Hey Dear, i am trying to use logitech c170 camera to access the image, i am getting fail to capture frame and failed to convert from NV12 to RGBA error. Could you please help me to resolve this issue.
hello sagar.jadhav,
could you please share your commands to access Logitech C170.
please also share the messages about the failure.
thanks
Hi, thanks for the reply.
I am using the jetson-inference repo and running ./imagnet-camera example. Here I modified the default camera setting to zero, #define DEFAULT_CAMERA 0 in imagenet-camera.cpp file.
Console message:
./imagenet-camera
imagenet-camera
args (1): 0 [./imagenet-camera]
[gstreamer] initialized gstreamer, version 1.14.1.0
[gstreamer] gstCamera attempting to initialize with GST_SOURCE_NVCAMERA
[gstreamer] gstCamera pipeline string:
v4l2src device=/dev/video0 ! video/x-raw, width=(int)1280, height=(int)720, format=YUY2 ! videoconvert ! video/x-raw, format=RGB ! videoconvert !appsink name=mysink
[gstreamer] gstCamera successfully initialized with GST_SOURCE_V4L2
imagenet-camera: successfully initialized video device
width: 1280
height: 720
depth: 24 (bpp)
imageNet – loading classification network model from:
– prototxt networks/googlenet.prototxt
– model networks/bvlc_googlenet.caffemodel
– class_labels networks/ilsvrc12_synset_words.txt
– input_blob ‘data’
– output_blob ‘prob’
– batch_size 2
[TRT] TensorRT version 5.0.6
[TRT] detected model format - caffe (extension ‘.caffemodel’)
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file networks/bvlc_googlenet.caffemodel.2.1.GPU.FP16.engine
[TRT] loading network profile from engine cache… networks/bvlc_googlenet.caffemodel.2.1.GPU.FP16.engine
[TRT] device GPU, networks/bvlc_googlenet.caffemodel loaded
[TRT] device GPU, CUDA engine context initialized with 2 bindings
[TRT] binding – index 0
– name ‘data’
– type FP32
– in/out INPUT
– # dims 3
– dim #0 3 (CHANNEL)
– dim #1 224 (SPATIAL)
– dim #2 224 (SPATIAL)
[TRT] binding – index 1
– name ‘prob’
– type FP32
– in/out OUTPUT
– # dims 3
– dim #0 1000 (CHANNEL)
– dim #1 1 (SPATIAL)
– dim #2 1 (SPATIAL)
[TRT] binding to input 0 data binding index: 0
[TRT] binding to input 0 data dims (b=2 c=3 h=224 w=224) size=1204224
[cuda] cudaAllocMapped 1204224 bytes, CPU 0x100e30000 GPU 0x100e30000
[TRT] binding to output 0 prob binding index: 1
[TRT] binding to output 0 prob dims (b=2 c=1000 h=1 w=1) size=8000
[cuda] cudaAllocMapped 8000 bytes, CPU 0x100f60000 GPU 0x100f60000
device GPU, networks/bvlc_googlenet.caffemodel initialized.
[TRT] networks/bvlc_googlenet.caffemodel loaded
imageNet – loaded 1000 class info entries
default X screen 0: 1280 x 1024
[OpenGL] glDisplay display window initialized
[OpenGL] creating 1280x720 texture
loaded image fontmapA.png (256 x 512) 2097152 bytes
[cuda] cudaAllocMapped 2097152 bytes, CPU 0x101060000 GPU 0x101060000
[cuda] cudaAllocMapped 8192 bytes, CPU 0x100f62000 GPU 0x100f62000
[gstreamer] gstreamer transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> videoconvert1
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> videoconvert0
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> v4l2src0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> videoconvert1
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from READY to PAUSED ==> videoconvert0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> v4l2src0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer msg new-clock ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> videoconvert1
[gstreamer] gstreamer msg stream-start ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> videoconvert0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> v4l2src0
[gstreamer] gstCamera onEOS
[gstreamer] gstreamer v4l2src0 ERROR Internal data stream error.
[gstreamer] gstreamer Debugging info: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
imagenet-camera: camera open for streaming
imagenet-camera: failed to capture frame
imagenet-camera: failed to convert from NV12 to RGBA
[TRT] imageNet::Classify( 0x(nil), 1280, 720 ) -> invalid parameters
[cuda] cudaNormalizeRGBA((float4*)imgRGBA, make_float2(0.0f, 255.0f), (float4*)imgRGBA, make_float2(0.0f, 1.0f), camera->GetWidth(), camera->GetHeight())
[cuda] invalid device pointer (error 17) (hex 0x11)
[cuda] /home/nvidia-1/jetson-inference/imagenet-camera/imagenet-camera.cpp:193
[cuda] registered 14745600 byte openGL texture for interop access (1280x720)
Also, I have one more query:
Is jetson nano support RPi Camera (F) (https://www.waveshare.com/rpi-camera-f.htm)?
Again thanks for reply.
hello sagar.jadhav,
- according to below,
please given all sensor capability in the gstreamer pipeline for your access commands, such as frame-rate.
for example,
you may also check sensor capability with below commands,
$ v4l2-ctl --list-formats-ext
- please refer to below for Jetson-Nano supported camera list.
https://github.com/NVIDIA-AI-IOT/jetbot/issues/29#issuecomment-481359800
Samething here… The official documents read that tests were executed with the Logitech C920. I have tried modified functions suggested in
https://devtalk.nvidia.com/default/topic/1045989/jetson-tx2/converting-from-yv12-to-rgba-within-jetson-inference/
but I did not see any good result.
Looking forward to read other options.
Hi A00354645,
Please file a new topic for your issue, we can re-investigate your question from there.
