Logic level of the CAMx_PWDN on Jetson Orin Nano Devkit
Dear Nvidia Jetson HW Experts,
I would like to confirm the voltage level of the CAMx_PWDN pins from the J20 and J21 connectors of the Jetson Orin Nano Devkit:
In the Jetson_Orin_Nano_DevKit_Carrier_Board_Specification_SP-11324-001_v1.1.pdf, the type of CAMx_PWDN is 1.8V :
However, in the Jetson_Orin_Nano_DevKit_Carrier_Board_Reference_Design_Files_A04_20230320/P3768_A04_OrCAD_schematics(base_version).pdf, they are routed to the J20, J21 connectors via the SN74LV1T125 which seems to give 3.3V output (CAMx_PWDN_LS) as its VCC is connected to 3.3V :
Could you confirm if CAMx_PWDN_LS is 1.8V or 3.3V, please ?
Thanks in advance and best regards,
Khang
CAMx_PWDN_LS is 3.3V.
Hi @Trumany,
So, pin #6 of J20 and J21 must be Output, 3.3V. Do you confirm?
Best Regards,
Khang
The “Output, 1.8V” in the table is for module pin 114/120 type description. For pin 6 of J20 and J21, it is “Input, 3.3V”.
Hi @Trumany,
I am confused why it is “Input”.
CAMx_PWDN_LS is input to J20/J21.
