Logarithmic fold operation behaving strangely
I’ve got some code I wrote, the goal being to fold a block of complex samples down into max, max index, sum and sum-of-moduli for some signal processing work I’m doing. My problem is that while testing I’m noticing some strange behavior. If I feed the kernel all (1.0, 0.0) samples, then it sums and produces the value one would expect. But, I can put a ramp into the buffer (buffer[ii] = ii) and the result is no longer correct. I’ve pored over the code and it looks correct to me, but I thought perhaps someone would see something I’ve missed or be able to point out some nuance of the CUDA runtime that I’m missing. I’m running CUDA 3.1 on a 8800GTS.
[codebox]#include <time.h>
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <cuda.h>
#include <cutil.h>
typedef struct cfloat_t {
float re;
float im;
} cfloat_t;
#define NUM_BLOCKS 256
#define THR_PER_BLK 128
global void fold_kernel(cfloat_t *data,
						float	*d_max, uint32_t *d_idx,
						cfloat_t *d_sum, float	*d_abs) {
__shared__ float	max_buff[THR_PER_BLK/2];
__shared__ uint32_t idx_buff[THR_PER_BLK/2];
__shared__ cfloat_t sum_buff[THR_PER_BLK/2];
__shared__ float	abs_buff[THR_PER_BLK/2];
// Do first comparison out of global memory to cut shared memory usage in half
if (threadIdx.x < blockDim.x/2) {
	const uint32_t idx_lower = blockIdx.x * blockDim.x + threadIdx.x;
	const uint32_t idx_upper = idx_lower + (blockDim.x/2);
	cfloat_t val_1 = data[idx_lower];
	float	mag_1 = sqrt(val_1.re * val_1.re + val_1.im * val_1.im);
	cfloat_t val_2 = data[idx_upper];
	float	mag_2 = sqrt(val_2.re * val_2.re + val_2.im * val_2.im);
	// Do initial sum and sum-of-absolutes
	sum_buff[threadIdx.x].re = val_1.re + val_2.re;
	sum_buff[threadIdx.x].im = val_1.im + val_2.im;
	abs_buff[threadIdx.x]	= mag_1 + mag_2;
	if (mag_2 > mag_1) {
		max_buff[threadIdx.x] = mag_2;
		idx_buff[threadIdx.x] = idx_upper;
	} else {
		max_buff[threadIdx.x] = mag_1;
		idx_buff[threadIdx.x] = idx_lower;
__syncthreads();
// Reduce to single value per block.
for (size_t ii=(THR_PER_BLK >> 2); ii > 0; ii >>= 1) {
	const size_t half = ii;
	if (threadIdx.x < half) {
		const size_t idx_1 = threadIdx.x;
		const size_t idx_2 = threadIdx.x + half;
		// Fold sum and sum of absolutes
		sum_buff[idx_1].re += sum_buff[idx_2].re;
		sum_buff[idx_1].im += sum_buff[idx_2].im;
		abs_buff[idx_1]	+= abs_buff[idx_2];
		if (max_buff[idx_2] > max_buff[idx_1]) {
			max_buff[idx_1] = max_buff[idx_2];
			idx_buff[idx_1] = idx_buff[idx_2];
	__syncthreads();
if (threadIdx.x == 0) {
	d_max[blockIdx.x] = max_buff[0];
	d_idx[blockIdx.x] = idx_buff[0];
	d_sum[blockIdx.x] = sum_buff[0];
	d_abs[blockIdx.x] = abs_buff[0];
host void test_fold_kernel() {
const uint32_t BUFF_SIZE   = 32768;
const uint32_t NUM_ITER	= 1;
cfloat_t *h_array = (cfloat_t*)malloc(BUFF_SIZE*sizeof(cfloat_t));
cfloat_t *d_array; CUDA_SAFE_CALL(cudaMalloc((void**)&d_array, BUFF_SIZE*sizeof(cfloat_t)));
float	*h_max_arr = (float*)   malloc(NUM_BLOCKS*sizeof(float));
uint32_t *h_idx_arr = (uint32_t*)malloc(NUM_BLOCKS*sizeof(uint32_t));
cfloat_t *h_sum_arr = (cfloat_t*)malloc(NUM_BLOCKS*sizeof(cfloat_t));
float	*h_abs_arr = (float*)   malloc(NUM_BLOCKS*sizeof(float));
float	*d_max_arr; CUDA_SAFE_CALL(cudaMalloc((void**)&d_max_arr, NUM_BLOCKS*sizeof(float)));
uint32_t *d_idx_arr; CUDA_SAFE_CALL(cudaMalloc((void**)&d_idx_arr, NUM_BLOCKS*sizeof(uint32_t)));
cfloat_t *d_sum_arr; CUDA_SAFE_CALL(cudaMalloc((void**)&d_sum_arr, NUM_BLOCKS*sizeof(cfloat_t)));
float	*d_abs_arr; CUDA_SAFE_CALL(cudaMalloc((void**)&d_abs_arr, NUM_BLOCKS*sizeof(float)));
// < CHANGE HERE >
for (size_t ii=0; ii < BUFF_SIZE; ii++) {
	h_array[ii].re = 1.0; //(float)ii;
	h_array[ii].im = 0.0;
for (size_t iter = 0; iter < NUM_ITER; iter++) {
	CUDA_SAFE_CALL(
	  cudaMemcpy(d_array, h_array, BUFF_SIZE*sizeof(cfloat_t), cudaMemcpyHostToDevice));
	fold_kernel<<<NUM_BLOCKS, THR_PER_BLK>>>(d_array, d_max_arr, d_idx_arr, d_sum_arr, d_abs_arr);
	// Copy results back
	CUDA_SAFE_CALL(cudaMemcpy(h_max_arr, d_max_arr, NUM_BLOCKS*sizeof(float),	cudaMemcpyDeviceToHost));
	CUDA_SAFE_CALL(cudaMemcpy(h_idx_arr, d_idx_arr, NUM_BLOCKS*sizeof(uint32_t), cudaMemcpyDeviceToHost));
	CUDA_SAFE_CALL(cudaMemcpy(h_sum_arr, d_sum_arr, NUM_BLOCKS*sizeof(cfloat_t), cudaMemcpyDeviceToHost));
	CUDA_SAFE_CALL(cudaMemcpy(h_abs_arr, d_abs_arr, NUM_BLOCKS*sizeof(float),	cudaMemcpyDeviceToHost));
	printf("Sums: \n");
	for (size_t ii=0; ii < NUM_BLOCKS; ii++) {
		printf(" %i -> (%f, %f)\n", ii, h_sum_arr[ii].re, h_sum_arr[ii].im);
	float	max	 = 0.0;
	uint32_t max_idx = 0;
	cfloat_t sum; sum.re = 0.0; sum.im = 0.0;
	float	abs	 = 0.0;
		if (h_max_arr[ii] > max) {
			max	 = h_max_arr[ii];
			max_idx = h_idx_arr[ii];
		sum.re += h_sum_arr[ii].re;
		sum.im += h_sum_arr[ii].im;
		abs	+= h_abs_arr[ii];
	printf("Sum: (%f, %f), Abs: %f  Max: %f  Idx: %u\n",
		   sum.re, sum.im, abs, max, max_idx);
int main() {
test_fold_kernel();
return 0;
}[/codebox]
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <cuda.h>
#include <cutil.h>
float re;
float im;
} cfloat_t;
	} else {
__syncthreads();
	__syncthreads();
// < CHANGE HERE >
	CUDA_SAFE_CALL(
	printf("Sums: \n");
	float	max	 = 0.0;
	float	abs	 = 0.0;
int main() {
test_fold_kernel();
return 0;
}[/codebox]
