While running a “debug” kernel, we get below INFO message from LOCKDEP. A “debug” kernel has some kernel’s debug features turned on; e.g. CONFIG_DEBUG_KERNEL, CONFIG_PROVE_LOCKING, CONFIG_LOCKDEP, CONFIG_DEBUG_LOCK_ALLOC, etc.
[ 19.135692] INFO: trying to register non-static key.
[ 19.135705] the code is fine but needs lockdep annotation.
[ 19.135715] turning off the locking correctness validator.
[ 19.135734] CPU: 0 PID: 971 Comm: kworker/0:1 Tainted: G W 4.9.140-rt94-r32.4.3-tegra-RedHawk-7.5.3-r600-nvhost-acm-non-sta #10
[ 19.135744] Hardware name: NVIDIA Jetson Xavier NX Developer Kit (DT)
[ 19.135776] Workqueue: pm pm_runtime_work
[ 19.135790] Call trace:
[ 19.135826] [<ffffff800808bfd0>] dump_backtrace+0x0/0x1b0
[ 19.135865] [<ffffff800808c2bc>] show_stack+0x24/0x30
[ 19.135890] [<ffffff80084bffc0>] dump_stack+0x88/0xb0
[ 19.135901] [<ffffff8008147474>] register_lock_class+0x394/0x5f0
[ 19.135911] [<ffffff80081486ac>] __lock_acquire.isra.12+0x6c/0xa10
[ 19.135920] [<ffffff800814949c>] lock_acquire+0xf4/0x238
[ 19.135930] [<ffffff80080fac44>] flush_work+0x44/0x2a0
[ 19.135939] [<ffffff80080fc720>] __cancel_work_timer+0xa0/0x188
[ 19.135948] [<ffffff80080fc85c>] cancel_delayed_work_sync+0x24/0x30
[ 19.135960] [<ffffff8008e67700>] devfreq_monitor_suspend+0x50/0x80
[ 19.135969] [<ffffff8008e6cf88>] devfreq_watermark_event_handler+0x408/0x4b0
[ 19.135978] [<ffffff8008e6767c>] devfreq_suspend_device+0x64/0x98
[ 19.135990] [<ffffff80085958d4>] nvhost_module_runtime_suspend+0x10c/0x1a8
[ 19.136000] [<ffffff8008921e14>] pm_generic_runtime_suspend+0x3c/0x58
[ 19.136010] [<ffffff8008934000>] genpd_runtime_suspend+0x98/0x238
[ 19.136023] [<ffffff8008924454>] __rpm_callback+0x74/0xa0
[ 19.136027] [<ffffff80089244b4>] rpm_callback+0x34/0x98
[ 19.136032] [<ffffff8008924b20>] rpm_suspend+0x100/0x608
[ 19.136037] [<ffffff8008926730>] pm_runtime_work+0x80/0xb8
[ 19.136042] [<ffffff80080fb56c>] process_one_work+0x2cc/0x710
[ 19.136047] [<ffffff80080fba0c>] worker_thread+0x5c/0x480
[ 19.136052] [<ffffff8008102ca4>] kthread+0xf4/0xf8
[ 19.136057] [<ffffff8008083320>] ret_from_fork+0x10/0x30
I am still debugging this, but initial observation is that the devfreq_suspend_device()
in nvhost_module_prepare_poweroff()
tries to flush_work()
which is not present, OR is not initialized with INIT_DELAYED_WORK()
I also noticed that the devfreq_resume_device()
in the file
nvidia/drivers/video/tegra/host/nvhost_acm.c
, calls the devfreq_watermark_event_handler()
. This, in turn calls devfreq_monitor_resume()
which queues a delayed work, through queue_delayed_work()
. This may be enough to make LOCKDEP happy as this queuing of work may, at some later point initialize a key. Or I may be wrong here and there needs to be an explicit call to INIT_DELAYED_WORK
I am not familiar with this device driver and the code path, and hence, don’t know how to fix/proceed. Please let me know the same.
Please note that this message is displayed on other Jetson devices too. I have seen it in R32.3.1 and R32.4.3. It may be present in previous releases but it is untested.
