Long exposure time
Hi, I’m trying to implement long exposure time for IMX477 camera sensor i.e. higher than 1 second.
It requires setting of FPS lower than 1. I made changes in driver sources and while trying to obtain frame using below command:
gst-launch-1.0 -e \
        nvarguscamerasrc exposuretimerange="5000000000 	5000000000" ! \
        "video/x-raw(memory:NVMM),width=4032,height=3040,framerate=1/2" ! \
        nvjpegenc quality=100 ! \
        multifilesink location=./test.jpg
(framerate is set to 1/2) I’m getting the following output:
GST_ARGUS: NvArgusCameraSrc: Setting Exposure Time Range : 5000000000 5000000000
GST_ARGUS: !!! EXP RANGE: 5000000000,000000, 5000000000,000000
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 4032 x 3040 FR = 29,999999 fps Duration = 33333334 ; Analog Gain range min 1,000000, max 22,250000; Exposure Range min 11000, max 50000000000;
GST_ARGUS: 1920 x 1080 FR = 59,999999 fps Duration = 16666667 ; Analog Gain range min 1,000000, max 22,250000; Exposure Range min 11000, max 50000000000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 0
   Output Stream W = 4032 H = 3040
   seconds to Run    = 0
   Frame Rate = 29,999999
GST_ARGUS: !!! FR: 0,500000, DUR: 2000000000
GST_ARGUS: !!! EXP RANGE 2: 5000000000, 5000000000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD... Exiting...
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: CANCELLED
Additional debug info:
Argus Error Status
EOS on shutdown enabled -- waiting for EOS after Error
Waiting for EOS...
Caught SIGSEGV
#0  0x0000007f7c852e28 in __GI___poll (fds=0x55b6effda0, nfds=547551052344, timeout=<optimized out>) at ../sysdeps/unix/sysv/linux/poll.c:41
#1  0x0000007f7c95fe08 in  () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0
#2  0x00000055b6e662d0 in  ()
Spinning.  Please run 'gdb gst-launch-1.0 12489' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 266)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 368)
and dmesg messages:
[pon kwi 12 13:12:59 2021] misc tegra_camera_ctrl: tegra_camera_update_isobw: Warning, Requested ISO BW 1640625 has been capped to VI's max BW 1500000
[pon kwi 12 13:13:00 2021] misc tegra_camera_ctrl: ISO BW req 1655985 > 1500000 (max) capping to max
[pon kwi 12 13:13:00 2021] misc tegra_camera_ctrl: tegra_camera_update_isobw: Warning, Requested ISO BW 1640625 has been capped to VI's max BW 1500000
[pon kwi 12 13:13:01 2021] fence timeout on [ffffffc08b98a780] after 1500ms
[pon kwi 12 13:13:01 2021] fence timeout on [ffffffc08b98a900] after 1500ms
[pon kwi 12 13:13:01 2021] name=[nvhost_sync:17], current value=9 waiting value=10
[pon kwi 12 13:13:01 2021] name=[nvhost_sync:18], current value=9 waiting value=10
[pon kwi 12 13:13:01 2021] ---- mlocks ----
[pon kwi 12 13:13:01 2021] ---- syncpts ----
[pon kwi 12 13:13:01 2021] id 8 (gm20b_507) min 26228 max 26228 refs 1 (previous client : )
[pon kwi 12 13:13:01 2021] id 9 (gm20b_506) min 14 max 14 refs 1 (previous client : )
[pon kwi 12 13:13:01 2021] id 11 (gm20b_505) min 41124 max 41124 refs 1 (previous client : gm20b_505)
[pon kwi 12 13:13:01 2021] id 12 (54340000.vic_0) min 3 max 3 refs 1 (previous client : 54340000.vic_0)
[pon kwi 12 13:13:01 2021] id 17 (54680000.isp_0) min 9 max 12 refs 4 (previous client : 54680000.isp_0)
[pon kwi 12 13:13:01 2021] id 18 (54680000.isp_1) min 9 max 12 refs 4 (previous client : 54680000.isp_1)
[pon kwi 12 13:13:01 2021] id 19 (54680000.isp_2) min 46 max 54 refs 10 (previous client : 54680000.isp_2)
[pon kwi 12 13:13:01 2021] id 20 (54680000.isp_3) min 9 max 12 refs 4 (previous client : 54680000.isp_3)
[pon kwi 12 13:13:01 2021] id 21 (gm20b_504) min 1408 max 1408 refs 1 (previous client : gm20b_504)
[pon kwi 12 13:13:01 2021] id 22 (gm20b_503) min 96 max 96 refs 1 (previous client : gm20b_503)
[pon kwi 12 13:13:01 2021] id 23 (gm20b_502) min 4 max 4 refs 1 (previous client : gm20b_502)
[pon kwi 12 13:13:01 2021] id 24 (gm20b_501) min 4 max 4 refs 1 (previous client : gm20b_501)
[pon kwi 12 13:13:01 2021] id 25 (gm20b_500) min 12 max 12 refs 1 (previous client : gm20b_500)
[pon kwi 12 13:13:01 2021] id 29 (54080000.vi_1) min 9 max 12 refs 4 (previous client : 54080000.vi_1)
[pon kwi 12 13:13:01 2021] id 30 (54080000.vi_2) min 23 max 28 refs 7 (previous client : 54080000.vi_2)
[pon kwi 12 13:13:01 2021] id 33 (54080000.vi_4) min 9 max 12 refs 4 (previous client : 54080000.vi_4)
[pon kwi 12 13:13:01 2021] id 34 (54340000.vic_0) min 3 max 3 refs 1 (previous client : 54340000.vic_0)
[pon kwi 12 13:13:01 2021] id 35 (gm20b_494) min 6 max 6 refs 1 (previous client : 54340000.vic_0)
[pon kwi 12 13:13:01 2021] id 36 (54340000.vic_0) min 18 max 18 refs 1 (previous client : gm20b_499)
[pon kwi 12 13:13:01 2021] id 37 (gm20b_495) min 26 max 26 refs 1 (previous client : gm20b_498)
[pon kwi 12 13:13:01 2021] id 38 (gm20b_497) min 26 max 26 refs 1 (previous client : gm20b_497)
[pon kwi 12 13:13:01 2021] id 39 (gm20b_499) min 24 max 24 refs 1 (previous client : gm20b_496)
[pon kwi 12 13:13:01 2021] id 40 (gm20b_496) min 24 max 24 refs 1 (previous client : gm20b_495)
[pon kwi 12 13:13:01 2021] id 41 (gm20b_498) min 24 max 24 refs 1 (previous client : gm20b_494)
[pon kwi 12 13:13:01 2021] ---- channels ----
                           channel 0 - 54680000.isp
[pon kwi 12 13:13:01 2021] 0-54680000.isp (18):
[pon kwi 12 13:13:01 2021] active class 01, offset 0050, val 00000011
[pon kwi 12 13:13:01 2021] DMAPUT 00000630, DMAGET 000005a8, DMACTL 00000000
[pon kwi 12 13:13:01 2021] CBREAD 00000011, CBSTAT 00010050
                           ffffffc079f4f000: JOB, syncpt_id=17, syncpt_val=10, first_get=00000528, timeout=10000, num_slots=3, num_handles=1
[pon kwi 12 13:13:01 2021]     GATHER at ffe20000+4490, 8 words
[pon kwi 12 13:13:01 2021] 20000001
[pon kwi 12 13:13:01 2021] 00000411
[pon kwi 12 13:13:01 2021] 00000512
[pon kwi 12 13:13:01 2021] 00000614
[pon kwi 12 13:13:01 2021] 200c0001
[pon kwi 12 13:13:01 2021] 00000005
[pon kwi 12 13:13:01 2021]     GATHER at ffe20000+44b0, 2 words
[pon kwi 12 13:13:01 2021] 00000013
                           channel 1 - 54080000.vi
[pon kwi 12 13:13:01 2021] 1-54080000.vi (13):
[pon kwi 12 13:13:01 2021] active class 01, offset 0050, val 0000001d
[pon kwi 12 13:13:01 2021] DMAPUT 00000390, DMAGET 00000390, DMACTL 00000000
[pon kwi 12 13:13:01 2021] CBREAD 0000001d, CBSTAT 00010050
                           ffffffc079f4f800: JOB, syncpt_id=29, syncpt_val=10, first_get=000002a8, timeout=10000, num_slots=7, num_handles=1
[pon kwi 12 13:13:01 2021]     GATHER at ffd68000+0000, 35 words
[pon kwi 12 13:13:01 2021] 10620001
[pon kwi 12 13:13:01 2021] 0000001f
[pon kwi 12 13:13:01 2021] 10630002
[pon kwi 12 13:13:01 2021] 00000000
[pon kwi 12 13:13:01 2021] 103a0001
[pon kwi 12 13:13:01 2021] 10100010
[pon kwi 12 13:13:01 2021] 103c0001
[pon kwi 12 13:13:01 2021] 10101010
[pon kwi 12 13:13:01 2021] 10420001
[pon kwi 12 13:13:01 2021] 00000001
[pon kwi 12 13:13:01 2021] 10430006
[pon kwi 12 13:13:01 2021] 001c984c
[pon kwi 12 13:13:01 2021] unable to lock channel list
                           ---- host general irq ----
[pon kwi 12 13:13:01 2021] sync_hintmask_ext = 0xc0000000
[pon kwi 12 13:13:01 2021] sync_hintmask = 0x80000000
[pon kwi 12 13:13:01 2021] sync_intc0mask = 0x00000001
[pon kwi 12 13:13:01 2021] sync_intmask = 0x00000011
                           ---- host syncpt irq mask ----
[pon kwi 12 13:13:01 2021] syncpt_thresh_int_mask(0) = 0x00000001
[pon kwi 12 13:13:01 2021] syncpt_thresh_int_mask(1) = 0x14000154
[pon kwi 12 13:13:01 2021] syncpt_thresh_int_mask(2) = 0x00000004
[pon kwi 12 13:13:01 2021] syncpt_thresh_int_mask(3) = 0x00000000
[pon kwi 12 13:13:01 2021] syncpt_thresh_int_mask(4) = 0x00000000
[pon kwi 12 13:13:01 2021] syncpt_thresh_int_mask(5) = 0x00000000
[pon kwi 12 13:13:01 2021] syncpt_thresh_int_mask(6) = 0x00000000
[pon kwi 12 13:13:01 2021] syncpt_thresh_int_mask(7) = 0x00000000
[pon kwi 12 13:13:01 2021] syncpt_thresh_int_mask(8) = 0x00000000
[pon kwi 12 13:13:01 2021] syncpt_thresh_int_mask(9) = 0x00000000
[pon kwi 12 13:13:01 2021] syncpt_thresh_int_mask(10) = 0x00000000
[pon kwi 12 13:13:01 2021] syncpt_thresh_int_mask(11) = 0x00000000
                           ---- host syncpt irq status ----
[pon kwi 12 13:13:01 2021] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[pon kwi 12 13:13:01 2021] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[pon kwi 12 13:13:01 2021] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[pon kwi 12 13:13:01 2021] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[pon kwi 12 13:13:01 2021] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[pon kwi 12 13:13:01 2021] syncpt_thresh_cpu0_int_status(5) = 0x00000000
                           ---- host syncpt thresh ----
[pon kwi 12 13:13:01 2021] syncpt_int_thresh_thresh_0(0) = 1
[pon kwi 12 13:13:01 2021] syncpt_int_thresh_thresh_0(17) = 10
[pon kwi 12 13:13:01 2021] syncpt_int_thresh_thresh_0(18) = 10
[pon kwi 12 13:13:01 2021] syncpt_int_thresh_thresh_0(19) = 47
[pon kwi 12 13:13:01 2021] syncpt_int_thresh_thresh_0(20) = 10
[pon kwi 12 13:13:01 2021] syncpt_int_thresh_thresh_0(29) = 10
[pon kwi 12 13:13:01 2021] syncpt_int_thresh_thresh_0(30) = 24
[pon kwi 12 13:13:01 2021] syncpt_int_thresh_thresh_0(33) = 10
[pon kwi 12 13:13:01 2021] 10590001
[pon kwi 12 13:13:01 2021] 00000003
[pon kwi 12 13:13:01 2021] 120e0006
[pon kwi 12 13:13:01 2021] 007f0015
[pon kwi 12 13:13:01 2021] 080301f0
[pon kwi 12 13:13:01 2021] 00140000
[pon kwi 12 13:13:01 2021] 0000f005
[pon kwi 12 13:13:01 2021] 12420001
[pon kwi 12 13:13:01 2021] 124b0003
[pon kwi 12 13:13:01 2021] 00000040
[pon kwi 12 13:13:01 2021] 128b0001
[pon kwi 12 13:13:01 2021]     GATHER at ffd68000+008c, 3 words
[pon kwi 12 13:13:01 2021] 304e0005
[pon kwi 12 13:13:01 2021] 0000002e
[pon kwi 12 13:13:01 2021]     GATHER at ffd68000+0098, 17 words
[pon kwi 12 13:13:01 2021] 00200004
[pon kwi 12 13:13:01 2021] 0be00fc0
[pon kwi 12 13:13:01 2021] 000013b0
[pon kwi 12 13:13:01 2021] 0000002b
[pon kwi 12 13:13:01 2021] 00000047
[pon kwi 12 13:13:01 2021] 00001d1d
[pon kwi 12 13:13:01 2021] 00000521
[pon kwi 12 13:13:01 2021] 20410001
[pon kwi 12 13:13:01 2021]     GATHER at ffd68000+00dc, 2 words
[pon kwi 12 13:13:01 2021] 0000001e
[pon kwi 12 13:13:01 2021] fence timeout on [ffffffc08b98ad80] after 1500ms
[pon kwi 12 13:13:01 2021] name=[nvhost_sync:33], current value=9 waiting value=10
[pon kwi 12 13:13:03 2021] fence timeout on [ffffffc0a2d58600] after 1500ms
[pon kwi 12 13:13:03 2021] name=[nvhost_sync:17], current value=10 waiting value=12
[pon kwi 12 13:13:03 2021] ---- mlocks ----
[pon kwi 12 13:13:03 2021] ---- syncpts ----
[pon kwi 12 13:13:03 2021] id 8 (gm20b_507) min 26234 max 26234 refs 1 (previous client : )
[pon kwi 12 13:13:03 2021] id 9 (gm20b_506) min 14 max 14 refs 1 (previous client : )
[pon kwi 12 13:13:03 2021] fence timeout on [ffffffc08b98ae40] after 1500ms
[pon kwi 12 13:13:03 2021] fence timeout on [ffffffc0a2d580c0] after 1500ms
[pon kwi 12 13:13:03 2021] id 11 (gm20b_505) min 41138 max 41138 refs 1 (previous client : gm20b_505)
[pon kwi 12 13:13:03 2021] name=[nvhost_sync:33], current value=10 waiting value=11
[pon kwi 12 13:13:03 2021] id 12 (54340000.vic_0) min 3 max 3 refs 1 (previous client : 54340000.vic_0)
[pon kwi 12 13:13:03 2021] name=[nvhost_sync:18], current value=10 waiting value=11
[pon kwi 12 13:13:03 2021] id 17 (54680000.isp_0) min 10 max 12 refs 3 (previous client : 54680000.isp_0)
[pon kwi 12 13:13:03 2021] id 18 (54680000.isp_1) min 10 max 12 refs 3 (previous client : 54680000.isp_1)
[pon kwi 12 13:13:03 2021] id 19 (54680000.isp_2) min 50 max 54 refs 6 (previous client : 54680000.isp_2)
[pon kwi 12 13:13:03 2021] id 20 (54680000.isp_3) min 10 max 12 refs 3 (previous client : 54680000.isp_3)
[pon kwi 12 13:13:03 2021] id 21 (gm20b_504) min 1408 max 1408 refs 1 (previous client : gm20b_504)
[pon kwi 12 13:13:03 2021] id 22 (gm20b_503) min 96 max 96 refs 1 (previous client : gm20b_503)
[pon kwi 12 13:13:03 2021] id 23 (gm20b_502) min 4 max 4 refs 1 (previous client : gm20b_502)
[pon kwi 12 13:13:03 2021] id 24 (gm20b_501) min 4 max 4 refs 1 (previous client : gm20b_501)
[pon kwi 12 13:13:03 2021] id 25 (gm20b_500) min 12 max 12 refs 1 (previous client : gm20b_500)
[pon kwi 12 13:13:03 2021] id 29 (54080000.vi_1) min 10 max 12 refs 3 (previous client : 54080000.vi_1)
[pon kwi 12 13:13:03 2021] id 30 (54080000.vi_2) min 25 max 28 refs 5 (previous client : 54080000.vi_2)
[pon kwi 12 13:13:03 2021] id 33 (54080000.vi_4) min 10 max 12 refs 3 (previous client : 54080000.vi_4)
[pon kwi 12 13:13:03 2021] id 34 (54340000.vic_0) min 3 max 3 refs 1 (previous client : 54340000.vic_0)
[pon kwi 12 13:13:03 2021] id 35 (gm20b_494) min 6 max 6 refs 1 (previous client : 54340000.vic_0)
[pon kwi 12 13:13:03 2021] id 36 (54340000.vic_0) min 18 max 18 refs 1 (previous client : gm20b_499)
[pon kwi 12 13:13:03 2021] id 37 (gm20b_495) min 26 max 26 refs 1 (previous client : gm20b_498)
[pon kwi 12 13:13:03 2021] id 38 (gm20b_497) min 26 max 26 refs 1 (previous client : gm20b_497)
[pon kwi 12 13:13:03 2021] id 39 (gm20b_499) min 24 max 24 refs 1 (previous client : gm20b_496)
[pon kwi 12 13:13:03 2021] id 40 (gm20b_496) min 24 max 24 refs 1 (previous client : gm20b_495)
[pon kwi 12 13:13:03 2021] id 41 (gm20b_498) min 24 max 24 refs 1 (previous client : gm20b_494)
[pon kwi 12 13:13:03 2021] ---- channels ----
[pon kwi 12 13:13:03 2021] 0-54680000.isp (11):
[pon kwi 12 13:13:03 2021] active class 01, offset 0050, val 00000011
[pon kwi 12 13:13:03 2021] DMAPUT 00000630, DMAGET 00000630, DMACTL 00000000
[pon kwi 12 13:13:03 2021] CBREAD 00000011, CBSTAT 00010050
                           ffffffc079f4ec00: JOB, syncpt_id=17, syncpt_val=11, first_get=00000598, timeout=10000, num_slots=3, num_handles=1
[pon kwi 12 13:13:03 2021]     GATHER at ffe20000+45a0, 8 words
[pon kwi 12 13:13:03 2021] 20000001
[pon kwi 12 13:13:03 2021] 00000411
[pon kwi 12 13:13:03 2021] 00000512
[pon kwi 12 13:13:03 2021] 00000614
[pon kwi 12 13:13:03 2021] 200c0001
[pon kwi 12 13:13:03 2021] 00000005
[pon kwi 12 13:13:03 2021]     GATHER at ffe20000+45c0, 2 words
[pon kwi 12 13:13:03 2021] 00000013
[pon kwi 12 13:13:03 2021] 1-54080000.vi (9):
[pon kwi 12 13:13:03 2021] active class 01, offset 0050, val 0000001d
[pon kwi 12 13:13:03 2021] DMAPUT 00000390, DMAGET 00000390, DMACTL 00000000
[pon kwi 12 13:13:03 2021] CBREAD 0000001d, CBSTAT 00010050
                           ffffffc079f4e400: JOB, syncpt_id=29, syncpt_val=11, first_get=00000300, timeout=10000, num_slots=5, num_handles=1
[pon kwi 12 13:13:03 2021]     GATHER at ffd68000+00f8, 3 words
[pon kwi 12 13:13:03 2021] 304e0005
[pon kwi 12 13:13:03 2021] 00000032
[pon kwi 12 13:13:03 2021]     GATHER at ffd68000+0104, 6 words
[pon kwi 12 13:13:03 2021] 00001d1d
[pon kwi 12 13:13:03 2021] 00000521
[pon kwi 12 13:13:03 2021] 20410001
[pon kwi 12 13:13:03 2021] 00000001
[pon kwi 12 13:13:03 2021]     GATHER at ffd68000+011c, 2 words
[pon kwi 12 13:13:03 2021] 0000001e
[pon kwi 12 13:13:03 2021] sync_hintmask_ext = 0xc0000000
[pon kwi 12 13:13:03 2021] sync_hintmask = 0x80000000
[pon kwi 12 13:13:03 2021] sync_intc0mask = 0x00000001
[pon kwi 12 13:13:03 2021] sync_intmask = 0x00000011
[pon kwi 12 13:13:03 2021] syncpt_thresh_int_mask(0) = 0x00000001
[pon kwi 12 13:13:03 2021] syncpt_thresh_int_mask(1) = 0x14000154
[pon kwi 12 13:13:03 2021] syncpt_thresh_int_mask(2) = 0x00000004
[pon kwi 12 13:13:03 2021] syncpt_thresh_int_mask(3) = 0x00000000
[pon kwi 12 13:13:03 2021] syncpt_thresh_int_mask(4) = 0x00000000
[pon kwi 12 13:13:03 2021] syncpt_thresh_int_mask(5) = 0x00000000
[pon kwi 12 13:13:03 2021] syncpt_thresh_int_mask(6) = 0x00000000
[pon kwi 12 13:13:03 2021] syncpt_thresh_int_mask(7) = 0x00000000
[pon kwi 12 13:13:03 2021] syncpt_thresh_int_mask(8) = 0x00000000
[pon kwi 12 13:13:03 2021] syncpt_thresh_int_mask(9) = 0x00000000
[pon kwi 12 13:13:03 2021] syncpt_thresh_int_mask(10) = 0x00000000
[pon kwi 12 13:13:03 2021] syncpt_thresh_int_mask(11) = 0x00000000
[pon kwi 12 13:13:03 2021] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[pon kwi 12 13:13:03 2021] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[pon kwi 12 13:13:03 2021] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[pon kwi 12 13:13:03 2021] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[pon kwi 12 13:13:03 2021] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[pon kwi 12 13:13:03 2021] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[pon kwi 12 13:13:03 2021] syncpt_int_thresh_thresh_0(0) = 1
[pon kwi 12 13:13:03 2021] syncpt_int_thresh_thresh_0(17) = 11
[pon kwi 12 13:13:03 2021] syncpt_int_thresh_thresh_0(18) = 11
[pon kwi 12 13:13:03 2021] syncpt_int_thresh_thresh_0(19) = 51
[pon kwi 12 13:13:03 2021] syncpt_int_thresh_thresh_0(20) = 11
[pon kwi 12 13:13:03 2021] syncpt_int_thresh_thresh_0(29) = 11
[pon kwi 12 13:13:03 2021] syncpt_int_thresh_thresh_0(30) = 26
[pon kwi 12 13:13:03 2021] syncpt_int_thresh_thresh_0(33) = 11
[pon kwi 12 13:13:04 2021] fence timeout on [ffffffc0a2d58240] after 1500ms
[pon kwi 12 13:13:04 2021] fence timeout on [ffffffc0a2d58840] after 1500ms
[pon kwi 12 13:13:04 2021] name=[nvhost_sync:33], current value=11 waiting value=12
[pon kwi 12 13:13:04 2021] name=[nvhost_sync:18], current value=11 waiting value=12
[pon kwi 12 13:13:04 2021] ---- mlocks ----
[pon kwi 12 13:13:04 2021] ---- syncpts ----
[pon kwi 12 13:13:04 2021] id 8 (gm20b_507) min 26240 max 26240 refs 1 (previous client : )
[pon kwi 12 13:13:04 2021] id 9 (gm20b_506) min 14 max 14 refs 1 (previous client : )
[pon kwi 12 13:13:04 2021] id 11 (gm20b_505) min 41150 max 41150 refs 1 (previous client : gm20b_505)
[pon kwi 12 13:13:04 2021] id 12 (54340000.vic_0) min 3 max 3 refs 1 (previous client : 54340000.vic_0)
[pon kwi 12 13:13:04 2021] id 17 (54680000.isp_0) min 11 max 13 refs 3 (previous client : 54680000.isp_0)
[pon kwi 12 13:13:04 2021] id 18 (54680000.isp_1) min 11 max 13 refs 3 (previous client : 54680000.isp_1)
[pon kwi 12 13:13:04 2021] id 19 (54680000.isp_2) min 53 max 57 refs 6 (previous client : 54680000.isp_2)
[pon kwi 12 13:13:04 2021] id 20 (54680000.isp_3) min 11 max 13 refs 3 (previous client : 54680000.isp_3)
[pon kwi 12 13:13:04 2021] id 21 (gm20b_504) min 1408 max 1408 refs 1 (previous client : gm20b_504)
[pon kwi 12 13:13:04 2021] id 22 (gm20b_503) min 96 max 96 refs 1 (previous client : gm20b_503)
[pon kwi 12 13:13:04 2021] id 23 (gm20b_502) min 4 max 4 refs 1 (previous client : gm20b_502)
[pon kwi 12 13:13:04 2021] id 24 (gm20b_501) min 4 max 4 refs 1 (previous client : gm20b_501)
[pon kwi 12 13:13:04 2021] id 25 (gm20b_500) min 12 max 12 refs 1 (previous client : gm20b_500)
[pon kwi 12 13:13:04 2021] id 29 (54080000.vi_1) min 11 max 13 refs 3 (previous client : 54080000.vi_1)
[pon kwi 12 13:13:04 2021] id 30 (54080000.vi_2) min 27 max 30 refs 5 (previous client : 54080000.vi_2)
[pon kwi 12 13:13:04 2021] id 33 (54080000.vi_4) min 11 max 13 refs 3 (previous client : 54080000.vi_4)
[pon kwi 12 13:13:04 2021] id 34 (54340000.vic_0) min 3 max 3 refs 1 (previous client : 54340000.vic_0)
[pon kwi 12 13:13:04 2021] id 35 (gm20b_494) min 6 max 6 refs 1 (previous client : 54340000.vic_0)
[pon kwi 12 13:13:04 2021] id 36 (54340000.vic_0) min 18 max 18 refs 1 (previous client : gm20b_499)
[pon kwi 12 13:13:04 2021] id 37 (gm20b_495) min 26 max 26 refs 1 (previous client : gm20b_498)
[pon kwi 12 13:13:04 2021] id 38 (gm20b_497) min 26 max 26 refs 1 (previous client : gm20b_497)
[pon kwi 12 13:13:04 2021] id 39 (gm20b_499) min 24 max 24 refs 1 (previous client : gm20b_496)
[pon kwi 12 13:13:04 2021] id 40 (gm20b_496) min 24 max 24 refs 1 (previous client : gm20b_495)
[pon kwi 12 13:13:04 2021] id 41 (gm20b_498) min 24 max 24 refs 1 (previous client : gm20b_494)
[pon kwi 12 13:13:04 2021] ---- channels ----
[pon kwi 12 13:13:04 2021] 0-54680000.isp (11):
[pon kwi 12 13:13:04 2021] active class 01, offset 0050, val 00000011
[pon kwi 12 13:13:04 2021] DMAPUT 00000688, DMAGET 00000688, DMACTL 00000000
[pon kwi 12 13:13:04 2021] CBREAD 00000011, CBSTAT 00010050
                           ffffffc079f4dc00: JOB, syncpt_id=17, syncpt_val=12, first_get=000005f0, timeout=10000, num_slots=3, num_handles=1
[pon kwi 12 13:13:04 2021]     GATHER at ffe20000+466c, 8 words
[pon kwi 12 13:13:04 2021] 20000001
[pon kwi 12 13:13:04 2021] 00000411
[pon kwi 12 13:13:04 2021] 00000512
[pon kwi 12 13:13:04 2021] 00000614
[pon kwi 12 13:13:04 2021] 200c0001
[pon kwi 12 13:13:04 2021] 00000005
[pon kwi 12 13:13:04 2021]     GATHER at ffe20000+468c, 2 words
[pon kwi 12 13:13:04 2021] 00000013
[pon kwi 12 13:13:04 2021] 1-54080000.vi (9):
[pon kwi 12 13:13:04 2021] active class 01, offset 0050, val 0000001d
[pon kwi 12 13:13:04 2021] DMAPUT 000003d8, DMAGET 000003d8, DMACTL 00000000
[pon kwi 12 13:13:04 2021] CBREAD 0000001d, CBSTAT 00010050
                           ffffffc079f4d400: JOB, syncpt_id=29, syncpt_val=12, first_get=00000348, timeout=10000, num_slots=5, num_handles=1
[pon kwi 12 13:13:04 2021]     GATHER at ffd68000+0138, 3 words
[pon kwi 12 13:13:04 2021] 304e0005
[pon kwi 12 13:13:04 2021] 00000035
[pon kwi 12 13:13:04 2021]     GATHER at ffd68000+0144, 10 words
[pon kwi 12 13:13:04 2021] 124b0003
[pon kwi 12 13:13:04 2021] 00000000
[pon kwi 12 13:13:04 2021] 00000047
[pon kwi 12 13:13:04 2021] 00001d1d
[pon kwi 12 13:13:04 2021] unable to lock channel list
[pon kwi 12 13:13:04 2021] sync_hintmask_ext = 0xc0000000
[pon kwi 12 13:13:04 2021] sync_hintmask = 0x80000000
[pon kwi 12 13:13:04 2021] sync_intc0mask = 0x00000001
[pon kwi 12 13:13:04 2021] sync_intmask = 0x00000011
[pon kwi 12 13:13:04 2021] syncpt_thresh_int_mask(0) = 0x00000001
[pon kwi 12 13:13:04 2021] syncpt_thresh_int_mask(1) = 0x14000154
[pon kwi 12 13:13:04 2021] syncpt_thresh_int_mask(2) = 0x00000004
[pon kwi 12 13:13:04 2021] syncpt_thresh_int_mask(3) = 0x00000000
[pon kwi 12 13:13:04 2021] syncpt_thresh_int_mask(4) = 0x00000000
[pon kwi 12 13:13:04 2021] syncpt_thresh_int_mask(5) = 0x00000000
[pon kwi 12 13:13:04 2021] syncpt_thresh_int_mask(6) = 0x00000000
[pon kwi 12 13:13:04 2021] syncpt_thresh_int_mask(7) = 0x00000000
[pon kwi 12 13:13:04 2021] syncpt_thresh_int_mask(8) = 0x00000000
[pon kwi 12 13:13:04 2021] syncpt_thresh_int_mask(9) = 0x00000000
[pon kwi 12 13:13:04 2021] syncpt_thresh_int_mask(10) = 0x00000000
[pon kwi 12 13:13:04 2021] syncpt_thresh_int_mask(11) = 0x00000000
[pon kwi 12 13:13:04 2021] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[pon kwi 12 13:13:04 2021] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[pon kwi 12 13:13:04 2021] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[pon kwi 12 13:13:04 2021] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[pon kwi 12 13:13:04 2021] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[pon kwi 12 13:13:04 2021] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[pon kwi 12 13:13:04 2021] syncpt_int_thresh_thresh_0(0) = 1
[pon kwi 12 13:13:04 2021] syncpt_int_thresh_thresh_0(17) = 12
[pon kwi 12 13:13:04 2021] syncpt_int_thresh_thresh_0(18) = 12
[pon kwi 12 13:13:04 2021] syncpt_int_thresh_thresh_0(19) = 54
[pon kwi 12 13:13:04 2021] syncpt_int_thresh_thresh_0(20) = 12
[pon kwi 12 13:13:04 2021] syncpt_int_thresh_thresh_0(29) = 12
[pon kwi 12 13:13:04 2021] syncpt_int_thresh_thresh_0(30) = 28
[pon kwi 12 13:13:04 2021] syncpt_int_thresh_thresh_0(33) = 12
[pon kwi 12 13:13:04 2021] 00000521
[pon kwi 12 13:13:04 2021] 20410001
[pon kwi 12 13:13:04 2021] 00000001
[pon kwi 12 13:13:04 2021]     GATHER at ffd68000+016c, 2 words
[pon kwi 12 13:13:04 2021] 0000001e
[pon kwi 12 13:13:05 2021] misc tegra_camera_ctrl: tegra_camera_update_isobw: Warning, Requested ISO BW 1500000 has been capped to VI's max BW 1500000
[pon kwi 12 13:13:14 2021] host1x 50000000.host1x: cdma_handle_timeout: timeout: 29 (54080000.vi_1) client 30, HW thresh 11, done 12
[pon kwi 12 13:13:14 2021] host1x 50000000.host1x: cdma_handle_timeout: timeout: 33 (54080000.vi_4) client 30, HW thresh 11, done 12
[pon kwi 12 13:13:14 2021] host1x 50000000.host1x: cdma_handle_timeout: timeout: 30 (54080000.vi_2) client 30, HW thresh 27, done 27
[pon kwi 12 13:13:14 2021] ---- mlocks ----
[pon kwi 12 13:13:14 2021] ---- syncpts ----
[pon kwi 12 13:13:14 2021] id 8 (gm20b_507) min 26272 max 26272 refs 1 (previous client : )
[pon kwi 12 13:13:14 2021] id 9 (gm20b_506) min 14 max 14 refs 1 (previous client : )
[pon kwi 12 13:13:14 2021] id 11 (gm20b_505) min 41216 max 41216 refs 1 (previous client : gm20b_505)
[pon kwi 12 13:13:14 2021] id 12 (54340000.vic_0) min 3 max 3 refs 1 (previous client : 54340000.vic_0)
[pon kwi 12 13:13:14 2021] id 17 (54680000.isp_0) min 11 max 13 refs 2 (previous client : 54680000.isp_0)
[pon kwi 12 13:13:14 2021] id 18 (54680000.isp_1) min 11 max 13 refs 2 (previous client : 54680000.isp_1)
[pon kwi 12 13:13:14 2021] id 19 (54680000.isp_2) min 53 max 58 refs 6 (previous client : 54680000.isp_2)
[pon kwi 12 13:13:14 2021] id 20 (54680000.isp_3) min 11 max 13 refs 2 (previous client : 54680000.isp_3)
[pon kwi 12 13:13:14 2021] id 29 (54080000.vi_1) min 11 max 13 refs 2 (previous client : 54080000.vi_1)
[pon kwi 12 13:13:14 2021] id 30 (54080000.vi_2) min 27 max 30 refs 4 (previous client : 54080000.vi_2)
[pon kwi 12 13:13:14 2021] id 33 (54080000.vi_4) min 11 max 13 refs 2 (previous client : 54080000.vi_4)
[pon kwi 12 13:13:14 2021] ---- channels ----
[pon kwi 12 13:13:14 2021] 0-54680000.isp (11):
[pon kwi 12 13:13:14 2021] active class 01, offset 0050, val 00000011
[pon kwi 12 13:13:14 2021] DMAPUT 000006a0, DMAGET 00000688, DMACTL 00000000
[pon kwi 12 13:13:14 2021] CBREAD 00000011, CBSTAT 00010050
[pon kwi 12 13:13:14 2021]     GATHER at ffe20000+466c, 8 words
[pon kwi 12 13:13:14 2021] 20000001
[pon kwi 12 13:13:14 2021] 00000411
[pon kwi 12 13:13:14 2021] 00000512
[pon kwi 12 13:13:14 2021] 00000614
[pon kwi 12 13:13:14 2021] 200c0001
[pon kwi 12 13:13:14 2021] 00000005
[pon kwi 12 13:13:14 2021]     GATHER at ffe20000+468c, 2 words
[pon kwi 12 13:13:14 2021] 00000013
[pon kwi 12 13:13:14 2021] 1-54080000.vi (7):
[pon kwi 12 13:13:14 2021] active class 01, offset 0050, val 0000001d
[pon kwi 12 13:13:14 2021] DMAPUT 000003d8, DMAGET 000003d8, DMACTL 00000000
[pon kwi 12 13:13:14 2021] CBREAD 0000001d, CBSTAT 00010050
[pon kwi 12 13:13:14 2021]     GATHER at ffd68000+0138, 3 words
[pon kwi 12 13:13:14 2021] 304e0005
[pon kwi 12 13:13:14 2021] 00000035
[pon kwi 12 13:13:14 2021]     GATHER at ffd68000+0144, 10 words
[pon kwi 12 13:13:14 2021] 124b0003
[pon kwi 12 13:13:14 2021] 00000000
[pon kwi 12 13:13:14 2021] 00000047
[pon kwi 12 13:13:14 2021] 00001d1d
[pon kwi 12 13:13:14 2021] 00000521
[pon kwi 12 13:13:14 2021] 20410001
[pon kwi 12 13:13:14 2021] 00000001
[pon kwi 12 13:13:14 2021]     GATHER at ffd68000+016c, 2 words
[pon kwi 12 13:13:14 2021] 0000001e
[pon kwi 12 13:13:14 2021] sync_hintmask_ext = 0xc0000000
[pon kwi 12 13:13:14 2021] sync_hintmask = 0x80000000
[pon kwi 12 13:13:14 2021] sync_intc0mask = 0x00000001
[pon kwi 12 13:13:14 2021] sync_intmask = 0x00000011
[pon kwi 12 13:13:14 2021] syncpt_thresh_int_mask(0) = 0x00000001
[pon kwi 12 13:13:14 2021] syncpt_thresh_int_mask(1) = 0x14000154
[pon kwi 12 13:13:14 2021] syncpt_thresh_int_mask(2) = 0x00000004
[pon kwi 12 13:13:14 2021] syncpt_thresh_int_mask(3) = 0x00000000
[pon kwi 12 13:13:14 2021] syncpt_thresh_int_mask(4) = 0x00000000
[pon kwi 12 13:13:14 2021] syncpt_thresh_int_mask(5) = 0x00000000
[pon kwi 12 13:13:14 2021] syncpt_thresh_int_mask(6) = 0x00000000
[pon kwi 12 13:13:14 2021] syncpt_thresh_int_mask(7) = 0x00000000
[pon kwi 12 13:13:14 2021] syncpt_thresh_int_mask(8) = 0x00000000
[pon kwi 12 13:13:14 2021] syncpt_thresh_int_mask(9) = 0x00000000
[pon kwi 12 13:13:14 2021] syncpt_thresh_int_mask(10) = 0x00000000
[pon kwi 12 13:13:14 2021] syncpt_thresh_int_mask(11) = 0x00000000
[pon kwi 12 13:13:14 2021] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[pon kwi 12 13:13:14 2021] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[pon kwi 12 13:13:14 2021] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[pon kwi 12 13:13:14 2021] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[pon kwi 12 13:13:14 2021] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[pon kwi 12 13:13:14 2021] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[pon kwi 12 13:13:14 2021] syncpt_int_thresh_thresh_0(0) = 1
[pon kwi 12 13:13:14 2021] syncpt_int_thresh_thresh_0(17) = 12
[pon kwi 12 13:13:14 2021] syncpt_int_thresh_thresh_0(18) = 12
[pon kwi 12 13:13:14 2021] syncpt_int_thresh_thresh_0(19) = 54
[pon kwi 12 13:13:14 2021] syncpt_int_thresh_thresh_0(20) = 12
[pon kwi 12 13:13:14 2021] syncpt_int_thresh_thresh_0(29) = 12
[pon kwi 12 13:13:14 2021] syncpt_int_thresh_thresh_0(30) = 28
[pon kwi 12 13:13:14 2021] syncpt_int_thresh_thresh_0(33) = 12
[pon kwi 12 13:13:14 2021] vi 54080000.vi:     SYNCPT_ID   29
[pon kwi 12 13:13:14 2021] vi 54080000.vi:     SYNCPT_VAL  12
[pon kwi 12 13:13:14 2021] vi 54080000.vi:     FIRST_GET   0x348
[pon kwi 12 13:13:14 2021] vi 54080000.vi:     TIMEOUT     10000
[pon kwi 12 13:13:14 2021] vi 54080000.vi:     NUM_SLOTS   5
[pon kwi 12 13:13:14 2021] vi 54080000.vi:     NUM_HANDLES 1
[pon kwi 12 13:13:14 2021] vi 54080000.vi:     SYNCPT_ID   30
[pon kwi 12 13:13:14 2021] vi 54080000.vi:     SYNCPT_VAL  28
[pon kwi 12 13:13:14 2021] vi 54080000.vi:     FIRST_GET   0x370
[pon kwi 12 13:13:14 2021] vi 54080000.vi:     NUM_SLOTS   4
[pon kwi 12 13:13:14 2021] vi 54080000.vi:     SYNCPT_VAL  13
[pon kwi 12 13:13:14 2021] vi 54080000.vi:     FIRST_GET   0x390
[pon kwi 12 13:13:14 2021] vi 54080000.vi:     SYNCPT_VAL  30
[pon kwi 12 13:13:14 2021] vi 54080000.vi:     FIRST_GET   0x3b8
[pon kwi 12 13:13:14 2021] host1x 50000000.host1x: cdma_handle_timeout: timeout: 17 (54680000.isp_0) client 25, HW thresh 11, done 12
[pon kwi 12 13:13:14 2021] host1x 50000000.host1x: cdma_handle_timeout: timeout: 18 (54680000.isp_1) client 25, HW thresh 11, done 12
[pon kwi 12 13:13:14 2021] host1x 50000000.host1x: cdma_handle_timeout: timeout: 20 (54680000.isp_3) client 25, HW thresh 11, done 12
[pon kwi 12 13:13:14 2021] host1x 50000000.host1x: cdma_handle_timeout: timeout: 19 (54680000.isp_2) client 25, HW thresh 53, done 53
[pon kwi 12 13:13:14 2021] syncpt_thresh_int_mask(1) = 0x00000154
[pon kwi 12 13:13:14 2021] syncpt_thresh_int_mask(2) = 0x00000000
[pon kwi 12 13:13:14 2021] isp 54680000.isp:     SYNCPT_ID   17
[pon kwi 12 13:13:14 2021] isp 54680000.isp:     SYNCPT_VAL  12
[pon kwi 12 13:13:14 2021] isp 54680000.isp:     FIRST_GET   0x5f0
[pon kwi 12 13:13:14 2021] isp 54680000.isp:     TIMEOUT     10000
[pon kwi 12 13:13:14 2021] isp 54680000.isp:     NUM_SLOTS   3
[pon kwi 12 13:13:14 2021] isp 54680000.isp:     NUM_HANDLES 1
[pon kwi 12 13:13:14 2021] isp 54680000.isp:     SYNCPT_ID   19
[pon kwi 12 13:13:14 2021] isp 54680000.isp:     SYNCPT_VAL  54
[pon kwi 12 13:13:14 2021] isp 54680000.isp:     FIRST_GET   0x608
[pon kwi 12 13:13:14 2021] isp 54680000.isp:     NUM_SLOTS   5
[pon kwi 12 13:13:14 2021] isp 54680000.isp:     SYNCPT_VAL  55
[pon kwi 12 13:13:14 2021] isp 54680000.isp:     FIRST_GET   0x630
[pon kwi 12 13:13:14 2021] isp 54680000.isp:     NUM_HANDLES 3
[pon kwi 12 13:13:14 2021] isp 54680000.isp:     SYNCPT_VAL  13
[pon kwi 12 13:13:14 2021] isp 54680000.isp:     FIRST_GET   0x648
[pon kwi 12 13:13:14 2021] isp 54680000.isp:     SYNCPT_VAL  57
[pon kwi 12 13:13:14 2021] isp 54680000.isp:     FIRST_GET   0x660
[pon kwi 12 13:13:14 2021] isp 54680000.isp:     SYNCPT_VAL  58
[pon kwi 12 13:13:14 2021] isp 54680000.isp:     FIRST_GET   0x688
The most interesting dmesg log for me is
Is somewhere in kernel code some timeout that doesn’t allow me to get frames with such low FPS value?
When I set FPS to 1 (framerate=1/1) I can get frame successfully.
Could you check if v4l2-ctl can get data if set frame rate less than 1?
Suppose ARGUS not support it.
@ShaneCCC I made changes in nvarguscamerasrc module to support FPS lower than 1. I can see in driver logs that correct FPS value is passed.
Could you make sure the v4l2-ctl can capture the raw image for this kind setting first.
@ShaneCCC Could you provide example command for that ?
You may need to modify the driver set the default FPS > 1 and have below command to verify it.
v4l2-ctl --stream-mmap --stream-count=100 -d /dev/video0
@ShaneCCC Nothing is happening while executing this command and the dmesg is giving me:
video4linux video0: frame start syncpt timeout!0
I tried it on not modified kernel also and the result was the same.
Check below command
v4l2-ctl -d /dev/video0 --set-fmt-video=width=4032,height=3040,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=50
@ShaneCCC the same result
Could you check the trace log. And confirm with sensor vendor for this kind setting.
@ShaneCCC This camera sensor should support exposure time up to 120s. The log I mentioned in my post:
is not from driver source. I think there is some limitation in kernel sources regarding to camera control.
I mean the trace log not kernel message. Also didn’t you verify this on any others platform?
https://elinux.org/Jetson_TX2_Camera_BringUp
@ShaneCCC
Here is a trace for v4l2 command:
#                              _-----=> irqs-off
#                             / _----=> need-resched
#                            | / _---=> hardirq/softirq
#                            || / _--=> preempt-depth
#                            ||| /     delay
#           TASK-PID   CPU#  ||||    TIMESTAMP  FUNCTION
        v4l2-ctl-7644  [000] ....   257.415402: tegra_channel_open: vi-output, imx477 6-001a
        v4l2-ctl-7644  [000] ....   257.418163: camera_common_s_power: status : 0x1
        v4l2-ctl-7644  [000] ....   257.849922: camera_common_s_power: status : 0x0
        v4l2-ctl-7644  [000] ....   257.850030: tegra_channel_set_power: imx477 6-001a : 0x1
        v4l2-ctl-7644  [000] ....   257.850040: camera_common_s_power: status : 0x1
        v4l2-ctl-7644  [000] ....   258.150604: tegra_channel_set_power: nvcsi--1 : 0x1
        v4l2-ctl-7644  [000] ....   258.150625: csi_s_power: enable : 0x1
 vi-output, imx4-7645  [002] ....   258.201043: tegra_channel_set_stream: enable : 0x1
 vi-output, imx4-7645  [002] ....   258.201146: tegra_channel_set_stream: nvcsi--1 : 0x1
 vi-output, imx4-7645  [002] ....   258.201148: csi_s_stream: enable : 0x1
 vi-output, imx4-7645  [002] ....   258.201155: tegra_channel_set_stream: imx477 6-001a : 0x1
 vi-output, imx4-7645  [000] ....   260.321622: tegra_channel_capture_frame: sof:260.166777765
 vi-output, imx4-7645  [001] ....   262.338132: tegra_channel_capture_frame: sof:262.183286931
 vi-output, imx4-7645  [001] ....   264.353688: tegra_channel_capture_frame: sof:264.198844951
 vi-output, imx4-7645  [001] ....   266.369124: tegra_channel_capture_frame: sof:266.214295784
 vi-output, imx4-7645  [002] ....   268.384544: tegra_channel_capture_frame: sof:268.229730679
 vi-output, imx4-7645  [003] ....   270.401317: tegra_channel_capture_frame: sof:270.246497917
 vi-output, imx4-7645  [000] ....   272.417149: tegra_channel_capture_frame: sof:272.262330208
 vi-output, imx4-7645  [001] ....   274.433198: tegra_channel_capture_frame: sof:274.278382395
 vi-output, imx4-7645  [001] ....   276.448548: tegra_channel_capture_frame: sof:276.293725936
 vi-output, imx4-7645  [001] ....   278.464911: tegra_channel_capture_frame: sof:278.310068175
 vi-output, imx4-7645  [001] ....   280.481235: tegra_channel_capture_frame: sof:280.326394945
 vi-output, imx4-7645  [001] ....   282.496812: tegra_channel_capture_frame: sof:282.341971194
 vi-output, imx4-7645  [001] ....   284.512609: tegra_channel_capture_frame: sof:284.357767600
 vi-output, imx4-7645  [001] ....   286.528541: tegra_channel_capture_frame: sof:286.373698536
 vi-output, imx4-7645  [001] ....   288.544482: tegra_channel_capture_frame: sof:288.389640931
 vi-output, imx4-7645  [001] ....   290.560945: tegra_channel_capture_frame: sof:290.406104264
 vi-output, imx4-7645  [001] ....   292.577036: tegra_channel_capture_frame: sof:292.422193742
Trace for gst-launch with fps=1/2:
#                              _-----=> irqs-off
#                            ||| /     delay
  nvargus-daemon-7437  [002] ....   185.325148: tegra_channel_open: vi-output, imx477 6-001a
  nvargus-daemon-7437  [002] ....   185.326279: camera_common_s_power: status : 0x1
  nvargus-daemon-7437  [000] ....   185.759224: camera_common_s_power: status : 0x0
  nvargus-daemon-7437  [000] ....   185.759313: tegra_channel_set_power: imx477 6-001a : 0x1
  nvargus-daemon-7437  [000] ....   185.759321: camera_common_s_power: status : 0x1
  nvargus-daemon-7437  [000] ....   186.059607: tegra_channel_set_power: nvcsi--1 : 0x1
  nvargus-daemon-7437  [000] ....   186.059625: csi_s_power: enable : 0x1
  nvargus-daemon-7437  [000] ....   186.060515: tegra_channel_close: vi-output, imx477 6-001a
  nvargus-daemon-7437  [000] ....   186.060544: tegra_channel_set_power: imx477 6-001a : 0x0
  nvargus-daemon-7437  [000] ....   186.060603: camera_common_s_power: status : 0x0
  nvargus-daemon-7437  [000] ....   186.061020: tegra_channel_set_power: nvcsi--1 : 0x0
  nvargus-daemon-7437  [000] ....   186.061035: csi_s_power: enable : 0x0
  nvargus-daemon-7437  [000] ....   186.075570: tegra_channel_open: vi-output, imx477 6-001a
  nvargus-daemon-7437  [000] ....   186.075582: tegra_channel_set_power: imx477 6-001a : 0x1
  nvargus-daemon-7437  [000] ....   186.075594: camera_common_s_power: status : 0x1
  nvargus-daemon-7437  [000] ....   186.376176: tegra_channel_set_power: nvcsi--1 : 0x1
  nvargus-daemon-7437  [000] ....   186.376192: csi_s_power: enable : 0x1
  nvargus-daemon-7437  [000] ....   186.377143: tegra_channel_close: vi-output, imx477 6-001a
  nvargus-daemon-7437  [000] ....   186.377169: tegra_channel_set_power: imx477 6-001a : 0x0
  nvargus-daemon-7437  [000] ....   186.377225: camera_common_s_power: status : 0x0
  nvargus-daemon-7437  [000] ....   186.377627: tegra_channel_set_power: nvcsi--1 : 0x0
  nvargus-daemon-7437  [000] ....   186.377642: csi_s_power: enable : 0x0
  nvargus-daemon-7437  [000] ....   186.411820: tegra_channel_open: vi-output, imx477 6-001a
  nvargus-daemon-7437  [000] ....   186.411829: tegra_channel_set_power: imx477 6-001a : 0x1
  nvargus-daemon-7437  [000] ....   186.411837: camera_common_s_power: status : 0x1
  nvargus-daemon-7437  [000] ....   186.712467: tegra_channel_set_power: nvcsi--1 : 0x1
  nvargus-daemon-7437  [000] ....   186.712491: csi_s_power: enable : 0x1
  nvargus-daemon-7437  [000] ....   186.712693: tegra_channel_close: vi-output, imx477 6-001a
  nvargus-daemon-7437  [000] ....   186.712721: tegra_channel_set_power: imx477 6-001a : 0x0
  nvargus-daemon-7437  [000] ....   186.712777: camera_common_s_power: status : 0x0
  nvargus-daemon-7437  [000] ....   186.713196: tegra_channel_set_power: nvcsi--1 : 0x0
  nvargus-daemon-7437  [000] ....   186.713211: csi_s_power: enable : 0x0
  nvargus-daemon-7437  [000] ....   186.713758: tegra_channel_open: vi-output, imx477 6-001a
  nvargus-daemon-7437  [000] ....   186.713805: tegra_channel_set_power: imx477 6-001a : 0x1
  nvargus-daemon-7437  [000] ....   186.713862: camera_common_s_power: status : 0x1
  nvargus-daemon-7437  [000] ....   187.014579: tegra_channel_set_power: nvcsi--1 : 0x1
  nvargus-daemon-7437  [000] ....   187.014599: csi_s_power: enable : 0x1
  nvargus-daemon-7437  [000] ....   187.015463: tegra_channel_close: vi-output, imx477 6-001a
  nvargus-daemon-7437  [000] ....   187.015491: tegra_channel_set_power: imx477 6-001a : 0x0
  nvargus-daemon-7437  [000] ....   187.015552: camera_common_s_power: status : 0x0
  nvargus-daemon-7437  [000] ....   187.015960: tegra_channel_set_power: nvcsi--1 : 0x0
  nvargus-daemon-7437  [000] ....   187.015976: csi_s_power: enable : 0x0
  nvargus-daemon-7437  [000] ....   187.016537: tegra_channel_open: vi-output, imx477 6-001a
  nvargus-daemon-7437  [000] ....   187.016583: tegra_channel_set_power: imx477 6-001a : 0x1
  nvargus-daemon-7437  [000] ....   187.016640: camera_common_s_power: status : 0x1
  nvargus-daemon-7437  [000] ....   187.317349: tegra_channel_set_power: nvcsi--1 : 0x1
  nvargus-daemon-7437  [000] ....   187.317366: csi_s_power: enable : 0x1
  nvargus-daemon-7437  [000] ....   187.318151: tegra_channel_close: vi-output, imx477 6-001a
  nvargus-daemon-7437  [000] ....   187.318180: tegra_channel_set_power: imx477 6-001a : 0x0
  nvargus-daemon-7437  [000] ....   187.318225: camera_common_s_power: status : 0x0
  nvargus-daemon-7437  [000] ....   187.319123: tegra_channel_set_power: nvcsi--1 : 0x0
  nvargus-daemon-7437  [000] ....   187.319139: csi_s_power: enable : 0x0
 CaptureSchedule-7456  [002] ....   187.509360: tegra_channel_open: vi-output, imx477 6-001a
 CaptureSchedule-7456  [002] ....   187.509370: tegra_channel_set_power: imx477 6-001a : 0x1
 CaptureSchedule-7456  [002] ....   187.509378: camera_common_s_power: status : 0x1
 CaptureSchedule-7456  [002] ....   187.809608: tegra_channel_set_power: nvcsi--1 : 0x1
 CaptureSchedule-7456  [002] ....   187.809613: csi_s_power: enable : 0x1
 CaptureSchedule-7456  [000] ....   187.812387: tegra_channel_set_stream: enable : 0x1
 CaptureSchedule-7456  [000] ....   187.812470: tegra_channel_set_stream: nvcsi--1 : 0x1
 CaptureSchedule-7456  [000] ....   187.812472: csi_s_stream: enable : 0x1
 CaptureSchedule-7456  [000] ....   187.812473: tegra_channel_set_stream: imx477 6-001a : 0x1
 ViCsiHw frameSt-7485  [003] ....   191.990454: tegra_channel_close: vi-output, imx477 6-001a
 ViCsiHw frameSt-7485  [003] ....   191.990461: tegra_channel_set_stream: enable : 0x0
 ViCsiHw frameSt-7485  [003] ....   191.990461: tegra_channel_set_stream: imx477 6-001a : 0x0
 ViCsiHw frameSt-7485  [003] ....   191.990776: tegra_channel_set_stream: nvcsi--1 : 0x0
 ViCsiHw frameSt-7485  [003] ....   191.990779: csi_s_stream: enable : 0x0
 ViCsiHw frameSt-7485  [003] ....   191.990874: tegra_channel_set_power: imx477 6-001a : 0x0
 ViCsiHw frameSt-7485  [003] ....   191.990879: camera_common_s_power: status : 0x0
 ViCsiHw frameSt-7485  [003] ....   191.990935: tegra_channel_set_power: nvcsi--1 : 0x0
 ViCsiHw frameSt-7485  [003] ....   191.990937: csi_s_power: enable : 0x0
     kworker/0:2-1469  [000] ....   201.017862: camera_common_s_power: status : 0x0
Trace for gst-launch with fps=1/1:
#                              _-----=> irqs-off
#                            ||| /     delay
 gst-plugin-scan-7249  [000] ....    96.949014: tegra_channel_open: vi-output, imx477 6-001a
 gst-plugin-scan-7249  [000] ....    96.951281: camera_common_s_power: status : 0x1
 gst-plugin-scan-7249  [000] ....    97.334161: camera_common_s_power: status : 0x0
 gst-plugin-scan-7249  [000] ....    97.334220: tegra_channel_set_power: imx477 6-001a : 0x1
 gst-plugin-scan-7249  [000] ....    97.334225: camera_common_s_power: status : 0x1
 gst-plugin-scan-7249  [000] ....    97.634371: tegra_channel_set_power: nvcsi--1 : 0x1
 gst-plugin-scan-7249  [000] ....    97.634376: csi_s_power: enable : 0x1
 gst-plugin-scan-7249  [000] ....    97.634433: tegra_channel_close: vi-output, imx477 6-001a
 gst-plugin-scan-7249  [000] ....    97.634437: tegra_channel_set_power: imx477 6-001a : 0x0
 gst-plugin-scan-7249  [000] ....    97.634445: camera_common_s_power: status : 0x0
 gst-plugin-scan-7249  [000] ....    97.634501: tegra_channel_set_power: nvcsi--1 : 0x0
 gst-plugin-scan-7249  [000] ....    97.634503: csi_s_power: enable : 0x0
  nvargus-daemon-7262  [003] ....    98.202042: tegra_channel_open: vi-output, imx477 6-001a
  nvargus-daemon-7262  [003] ....    98.203173: camera_common_s_power: status : 0x1
  nvargus-daemon-7262  [000] ....    98.588968: camera_common_s_power: status : 0x0
  nvargus-daemon-7262  [000] ....    98.589033: tegra_channel_set_power: imx477 6-001a : 0x1
  nvargus-daemon-7262  [000] ....    98.589038: camera_common_s_power: status : 0x1
  nvargus-daemon-7262  [000] ....    98.889207: tegra_channel_set_power: nvcsi--1 : 0x1
  nvargus-daemon-7262  [000] ....    98.889211: csi_s_power: enable : 0x1
  nvargus-daemon-7262  [000] ....    98.889358: tegra_channel_close: vi-output, imx477 6-001a
  nvargus-daemon-7262  [000] ....    98.889362: tegra_channel_set_power: imx477 6-001a : 0x0
  nvargus-daemon-7262  [000] ....    98.889370: camera_common_s_power: status : 0x0
  nvargus-daemon-7262  [000] ....    98.889433: tegra_channel_set_power: nvcsi--1 : 0x0
  nvargus-daemon-7262  [000] ....    98.889435: csi_s_power: enable : 0x0
  nvargus-daemon-7262  [000] ....    98.891963: tegra_channel_open: vi-output, imx477 6-001a
  nvargus-daemon-7262  [000] ....    98.891972: tegra_channel_set_power: imx477 6-001a : 0x1
  nvargus-daemon-7262  [000] ....    98.891978: camera_common_s_power: status : 0x1
  nvargus-daemon-7262  [000] ....    99.192213: tegra_channel_set_power: nvcsi--1 : 0x1
  nvargus-daemon-7262  [000] ....    99.192217: csi_s_power: enable : 0x1
  nvargus-daemon-7262  [000] ....    99.192336: tegra_channel_close: vi-output, imx477 6-001a
  nvargus-daemon-7262  [000] ....    99.192340: tegra_channel_set_power: imx477 6-001a : 0x0
  nvargus-daemon-7262  [000] ....    99.192347: camera_common_s_power: status : 0x0
  nvargus-daemon-7262  [000] ....    99.192407: tegra_channel_set_power: nvcsi--1 : 0x0
  nvargus-daemon-7262  [000] ....    99.192408: csi_s_power: enable : 0x0
  nvargus-daemon-7262  [000] ....    99.217485: tegra_channel_open: vi-output, imx477 6-001a
  nvargus-daemon-7262  [000] ....    99.217496: tegra_channel_set_power: imx477 6-001a : 0x1
  nvargus-daemon-7262  [000] ....    99.217504: camera_common_s_power: status : 0x1
  nvargus-daemon-7262  [000] ....    99.517671: tegra_channel_set_power: nvcsi--1 : 0x1
  nvargus-daemon-7262  [000] ....    99.517675: csi_s_power: enable : 0x1
  nvargus-daemon-7262  [000] ....    99.517703: tegra_channel_close: vi-output, imx477 6-001a
  nvargus-daemon-7262  [000] ....    99.517707: tegra_channel_set_power: imx477 6-001a : 0x0
  nvargus-daemon-7262  [000] ....    99.517713: camera_common_s_power: status : 0x0
  nvargus-daemon-7262  [000] ....    99.517766: tegra_channel_set_power: nvcsi--1 : 0x0
  nvargus-daemon-7262  [000] ....    99.517767: csi_s_power: enable : 0x0
  nvargus-daemon-7262  [000] ....    99.517838: tegra_channel_open: vi-output, imx477 6-001a
  nvargus-daemon-7262  [000] ....    99.517843: tegra_channel_set_power: imx477 6-001a : 0x1
  nvargus-daemon-7262  [000] ....    99.517847: camera_common_s_power: status : 0x1
  nvargus-daemon-7262  [001] ....    99.818041: tegra_channel_set_power: nvcsi--1 : 0x1
  nvargus-daemon-7262  [001] ....    99.818046: csi_s_power: enable : 0x1
  nvargus-daemon-7262  [001] ....    99.818139: tegra_channel_close: vi-output, imx477 6-001a
  nvargus-daemon-7262  [001] ....    99.818143: tegra_channel_set_power: imx477 6-001a : 0x0
  nvargus-daemon-7262  [001] ....    99.818150: camera_common_s_power: status : 0x0
  nvargus-daemon-7262  [001] ....    99.818208: tegra_channel_set_power: nvcsi--1 : 0x0
  nvargus-daemon-7262  [001] ....    99.818209: csi_s_power: enable : 0x0
  nvargus-daemon-7262  [001] ....    99.818329: tegra_channel_open: vi-output, imx477 6-001a
  nvargus-daemon-7262  [001] ....    99.818336: tegra_channel_set_power: imx477 6-001a : 0x1
  nvargus-daemon-7262  [001] ....    99.818341: camera_common_s_power: status : 0x1
  nvargus-daemon-7262  [001] ....   100.118546: tegra_channel_set_power: nvcsi--1 : 0x1
  nvargus-daemon-7262  [001] ....   100.118551: csi_s_power: enable : 0x1
  nvargus-daemon-7262  [001] ....   100.118652: tegra_channel_close: vi-output, imx477 6-001a
  nvargus-daemon-7262  [001] ....   100.118656: tegra_channel_set_power: imx477 6-001a : 0x0
  nvargus-daemon-7262  [001] ....   100.118660: camera_common_s_power: status : 0x0
  nvargus-daemon-7262  [001] ....   100.118716: tegra_channel_set_power: nvcsi--1 : 0x0
  nvargus-daemon-7262  [001] ....   100.118718: csi_s_power: enable : 0x0
 CaptureSchedule-7283  [002] ....   100.464760: tegra_channel_open: vi-output, imx477 6-001a
 CaptureSchedule-7283  [002] ....   100.464771: tegra_channel_set_power: imx477 6-001a : 0x1
 CaptureSchedule-7283  [002] ....   100.464779: camera_common_s_power: status : 0x1
 CaptureSchedule-7283  [003] ....   100.765015: tegra_channel_set_power: nvcsi--1 : 0x1
 CaptureSchedule-7283  [003] ....   100.765019: csi_s_power: enable : 0x1
 CaptureSchedule-7283  [003] ....   100.768577: tegra_channel_set_stream: enable : 0x1
 CaptureSchedule-7283  [003] ....   100.768668: tegra_channel_set_stream: nvcsi--1 : 0x1
 CaptureSchedule-7283  [003] ....   100.768670: csi_s_stream: enable : 0x1
 CaptureSchedule-7283  [003] ....   100.768671: tegra_channel_set_stream: imx477 6-001a : 0x1
 CaptureSchedule-7283  [003] ....   105.406521: tegra_channel_set_stream: enable : 0x0
 CaptureSchedule-7283  [003] ....   105.406527: tegra_channel_set_stream: imx477 6-001a : 0x0
 CaptureSchedule-7283  [002] ....   105.406855: tegra_channel_set_stream: nvcsi--1 : 0x0
 CaptureSchedule-7283  [002] ....   105.406860: csi_s_stream: enable : 0x0
 CaptureSchedule-7283  [003] ....   105.407866: tegra_channel_close: vi-output, imx477 6-001a
 CaptureSchedule-7283  [003] ....   105.407873: tegra_channel_set_power: imx477 6-001a : 0x0
 CaptureSchedule-7283  [003] ....   105.407881: camera_common_s_power: status : 0x0
 CaptureSchedule-7283  [003] ....   105.407944: tegra_channel_set_power: nvcsi--1 : 0x0
 CaptureSchedule-7283  [003] ....   105.407946: csi_s_power: enable : 0x0
I haven’t tried it on another platform.
OOPS, it’s nano the trace log only for the TX2/Xavier.
For Nano could you enable debug print in the csi2_fops.c to check the status.
@ShaneCCC
This is dmesg for gst-launch, fps=1/2 with enable debug print of csi2_fops.c file:
[wto kwi 13 09:21:59 2021] vi 54080000.vi: Calibrate csi port 0
[wto kwi 13 09:22:01 2021] misc tegra_camera_ctrl: tegra_camera_update_isobw: Warning, Requested ISO BW 1640625 has been capped to VI's max BW 1500000
[wto kwi 13 09:22:01 2021] misc tegra_camera_ctrl: ISO BW req 1655985 > 1500000 (max) capping to max
[wto kwi 13 09:22:03 2021] fence timeout on [ffffffc08b050a80] after 1500ms
[wto kwi 13 09:22:03 2021] name=[nvhost_sync:33], current value=6 waiting value=7
[wto kwi 13 09:22:03 2021] ---- mlocks ----
[wto kwi 13 09:22:03 2021] ---- syncpts ----
[wto kwi 13 09:22:03 2021] id 8 (gm20b_507) min 11762 max 11762 refs 1 (previous client : )
[wto kwi 13 09:22:03 2021] id 9 (gm20b_506) min 14 max 14 refs 1 (previous client : )
[wto kwi 13 09:22:03 2021] id 11 (gm20b_505) min 10518 max 10518 refs 1 (previous client : gm20b_505)
[wto kwi 13 09:22:03 2021] id 12 (54340000.vic_0) min 486 max 486 refs 1 (previous client : vi)
[wto kwi 13 09:22:03 2021] id 17 (54680000.isp_0) min 10 max 12 refs 3 (previous client : 54680000.isp_0)
[wto kwi 13 09:22:03 2021] id 18 (54680000.isp_1) min 10 max 12 refs 3 (previous client : 54680000.isp_1)
[wto kwi 13 09:22:03 2021] id 19 (54680000.isp_2) min 50 max 54 refs 6 (previous client : 54680000.isp_2)
[wto kwi 13 09:22:03 2021] id 20 (54680000.isp_3) min 10 max 12 refs 3 (previous client : 54680000.isp_3)
[wto kwi 13 09:22:03 2021] id 21 (gm20b_504) min 1408 max 1408 refs 1 (previous client : gm20b_504)
[wto kwi 13 09:22:03 2021] id 22 (gm20b_503) min 122 max 122 refs 1 (previous client : gm20b_503)
[wto kwi 13 09:22:03 2021] id 23 (gm20b_502) min 4 max 4 refs 1 (previous client : gm20b_502)
[wto kwi 13 09:22:03 2021] id 24 (gm20b_501) min 4 max 4 refs 1 (previous client : gm20b_501)
[wto kwi 13 09:22:03 2021] id 25 (gm20b_500) min 12 max 12 refs 1 (previous client : gm20b_500)
[wto kwi 13 09:22:03 2021] id 28 (54080000.vi_0) min 6 max 6 refs 1 (previous client : 54080000.vi_0)
[wto kwi 13 09:22:03 2021] id 29 (54080000.vi_1) min 6 max 8 refs 3 (previous client : 54080000.vi_1)
[wto kwi 13 09:22:03 2021] id 30 (54080000.vi_2) min 21 max 24 refs 5 (previous client : 54080000.vi_2)
[wto kwi 13 09:22:03 2021] id 31 (54080000.vi_5) min 8 max 8 refs 1 (previous client : 54080000.vi_5)
[wto kwi 13 09:22:03 2021] id 33 (54080000.vi_4) min 6 max 8 refs 3 (previous client : 54080000.vi_4)
[wto kwi 13 09:22:03 2021] id 34 (54340000.vic_0) min 3 max 3 refs 1 (previous client : 54340000.vic_0)
[wto kwi 13 09:22:03 2021] id 36 (gm20b_496) min 24 max 24 refs 1 (previous client : gm20b_496)
[wto kwi 13 09:22:03 2021] id 37 (gm20b_495) min 28 max 28 refs 1 (previous client : gm20b_495)
[wto kwi 13 09:22:03 2021] id 38 (gm20b_497) min 24 max 24 refs 1 (previous client : gm20b_497)
[wto kwi 13 09:22:03 2021] id 39 (gm20b_499) min 24 max 24 refs 1 (previous client : gm20b_499)
[wto kwi 13 09:22:03 2021] id 40 (gm20b_494) min 24 max 24 refs 1 (previous client : gm20b_494)
[wto kwi 13 09:22:03 2021] id 41 (gm20b_498) min 22 max 22 refs 1 (previous client : 54080000.vi_4)
[wto kwi 13 09:22:03 2021] ---- channels ----
[wto kwi 13 09:22:03 2021] 0-54680000.isp (11):
[wto kwi 13 09:22:03 2021] active class 01, offset 0050, val 00000011
[wto kwi 13 09:22:03 2021] DMAPUT 00000630, DMAGET 00000630, DMACTL 00000000
[wto kwi 13 09:22:03 2021] CBREAD 00000011, CBSTAT 00010050
                           ffffffc0f347fc00: JOB, syncpt_id=17, syncpt_val=11, first_get=00000598, timeout=10000, num_slots=3, num_handles=1
[wto kwi 13 09:22:03 2021]     GATHER at ffda8000+45a0, 8 words
[wto kwi 13 09:22:03 2021] 20000001
[wto kwi 13 09:22:03 2021] 00000411
[wto kwi 13 09:22:03 2021] 00000512
[wto kwi 13 09:22:03 2021] 00000614
[wto kwi 13 09:22:03 2021] 200c0001
[wto kwi 13 09:22:03 2021] 00000005
[wto kwi 13 09:22:03 2021]     GATHER at ffda8000+45c0, 2 words
[wto kwi 13 09:22:03 2021] 00000013
[wto kwi 13 09:22:03 2021] 1-54080000.vi (9):
[wto kwi 13 09:22:03 2021] active class 01, offset 0050, val 0000001d
[wto kwi 13 09:22:03 2021] DMAPUT 00000390, DMAGET 00000390, DMACTL 00000000
[wto kwi 13 09:22:03 2021] CBREAD 0000001d, CBSTAT 00010050
                           ffffffc0f347f800: JOB, syncpt_id=29, syncpt_val=7, first_get=00000300, timeout=10000, num_slots=5, num_handles=1
[wto kwi 13 09:22:03 2021]     GATHER at ffcf8000+00f8, 3 words
[wto kwi 13 09:22:03 2021] 304e0005
[wto kwi 13 09:22:03 2021] 00000032
[wto kwi 13 09:22:03 2021]     GATHER at ffcf8000+0104, 6 words
[wto kwi 13 09:22:03 2021] 00001d1d
[wto kwi 13 09:22:03 2021] 00000521
[wto kwi 13 09:22:03 2021] 20410001
[wto kwi 13 09:22:03 2021] 00000001
[wto kwi 13 09:22:03 2021]     GATHER at ffcf8000+011c, 2 words
[wto kwi 13 09:22:03 2021] 0000001e
[wto kwi 13 09:22:03 2021] sync_hintmask_ext = 0xc0000000
[wto kwi 13 09:22:03 2021] sync_hintmask = 0x80000000
[wto kwi 13 09:22:03 2021] sync_intc0mask = 0x00000001
[wto kwi 13 09:22:03 2021] sync_intmask = 0x00000011
[wto kwi 13 09:22:03 2021] syncpt_thresh_int_mask(0) = 0x00000001
[wto kwi 13 09:22:03 2021] syncpt_thresh_int_mask(1) = 0x14000154
[wto kwi 13 09:22:03 2021] syncpt_thresh_int_mask(2) = 0x00000004
[wto kwi 13 09:22:03 2021] syncpt_thresh_int_mask(3) = 0x00000000
[wto kwi 13 09:22:03 2021] syncpt_thresh_int_mask(4) = 0x00000000
[wto kwi 13 09:22:03 2021] syncpt_thresh_int_mask(5) = 0x00000000
[wto kwi 13 09:22:03 2021] syncpt_thresh_int_mask(6) = 0x00000000
[wto kwi 13 09:22:03 2021] syncpt_thresh_int_mask(7) = 0x00000000
[wto kwi 13 09:22:03 2021] syncpt_thresh_int_mask(8) = 0x00000000
[wto kwi 13 09:22:03 2021] syncpt_thresh_int_mask(9) = 0x00000000
[wto kwi 13 09:22:03 2021] syncpt_thresh_int_mask(10) = 0x00000000
[wto kwi 13 09:22:03 2021] syncpt_thresh_int_mask(11) = 0x00000000
[wto kwi 13 09:22:03 2021] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[wto kwi 13 09:22:03 2021] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[wto kwi 13 09:22:03 2021] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[wto kwi 13 09:22:03 2021] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[wto kwi 13 09:22:03 2021] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[wto kwi 13 09:22:03 2021] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[wto kwi 13 09:22:03 2021] syncpt_int_thresh_thresh_0(0) = 1
[wto kwi 13 09:22:03 2021] syncpt_int_thresh_thresh_0(17) = 11
[wto kwi 13 09:22:03 2021] syncpt_int_thresh_thresh_0(18) = 11
[wto kwi 13 09:22:03 2021] syncpt_int_thresh_thresh_0(19) = 51
[wto kwi 13 09:22:03 2021] syncpt_int_thresh_thresh_0(20) = 11
[wto kwi 13 09:22:03 2021] syncpt_int_thresh_thresh_0(29) = 7
[wto kwi 13 09:22:03 2021] syncpt_int_thresh_thresh_0(30) = 22
[wto kwi 13 09:22:03 2021] syncpt_int_thresh_thresh_0(33) = 7
[wto kwi 13 09:22:03 2021] fence timeout on [ffffffc08b050600] after 1500ms
[wto kwi 13 09:22:03 2021] name=[nvhost_sync:17], current value=10 waiting value=11
[wto kwi 13 09:22:03 2021] id 17 (54680000.isp_0) min 10 max 13 refs 4 (previous client : 54680000.isp_0)
[wto kwi 13 09:22:03 2021] id 18 (54680000.isp_1) min 10 max 13 refs 4 (previous client : 54680000.isp_1)
[wto kwi 13 09:22:03 2021] id 19 (54680000.isp_2) min 50 max 57 refs 9 (previous client : 54680000.isp_2)
[wto kwi 13 09:22:03 2021] fence timeout on [ffffffc08b050300] after 1500ms
[wto kwi 13 09:22:03 2021] name=[nvhost_sync:18], current value=10 waiting value=11
[wto kwi 13 09:22:03 2021] id 20 (54680000.isp_3) min 10 max 13 refs 4 (previous client : 54680000.isp_3)
[wto kwi 13 09:22:03 2021] id 29 (54080000.vi_1) min 6 max 9 refs 4 (previous client : 54080000.vi_1)
[wto kwi 13 09:22:03 2021] id 30 (54080000.vi_2) min 21 max 26 refs 7 (previous client : 54080000.vi_2)
[wto kwi 13 09:22:03 2021] id 33 (54080000.vi_4) min 6 max 9 refs 4 (previous client : 54080000.vi_4)
[wto kwi 13 09:22:03 2021] 0-54680000.isp (17):
[wto kwi 13 09:22:03 2021] DMAPUT 00000688, DMAGET 00000630, DMACTL 00000000
[wto kwi 13 09:22:03 2021] 1-54080000.vi (13):
[wto kwi 13 09:22:03 2021] DMAPUT 000003d8, DMAGET 000003d8, DMACTL 00000000
[wto kwi 13 09:22:04 2021] fence timeout on [ffffffc08b050f00] after 1500ms
[wto kwi 13 09:22:04 2021] name=[nvhost_sync:33], current value=7 waiting value=8
[wto kwi 13 09:22:04 2021] ---- mlocks ----
[wto kwi 13 09:22:04 2021] ---- syncpts ----
[wto kwi 13 09:22:04 2021] id 8 (gm20b_507) min 11766 max 11766 refs 1 (previous client : )
[wto kwi 13 09:22:04 2021] id 9 (gm20b_506) min 14 max 14 refs 1 (previous client : )
[wto kwi 13 09:22:04 2021] id 11 (gm20b_505) min 10526 max 10526 refs 1 (previous client : gm20b_505)
[wto kwi 13 09:22:04 2021] id 12 (54340000.vic_0) min 486 max 486 refs 1 (previous client : vi)
[wto kwi 13 09:22:04 2021] id 17 (54680000.isp_0) min 11 max 13 refs 3 (previous client : 54680000.isp_0)
[wto kwi 13 09:22:04 2021] id 18 (54680000.isp_1) min 11 max 13 refs 3 (previous client : 54680000.isp_1)
[wto kwi 13 09:22:04 2021] fence timeout on [ffffffc08b050240] after 1500ms
[wto kwi 13 09:22:04 2021] id 19 (54680000.isp_2) min 53 max 57 refs 6 (previous client : 54680000.isp_2)
[wto kwi 13 09:22:04 2021] id 20 (54680000.isp_3) min 11 max 13 refs 3 (previous client : 54680000.isp_3)
[wto kwi 13 09:22:04 2021] name=[nvhost_sync:18], current value=11 waiting value=12
[wto kwi 13 09:22:04 2021] id 21 (gm20b_504) min 1408 max 1408 refs 1 (previous client : gm20b_504)
[wto kwi 13 09:22:04 2021] id 22 (gm20b_503) min 122 max 122 refs 1 (previous client : gm20b_503)
[wto kwi 13 09:22:04 2021] id 23 (gm20b_502) min 4 max 4 refs 1 (previous client : gm20b_502)
[wto kwi 13 09:22:04 2021] id 24 (gm20b_501) min 4 max 4 refs 1 (previous client : gm20b_501)
[wto kwi 13 09:22:04 2021] id 25 (gm20b_500) min 12 max 12 refs 1 (previous client : gm20b_500)
[wto kwi 13 09:22:04 2021] id 28 (54080000.vi_0) min 6 max 6 refs 1 (previous client : 54080000.vi_0)
[wto kwi 13 09:22:04 2021] id 29 (54080000.vi_1) min 7 max 9 refs 3 (previous client : 54080000.vi_1)
[wto kwi 13 09:22:04 2021] id 30 (54080000.vi_2) min 23 max 26 refs 5 (previous client : 54080000.vi_2)
[wto kwi 13 09:22:04 2021] id 31 (54080000.vi_5) min 8 max 8 refs 1 (previous client : 54080000.vi_5)
[wto kwi 13 09:22:04 2021] id 33 (54080000.vi_4) min 7 max 9 refs 3 (previous client : 54080000.vi_4)
[wto kwi 13 09:22:04 2021] id 34 (54340000.vic_0) min 3 max 3 refs 1 (previous client : 54340000.vic_0)
[wto kwi 13 09:22:04 2021] id 36 (gm20b_496) min 24 max 24 refs 1 (previous client : gm20b_496)
[wto kwi 13 09:22:04 2021] id 37 (gm20b_495) min 28 max 28 refs 1 (previous client : gm20b_495)
[wto kwi 13 09:22:04 2021] id 38 (gm20b_497) min 24 max 24 refs 1 (previous client : gm20b_497)
[wto kwi 13 09:22:04 2021] id 39 (gm20b_499) min 24 max 24 refs 1 (previous client : gm20b_499)
[wto kwi 13 09:22:04 2021] id 40 (gm20b_494) min 24 max 24 refs 1 (previous client : gm20b_494)
[wto kwi 13 09:22:04 2021] id 41 (gm20b_498) min 22 max 22 refs 1 (previous client : 54080000.vi_4)
[wto kwi 13 09:22:04 2021] ---- channels ----
[wto kwi 13 09:22:04 2021] 0-54680000.isp (11):
[wto kwi 13 09:22:04 2021] active class 01, offset 0050, val 00000011
[wto kwi 13 09:22:04 2021] DMAPUT 00000688, DMAGET 00000688, DMACTL 00000000
[wto kwi 13 09:22:04 2021] CBREAD 00000011, CBSTAT 00010050
                           ffffffc0adad7400: JOB, syncpt_id=17, syncpt_val=12, first_get=000005f0, timeout=10000, num_slots=3, num_handles=1
[wto kwi 13 09:22:04 2021]     GATHER at ffda8000+466c, 8 words
[wto kwi 13 09:22:04 2021] 20000001
[wto kwi 13 09:22:04 2021] 00000411
[wto kwi 13 09:22:04 2021] 00000512
[wto kwi 13 09:22:04 2021] 00000614
[wto kwi 13 09:22:04 2021] 200c0001
[wto kwi 13 09:22:04 2021] 00000005
[wto kwi 13 09:22:04 2021]     GATHER at ffda8000+468c, 2 words
[wto kwi 13 09:22:04 2021] 00000013
[wto kwi 13 09:22:04 2021] 1-54080000.vi (9):
[wto kwi 13 09:22:04 2021] active class 01, offset 0050, val 0000001d
[wto kwi 13 09:22:04 2021] DMAPUT 000003d8, DMAGET 000003d8, DMACTL 00000000
[wto kwi 13 09:22:04 2021] CBREAD 0000001d, CBSTAT 00010050
                           ffffffc0adad4000: JOB, syncpt_id=29, syncpt_val=8, first_get=00000348, timeout=10000, num_slots=5, num_handles=1
[wto kwi 13 09:22:04 2021]     GATHER at ffcf8000+0138, 3 words
[wto kwi 13 09:22:04 2021] 304e0005
[wto kwi 13 09:22:04 2021] 00000035
[wto kwi 13 09:22:04 2021]     GATHER at ffcf8000+0144, 10 words
[wto kwi 13 09:22:04 2021] 124b0003
[wto kwi 13 09:22:04 2021] 00000000
[wto kwi 13 09:22:04 2021] 00000047
[wto kwi 13 09:22:04 2021] 00001d1d
[wto kwi 13 09:22:04 2021] 00000521
[wto kwi 13 09:22:04 2021] 20410001
[wto kwi 13 09:22:04 2021] 00000001
[wto kwi 13 09:22:04 2021]     GATHER at ffcf8000+016c, 2 words
[wto kwi 13 09:22:04 2021] 0000001e
[wto kwi 13 09:22:04 2021] sync_hintmask_ext = 0xc0000000
[wto kwi 13 09:22:04 2021] sync_hintmask = 0x80000000
[wto kwi 13 09:22:04 2021] sync_intc0mask = 0x00000001
[wto kwi 13 09:22:04 2021] sync_intmask = 0x00000011
[wto kwi 13 09:22:04 2021] syncpt_thresh_int_mask(0) = 0x00000001
[wto kwi 13 09:22:04 2021] syncpt_thresh_int_mask(1) = 0x14000154
[wto kwi 13 09:22:04 2021] syncpt_thresh_int_mask(2) = 0x00000004
[wto kwi 13 09:22:04 2021] syncpt_thresh_int_mask(3) = 0x00000000
[wto kwi 13 09:22:04 2021] syncpt_thresh_int_mask(4) = 0x00000000
[wto kwi 13 09:22:04 2021] syncpt_thresh_int_mask(5) = 0x00000000
[wto kwi 13 09:22:04 2021] syncpt_thresh_int_mask(6) = 0x00000000
[wto kwi 13 09:22:04 2021] syncpt_thresh_int_mask(7) = 0x00000000
[wto kwi 13 09:22:04 2021] syncpt_thresh_int_mask(8) = 0x00000000
[wto kwi 13 09:22:04 2021] syncpt_thresh_int_mask(9) = 0x00000000
[wto kwi 13 09:22:04 2021] syncpt_thresh_int_mask(10) = 0x00000000
[wto kwi 13 09:22:04 2021] syncpt_thresh_int_mask(11) = 0x00000000
[wto kwi 13 09:22:04 2021] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[wto kwi 13 09:22:04 2021] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[wto kwi 13 09:22:04 2021] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[wto kwi 13 09:22:04 2021] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[wto kwi 13 09:22:04 2021] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[wto kwi 13 09:22:04 2021] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[wto kwi 13 09:22:04 2021] syncpt_int_thresh_thresh_0(0) = 1
[wto kwi 13 09:22:04 2021] syncpt_int_thresh_thresh_0(17) = 12
[wto kwi 13 09:22:04 2021] syncpt_int_thresh_thresh_0(18) = 12
[wto kwi 13 09:22:04 2021] syncpt_int_thresh_thresh_0(19) = 54
[wto kwi 13 09:22:04 2021] syncpt_int_thresh_thresh_0(20) = 12
[wto kwi 13 09:22:04 2021] syncpt_int_thresh_thresh_0(29) = 8
[wto kwi 13 09:22:04 2021] syncpt_int_thresh_thresh_0(30) = 24
[wto kwi 13 09:22:04 2021] syncpt_int_thresh_thresh_0(33) = 8
[wto kwi 13 09:22:04 2021] fence timeout on [ffffffc0f508b6c0] after 1500ms
[wto kwi 13 09:22:04 2021] name=[nvhost_sync:17], current value=11 waiting value=13
[wto kwi 13 09:22:05 2021] misc tegra_camera_ctrl: tegra_camera_update_isobw: Warning, Requested ISO BW 1500000 has been capped to VI's max BW 1500000
[wto kwi 13 09:22:14 2021] host1x 50000000.host1x: cdma_handle_timeout: timeout: 29 (54080000.vi_1) client 30, HW thresh 7, done 8
[wto kwi 13 09:22:14 2021] host1x 50000000.host1x: cdma_handle_timeout: timeout: 33 (54080000.vi_4) client 30, HW thresh 7, done 8
[wto kwi 13 09:22:14 2021] host1x 50000000.host1x: cdma_handle_timeout: timeout: 30 (54080000.vi_2) client 30, HW thresh 23, done 23
[wto kwi 13 09:22:14 2021] ---- mlocks ----
[wto kwi 13 09:22:14 2021] ---- syncpts ----
[wto kwi 13 09:22:14 2021] id 8 (gm20b_507) min 11798 max 11798 refs 1 (previous client : )
[wto kwi 13 09:22:14 2021] id 9 (gm20b_506) min 14 max 14 refs 1 (previous client : )
[wto kwi 13 09:22:14 2021] id 11 (gm20b_505) min 10592 max 10592 refs 1 (previous client : gm20b_505)
[wto kwi 13 09:22:14 2021] id 12 (54340000.vic_0) min 486 max 486 refs 1 (previous client : vi)
[wto kwi 13 09:22:14 2021] id 17 (54680000.isp_0) min 11 max 13 refs 2 (previous client : 54680000.isp_0)
[wto kwi 13 09:22:14 2021] id 18 (54680000.isp_1) min 11 max 13 refs 2 (previous client : 54680000.isp_1)
[wto kwi 13 09:22:14 2021] id 19 (54680000.isp_2) min 53 max 57 refs 5 (previous client : 54680000.isp_2)
[wto kwi 13 09:22:14 2021] id 20 (54680000.isp_3) min 11 max 13 refs 2 (previous client : 54680000.isp_3)
[wto kwi 13 09:22:14 2021] id 29 (54080000.vi_1) min 7 max 9 refs 2 (previous client : 54080000.vi_1)
[wto kwi 13 09:22:14 2021] id 30 (54080000.vi_2) min 23 max 26 refs 4 (previous client : 54080000.vi_2)
[wto kwi 13 09:22:14 2021] id 33 (54080000.vi_4) min 7 max 9 refs 2 (previous client : 54080000.vi_4)
[wto kwi 13 09:22:14 2021] ---- channels ----
[wto kwi 13 09:22:14 2021] 0-54680000.isp (10):
[wto kwi 13 09:22:14 2021] active class 01, offset 0050, val 00000011
[wto kwi 13 09:22:14 2021] DMAPUT 00000688, DMAGET 00000688, DMACTL 00000000
[wto kwi 13 09:22:14 2021] CBREAD 00000011, CBSTAT 00010050
[wto kwi 13 09:22:14 2021]     GATHER at ffda8000+466c, 8 words
[wto kwi 13 09:22:14 2021] 20000001
[wto kwi 13 09:22:14 2021] 00000411
[wto kwi 13 09:22:14 2021] 00000512
[wto kwi 13 09:22:14 2021] 00000614
[wto kwi 13 09:22:14 2021] 200c0001
[wto kwi 13 09:22:14 2021] 00000005
[wto kwi 13 09:22:14 2021]     GATHER at ffda8000+468c, 2 words
[wto kwi 13 09:22:14 2021] 00000013
[wto kwi 13 09:22:14 2021] 1-54080000.vi (7):
[wto kwi 13 09:22:14 2021] active class 01, offset 0050, val 0000001d
[wto kwi 13 09:22:14 2021] DMAPUT 000003d8, DMAGET 000003d8, DMACTL 00000000
[wto kwi 13 09:22:14 2021] CBREAD 0000001d, CBSTAT 00010050
[wto kwi 13 09:22:14 2021]     GATHER at ffcf8000+0138, 3 words
[wto kwi 13 09:22:14 2021] 304e0005
[wto kwi 13 09:22:14 2021] 00000035
[wto kwi 13 09:22:14 2021]     GATHER at ffcf8000+0144, 10 words
[wto kwi 13 09:22:14 2021] 124b0003
[wto kwi 13 09:22:14 2021] 00000000
[wto kwi 13 09:22:14 2021] 00000047
[wto kwi 13 09:22:14 2021] 00001d1d
[wto kwi 13 09:22:14 2021] 00000521
[wto kwi 13 09:22:14 2021] 20410001
[wto kwi 13 09:22:14 2021] 00000001
[wto kwi 13 09:22:14 2021]     GATHER at ffcf8000+016c, 2 words
[wto kwi 13 09:22:14 2021] 0000001e
[wto kwi 13 09:22:14 2021] sync_hintmask_ext = 0xc0000000
[wto kwi 13 09:22:14 2021] sync_hintmask = 0x80000000
[wto kwi 13 09:22:14 2021] sync_intc0mask = 0x00000001
[wto kwi 13 09:22:14 2021] sync_intmask = 0x00000011
[wto kwi 13 09:22:14 2021] syncpt_thresh_int_mask(0) = 0x00000001
[wto kwi 13 09:22:14 2021] syncpt_thresh_int_mask(1) = 0x14000154
[wto kwi 13 09:22:14 2021] syncpt_thresh_int_mask(2) = 0x00000004
[wto kwi 13 09:22:14 2021] syncpt_thresh_int_mask(3) = 0x00000000
[wto kwi 13 09:22:14 2021] syncpt_thresh_int_mask(4) = 0x00000000
[wto kwi 13 09:22:14 2021] syncpt_thresh_int_mask(5) = 0x00000000
[wto kwi 13 09:22:14 2021] syncpt_thresh_int_mask(6) = 0x00000000
[wto kwi 13 09:22:14 2021] syncpt_thresh_int_mask(7) = 0x00000000
[wto kwi 13 09:22:14 2021] syncpt_thresh_int_mask(8) = 0x00000000
[wto kwi 13 09:22:14 2021] syncpt_thresh_int_mask(9) = 0x00000000
[wto kwi 13 09:22:14 2021] syncpt_thresh_int_mask(10) = 0x00000000
[wto kwi 13 09:22:14 2021] syncpt_thresh_int_mask(11) = 0x00000000
[wto kwi 13 09:22:14 2021] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[wto kwi 13 09:22:14 2021] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[wto kwi 13 09:22:14 2021] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[wto kwi 13 09:22:14 2021] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[wto kwi 13 09:22:14 2021] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[wto kwi 13 09:22:14 2021] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[wto kwi 13 09:22:14 2021] syncpt_int_thresh_thresh_0(0) = 1
[wto kwi 13 09:22:14 2021] syncpt_int_thresh_thresh_0(17) = 12
[wto kwi 13 09:22:14 2021] syncpt_int_thresh_thresh_0(18) = 12
[wto kwi 13 09:22:14 2021] syncpt_int_thresh_thresh_0(19) = 54
[wto kwi 13 09:22:14 2021] syncpt_int_thresh_thresh_0(20) = 12
[wto kwi 13 09:22:14 2021] syncpt_int_thresh_thresh_0(29) = 8
[wto kwi 13 09:22:14 2021] syncpt_int_thresh_thresh_0(30) = 24
[wto kwi 13 09:22:14 2021] syncpt_int_thresh_thresh_0(33) = 8
[wto kwi 13 09:22:14 2021] vi 54080000.vi: Calibrate csi port 0
[wto kwi 13 09:22:14 2021] vi 54080000.vi:     SYNCPT_ID   29
[wto kwi 13 09:22:14 2021] vi 54080000.vi:     SYNCPT_VAL  8
[wto kwi 13 09:22:14 2021] vi 54080000.vi:     FIRST_GET   0x348
[wto kwi 13 09:22:14 2021] vi 54080000.vi:     TIMEOUT     10000
[wto kwi 13 09:22:14 2021] vi 54080000.vi:     NUM_SLOTS   5
[wto kwi 13 09:22:14 2021] vi 54080000.vi:     NUM_HANDLES 1
[wto kwi 13 09:22:14 2021] vi 54080000.vi:     SYNCPT_ID   30
[wto kwi 13 09:22:14 2021] vi 54080000.vi:     SYNCPT_VAL  24
[wto kwi 13 09:22:14 2021] vi 54080000.vi:     FIRST_GET   0x370
[wto kwi 13 09:22:14 2021] vi 54080000.vi:     NUM_SLOTS   4
[wto kwi 13 09:22:14 2021] vi 54080000.vi:     SYNCPT_VAL  9
[wto kwi 13 09:22:14 2021] vi 54080000.vi:     FIRST_GET   0x390
[wto kwi 13 09:22:14 2021] vi 54080000.vi:     SYNCPT_VAL  26
[wto kwi 13 09:22:14 2021] vi 54080000.vi:     FIRST_GET   0x3b8
[wto kwi 13 09:22:14 2021] host1x 50000000.host1x: cdma_handle_timeout: timeout: 17 (54680000.isp_0) client 25, HW thresh 11, done 12
[wto kwi 13 09:22:14 2021] host1x 50000000.host1x: cdma_handle_timeout: timeout: 18 (54680000.isp_1) client 25, HW thresh 11, done 12
[wto kwi 13 09:22:14 2021] host1x 50000000.host1x: cdma_handle_timeout: timeout: 20 (54680000.isp_3) client 25, HW thresh 11, done 12
[wto kwi 13 09:22:14 2021] host1x 50000000.host1x: cdma_handle_timeout: timeout: 19 (54680000.isp_2) client 25, HW thresh 53, done 53
                           channel 0 - 54680000.isp
                           ---- host general irq ----
                           ---- host syncpt irq mask ----
[wto kwi 13 09:22:14 2021] syncpt_thresh_int_mask(1) = 0x00000154
[wto kwi 13 09:22:14 2021] syncpt_thresh_int_mask(2) = 0x00000000
                           ---- host syncpt irq status ----
                           ---- host syncpt thresh ----
[wto kwi 13 09:22:14 2021] isp 54680000.isp:     SYNCPT_ID   17
[wto kwi 13 09:22:14 2021] isp 54680000.isp:     SYNCPT_VAL  12
[wto kwi 13 09:22:14 2021] isp 54680000.isp:     FIRST_GET   0x5f0
[wto kwi 13 09:22:14 2021] isp 54680000.isp:     TIMEOUT     10000
[wto kwi 13 09:22:14 2021] isp 54680000.isp:     NUM_SLOTS   3
[wto kwi 13 09:22:14 2021] isp 54680000.isp:     NUM_HANDLES 1
[wto kwi 13 09:22:14 2021] isp 54680000.isp:     SYNCPT_ID   19
[wto kwi 13 09:22:14 2021] isp 54680000.isp:     SYNCPT_VAL  54
[wto kwi 13 09:22:14 2021] isp 54680000.isp:     FIRST_GET   0x608
[wto kwi 13 09:22:14 2021] isp 54680000.isp:     NUM_SLOTS   5
[wto kwi 13 09:22:14 2021] isp 54680000.isp:     SYNCPT_VAL  55
[wto kwi 13 09:22:14 2021] isp 54680000.isp:     FIRST_GET   0x630
[wto kwi 13 09:22:14 2021] isp 54680000.isp:     NUM_HANDLES 3
[wto kwi 13 09:22:14 2021] isp 54680000.isp:     SYNCPT_VAL  13
[wto kwi 13 09:22:14 2021] isp 54680000.isp:     FIRST_GET   0x648
[wto kwi 13 09:22:14 2021] isp 54680000.isp:     SYNCPT_VAL  57
[wto kwi 13 09:22:14 2021] isp 54680000.isp:     FIRST_GET   0x660
I enabled debug with following command:
echo -n 'file csi2_fops.c +p' | sudo tee /sys/kernel/debug/dynamic_debug/control
You need to run the v4l2 command to print the debug message from csi2_fops.c
@ShaneCCC
[wto kwi 13 10:02:15 2021] vi 54080000.vi: Calibrate csi port 0
[wto kwi 13 10:02:16 2021] misc tegra_camera_ctrl: tegra_camera_update_isobw: Warning, Requested ISO BW 1640625 has been capped to VI's max BW 1500000
[wto kwi 13 10:02:16 2021] vi 54080000.vi: cil_settingtime was autocalculated
[wto kwi 13 10:02:16 2021] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[wto kwi 13 10:02:18 2021] video4linux video0: frame start syncpt timeout!0
[wto kwi 13 10:02:18 2021] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[wto kwi 13 10:02:18 2021] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[wto kwi 13 10:02:18 2021] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[wto kwi 13 10:02:18 2021] vi 54080000.vi: cil_settingtime was autocalculated
[wto kwi 13 10:02:18 2021] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[wto kwi 13 10:02:20 2021] video4linux video0: frame start syncpt timeout!0
[wto kwi 13 10:02:20 2021] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[wto kwi 13 10:02:20 2021] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[wto kwi 13 10:02:20 2021] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[wto kwi 13 10:02:20 2021] vi 54080000.vi: cil_settingtime was autocalculated
[wto kwi 13 10:02:20 2021] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[wto kwi 13 10:02:22 2021] video4linux video0: frame start syncpt timeout!0
[wto kwi 13 10:02:22 2021] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[wto kwi 13 10:02:22 2021] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[wto kwi 13 10:02:22 2021] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[wto kwi 13 10:02:22 2021] vi 54080000.vi: cil_settingtime was autocalculated
[wto kwi 13 10:02:22 2021] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[wto kwi 13 10:02:24 2021] video4linux video0: frame start syncpt timeout!0
[wto kwi 13 10:02:24 2021] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[wto kwi 13 10:02:24 2021] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[wto kwi 13 10:02:24 2021] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[wto kwi 13 10:02:24 2021] vi 54080000.vi: cil_settingtime was autocalculated
[wto kwi 13 10:02:24 2021] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[wto kwi 13 10:02:26 2021] video4linux video0: frame start syncpt timeout!0
[wto kwi 13 10:02:26 2021] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[wto kwi 13 10:02:26 2021] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[wto kwi 13 10:02:26 2021] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040040
[wto kwi 13 10:02:26 2021] vi 54080000.vi: cil_settingtime was autocalculated
[wto kwi 13 10:02:26 2021] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[wto kwi 13 10:02:28 2021] video4linux video0: frame start syncpt timeout!0
[wto kwi 13 10:02:28 2021] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[wto kwi 13 10:02:28 2021] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[wto kwi 13 10:02:28 2021] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040040
[wto kwi 13 10:02:28 2021] vi 54080000.vi: cil_settingtime was autocalculated
[wto kwi 13 10:02:28 2021] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[wto kwi 13 10:02:30 2021] video4linux video0: frame start syncpt timeout!0
[wto kwi 13 10:02:30 2021] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[wto kwi 13 10:02:30 2021] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[wto kwi 13 10:02:30 2021] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040040
[wto kwi 13 10:02:30 2021] vi 54080000.vi: cil_settingtime was autocalculated
[wto kwi 13 10:02:30 2021] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[wto kwi 13 10:02:32 2021] video4linux video0: frame start syncpt timeout!0
[wto kwi 13 10:02:32 2021] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[wto kwi 13 10:02:32 2021] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[wto kwi 13 10:02:32 2021] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040040
[wto kwi 13 10:02:32 2021] vi 54080000.vi: cil_settingtime was autocalculated
[wto kwi 13 10:02:32 2021] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[wto kwi 13 10:02:34 2021] video4linux video0: frame start syncpt timeout!0
[wto kwi 13 10:02:34 2021] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[wto kwi 13 10:02:34 2021] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[wto kwi 13 10:02:34 2021] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040040
[wto kwi 13 10:02:34 2021] vi 54080000.vi: cil_settingtime was autocalculated
[wto kwi 13 10:02:34 2021] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[wto kwi 13 10:02:36 2021] video4linux video0: frame start syncpt timeout!0
[wto kwi 13 10:02:36 2021] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[wto kwi 13 10:02:36 2021] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[wto kwi 13 10:02:36 2021] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040040
[wto kwi 13 10:02:36 2021] vi 54080000.vi: cil_settingtime was autocalculated
[wto kwi 13 10:02:36 2021] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[wto kwi 13 10:02:38 2021] video4linux video0: frame start syncpt timeout!0
[wto kwi 13 10:02:38 2021] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[wto kwi 13 10:02:38 2021] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[wto kwi 13 10:02:38 2021] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040040
[wto kwi 13 10:02:38 2021] vi 54080000.vi: cil_settingtime was autocalculated
[wto kwi 13 10:02:38 2021] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[wto kwi 13 10:02:40 2021] video4linux video0: frame start syncpt timeout!0
[wto kwi 13 10:02:40 2021] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[wto kwi 13 10:02:40 2021] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[wto kwi 13 10:02:40 2021] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040040
[wto kwi 13 10:02:40 2021] vi 54080000.vi: cil_settingtime was autocalculated
[wto kwi 13 10:02:40 2021] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[wto kwi 13 10:02:42 2021] video4linux video0: frame start syncpt timeout!0
[wto kwi 13 10:02:42 2021] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[wto kwi 13 10:02:42 2021] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[wto kwi 13 10:02:42 2021] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040040
[wto kwi 13 10:02:42 2021] vi 54080000.vi: cil_settingtime was autocalculated
[wto kwi 13 10:02:42 2021] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[wto kwi 13 10:02:44 2021] video4linux video0: frame start syncpt timeout!0
[wto kwi 13 10:02:44 2021] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[wto kwi 13 10:02:44 2021] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[wto kwi 13 10:02:44 2021] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040040
[wto kwi 13 10:02:44 2021] vi 54080000.vi: cil_settingtime was autocalculated
[wto kwi 13 10:02:44 2021] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[wto kwi 13 10:02:46 2021] video4linux video0: frame start syncpt timeout!0
[wto kwi 13 10:02:46 2021] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[wto kwi 13 10:02:46 2021] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[wto kwi 13 10:02:46 2021] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040040
[wto kwi 13 10:02:46 2021] vi 54080000.vi: cil_settingtime was autocalculated
[wto kwi 13 10:02:46 2021] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[wto kwi 13 10:02:48 2021] video4linux video0: frame start syncpt timeout!0
[wto kwi 13 10:02:48 2021] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[wto kwi 13 10:02:48 2021] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[wto kwi 13 10:02:48 2021] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040040
[wto kwi 13 10:02:48 2021] vi 54080000.vi: cil_settingtime was autocalculated
[wto kwi 13 10:02:48 2021] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[wto kwi 13 10:02:50 2021] video4linux video0: frame start syncpt timeout!0
[wto kwi 13 10:02:50 2021] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[wto kwi 13 10:02:50 2021] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[wto kwi 13 10:02:50 2021] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040040
[wto kwi 13 10:02:50 2021] vi 54080000.vi: cil_settingtime was autocalculated
[wto kwi 13 10:02:50 2021] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
This error tell the MIPI timing have problem to capture the frame from MIPI bus. Have a check the TRM for the error. Also could you confirm with vendor if this configure working on vendor’s system.
“CILA_DATA_LANE0_CTRL_ERR: Control Error. Set when CIL-A detects LP state 01 or 10 followed by a
stop state (LP11) instead of transitioning”
@ShaneCCC
So why I can capture frame using gstreamer and fps>=1 ?
I think you change the configure the MIPI timing are change too.
