\deepstream\deepstream-6.1\sources\apps\apps-common\src, for example: create_multi_source_bin, create_common_elements, create_tiled_display_bin, create_osd_bin
As you see, it is showing in and out timestamps for different components:
src_bin_muxer;
primary_gie;
osd_conv;
nvosd0.
After going through documentations, I found that NvDsMeta API captures timestamps using functions: nvds_set_input_system_timestamp and nvds_set_output_system_timestamp.
So I wanted to find in which source code/files those functions are capturing timestamps for those components above.
I found for primary_gie (it was at gst-nvinfer at gst-plugins).
I might have been confused about something, I would appreciate if you would clarify If I am wrong.
Yes, I understood that part. What I wanted to know is: In which files you are using those functions to calculate the latency for each component?
Meaning, in which file you are saving (calling nvds_set_input_system_timestamp/nvds_set_output_system_timestamp) start and end timestamps for src_bin_muxer? or for osd_conv?
I went through the files in “opt\nvidia\deepstream\deepstream-6.1\sources\apps\apps-common\src”, but none of those files are capturing the time to calculate the latency.
As you can see it is saving start time for element “nvinfer” which is “primary_gie” from the latency measured component.
So, I just wanted to know: where are the start times for the other components?
In which file start time was saved for “src_bin_muxer”/“tiled_display_tiler”/“osd_conv”?
sorry for the late response, src_bin_muxer will nvstreammux plugin, tiled_display_tiler will use nvtiler plugin, osd_conv will use nvvideoconvert plugin, these plugins are not opensource, so you did not see nvds_set_input_system_timestamp.
