Logitech MX Brio 4K Webcam Not Working with nvgstcapture-1.0 on Jetson Nano
Hi everyone,
I’m having trouble using my Logitech MX Brio 4K webcam on my Jetson Nano. I’ve connected the webcam and checked ls /dev/video*, which returns the following output:
(base) njetson001@njetson001:~$ ls /dev/video0
/dev/video0
However, when I try running nvgstcapture-1.0, I get the following error/timeout message:
I’ve tried different commands, including specifying --cap-dev-node=0 and adjusting resolution settings, but nothing seems to work. Does anyone know if there are specific drivers or configurations needed to get this webcam running with GStreamer on Jetson Nano?
This is output when using online webcam tester (https://webcamtests.com/), the camera is detected but cannot running properly
“Apparently, your webcam is being used or blocked by another application. To start your webcam, you must temporarily close that application.”
Any help would be greatly appreciated!
Webcam that i use Buy MX Brio UHD 4K Webcam | Logitech
Confirm by v4l2-ctl first then try the v4l2src. You should able to find the example for gst-launch-1.0 command line in forum topic.
v4l2-ctl --list-formats-ext
v4l2-ctl --stream-mmap
gst-launch-1.0 v4l2src ......
(base) njetson001@njetson001:~$ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
	Index       : 0
	Type        : Video Capture
	Pixel Format: 'YUYV'
			Interval: Discrete 0.033s (30.000 fps)
			Interval: Discrete 0.042s (24.000 fps)
			Interval: Discrete 0.050s (20.000 fps)
			Interval: Discrete 0.067s (15.000 fps)
			Interval: Discrete 0.100s (10.000 fps)
			Interval: Discrete 0.133s (7.500 fps)
			Interval: Discrete 0.200s (5.000 fps)
			Interval: Discrete 0.017s (60.000 fps)
	Index       : 1
	Pixel Format: 'MJPG' (compressed)
		Size: Discrete 1920x1080
	Index       : 2
	Pixel Format: 'NV12'
(base) njetson001@njetson001:~$ v4l2-ctl --stream-mmap
VIDIOC_REQBUFS: failed: Cannot allocate memory
(base) njetson001@njetson001:~$ gst-launch-1.0 v4l2src device=/dev/video0 ! xvimagesink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Device '/dev/video0' failed during initialization
Additional debug info:
gstv4l2object.c(3767): gst_v4l2_object_set_format_full (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Call to S_FMT failed for YUYV @ 800x600: Input/output error
Execution ended after 0:00:05.117744315
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
Try below command.
v4l2-ctl --set-fmt-video=width=640,height=480,pixelformat=YUYV --set-ctrl bypass_mode=0 --stream-mmap
(base) njetson001@njetson001:~$ v4l2-ctl --set-fmt-video=width=640,height=480,pixelformat=YUYV --set-ctrl bypass_mode=0 --stream-mmap
unknown control 'bypass_mode'
What’s wrong?
Remove the bypass_mode from the pipeline for USB camera.
v4l2-ctl --set-fmt-video=width=640,height=480,pixelformat=YUYV --stream-mmap
(base) njetson001@njetson001:~$ v4l2-ctl --set-fmt-video=width=640,height=480,pixelformat=YUYV --stream-mmap
VIDIOC_S_FMT: failed: Input/output error
still error, i think i’ve tried that command before
If v4l2-ctl can’t capture successfully that tell it could be sensor HW problem.
You may confirm on host PC to confirm it.
okay thank you
