这个就是我安装得系统版本,我没有找到g+±12
我很確定有
davey@dave-yu-nvidia-pc:~$ sudo docker run --privileged -it --rm ubuntu:jammy
root@b8f45425cebf:/# apt update
Get:1 http://security.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
Get:2 http://archive.ubuntu.com/ubuntu jammy InRelease [270 kB]
Get:3 http://security.ubuntu.com/ubuntu jammy-security/multiverse amd64 Packages [44.7 kB]
Get:4 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages [1083 kB]
Get:5 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [119 kB]
Get:6 http://security.ubuntu.com/ubuntu jammy-security/restricted amd64 Packages [2395 kB]
Get:7 http://security.ubuntu.com/ubuntu jammy-security/main amd64 Packages [1853 kB]
Get:8 http://archive.ubuntu.com/ubuntu jammy-backports InRelease [109 kB]
Get:9 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages [17.5 MB]
Get:10 http://archive.ubuntu.com/ubuntu jammy/restricted amd64 Packages [164 kB]
Get:11 http://archive.ubuntu.com/ubuntu jammy/main amd64 Packages [1792 kB]
Get:12 http://archive.ubuntu.com/ubuntu jammy/multiverse amd64 Packages [266 kB]
Get:13 http://archive.ubuntu.com/ubuntu jammy-updates/multiverse amd64 Packages [51.1 kB]
Get:14 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages [1375 kB]
Get:15 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages [2125 kB]
Get:16 http://archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 Packages [2468 kB]
Get:17 http://archive.ubuntu.com/ubuntu jammy-backports/universe amd64 Packages [31.9 kB]
Get:18 http://archive.ubuntu.com/ubuntu jammy-backports/main amd64 Packages [81.0 kB]
Fetched 31.8 MB in 16s (1954 kB/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
19 packages can be upgraded. Run 'apt list --upgradable' to see them.
root@b8f45425cebf:/# apt install g++-12
The following additional packages will be installed:
binutils binutils-common binutils-x86-64-linux-gnu cpp-12 fontconfig-config fonts-dejavu-core gcc-12 libasan8 libatomic1 libbinutils libbrotli1 libbsd0 libc-dev-bin libc-devtools libc6 libc6-dev libcc1-0 libcrypt-dev
libctf-nobfd0 libctf0 libdeflate0 libexpat1 libfontconfig1 libfreetype6 libgcc-12-dev libgd3 libgomp1 libisl23 libitm1 libjbig0 libjpeg-turbo8 libjpeg8 liblsan0 libmd0 libmpc3 libmpfr6 libnsl-dev libpng16-16 libquadmath0
libstdc++-12-dev libtiff5 libtirpc-dev libtsan2 libubsan1 libwebp7 libx11-6 libx11-data libxau6 libxcb1 libxdmcp6 libxpm4 linux-libc-dev manpages manpages-dev rpcsvc-proto ucf
Suggested packages:
binutils-doc gcc-12-locales cpp-12-doc g++-12-multilib gcc-12-doc gcc-12-multilib glibc-doc locales libgd-tools libstdc++-12-doc man-browser
Recommended packages:
libnss-nis libnss-nisplus
The following NEW packages will be installed:
binutils binutils-common binutils-x86-64-linux-gnu cpp-12 fontconfig-config fonts-dejavu-core g++-12 gcc-12 libasan8 libatomic1 libbinutils libbrotli1 libbsd0 libc-dev-bin libc-devtools libc6-dev libcc1-0 libcrypt-dev
The following packages will be upgraded:
libc6
1 upgraded, 56 newly installed, 0 to remove and 18 not upgraded.
Need to get 77.3 MB of archives.
After this operation, 264 MB of additional disk space will be used.
Do you want to continue? [Y/n]
是否是因为虚拟机的Ubuntu的系统还没支持?我重新下载一个新的系统看看
你先回答一下你有沒有跑過sudo apt update
已经是跑过了,在没有看到g+±12的时候我又重新跑了,也没有找到
我能不能用使用其他版本的系统,例如23.10?
能裝gcc12就可以…
你要不要現在再試一次docker到底跑不跑得起來
docker还是报错,请问您是否有安装好环境的虚拟机镜像?
你有任何一個docker image跑得起來的?
說實話我覺得連docker都不能用應該不是我們的問題
请问是否是有系统架构要求?我按照操作步骤bash执行的话后续执行还是没有反应
你先回答我這個問題就好
docker可以运行
只不过 edk2_docker是没有反应的
我現在才注意到
你在第一個terminal window設了alias 然後在第二個terminal window才執行…
這樣當然不會有用 除非你寫進bash的設定檔裡 否則所有環境變數都是離開現在的terminal環境就失效了
麻煩用同一個視窗操作
可是在同个窗口使用的话也是会报错
sudo apt install docker.io
sudo usermod -a -G docker ${USER}
# Log out, log back in
你有重新登入?
我使用虚拟机跑起来,看样子很顺利,请问生成的文件路径在哪里?我重新生成是否会替换?还是需要先删除之前的
在你的nvidia-uefi/images/uefi_Jetson_RELEASE.bin
複製進Linux_for_Tegra/bootloader/把檔名改回uefi_jetson.bin就好
