After logging in, I keep going back to the login screen over and over again.
Which JetPack SW?
Any log as reference?
Can you refalsh your devcie to see if can back to normal?
JetPack 6.2
Could you please tell me how I can get the logs?
Do you mean to flash and reinstall jetpack?
If the device cannot be flashed/booted, please refer to the page to get uart log from the device:
Jetson/General debug - eLinux.org
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs:
Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
