I have a logitech c270.
When I check the v4l2 formats I get this
Index : 0
Type : Video Capture
Pixel Format: ‘RG10’
Name : 10-bit Bayer RGRG/GBGB
Size: Discrete 3264x2464
Interval: Discrete 0.048s (21.000 fps)
Size: Discrete 3264x1848
Interval: Discrete 0.036s (28.000 fps)
Size: Discrete 1920x1080
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.017s (60.000 fps)
I have tried various combinations of these settings, but I still get an error at imshow that my width and height are less than 0.
The camera does run when I
cam=cv2.VideoCapture(‘/dev/video1’)
it doesn’t run with
dispW=1280
dispH=720
camSet =‘v4l2src device=/dev/video1 ! video/x-raw,width=’+str(dispW)+‘,height=’+str(dispH)+‘,framerate=60/1 ! videoconvert ! appsink’
cam=cv2.VideoCapture(camSet)
What am I missing?
Thanks in advance.
Looks like it’s an bayer format. You may need bayer2rgb element to handle it.
I am not 100% sure if I did this correctly, but I added ! bayer2rgb at the end, and I still have the same issue.
Thanks for the advice!
I guess I should have mentioned that I had a piCam installed. I disconnected it and got completely different results when I checked the v4l2 formats
ioctl: VIDIOC_ENUM_FMT
Index : 0
Pixel Format: ‘YUYV’
Interval: Discrete 0.040s (25.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.200s (5.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Index : 1
Pixel Format: ‘MJPG’ (compressed)
Anyway, I changed the source from 1 to 0 as now
The camera launches with cam=cv2.VideoCapture(’/dev/video0’)
The other method still doesn’t work though. I tried supported resolutions and added format=MJPG.
I think you should verify the pipeline by the gst-launch-1.0 to make sure it’s worked the check the CV later.
Hey, I got it working. I made a syntax error. camSet = Instead of camSet=
I didn’t notice until a little while ago. Sorry for the trouble, and thanks for the help.
