@ShaneCCC You suggested that ARGUS doesn’t support FPS < 1. I’ve tested it and It seems that it is supported. As I mentioned before there is an error like this:
fence timeout on [ffffffc08b98a780] after 1500ms
so I set FPS to don’t exceed that timeout i.e. 2/3 - one frame should be handled in 1,5s for this setting - and I was able to get frame successfully. The problem occurs when FPS value make time of getting frame longer than 1,5s.
I found the log about timeout in kernel source file: kernel/kernel-4.9/drivers/staging/android/sync.c
in function int sync_fence_wait(struct sync_fence *fence, long timeout) but I cannot find where it is called with 1500ms timeout value. It is possible that the libargus calls it ? As far as I know the ARGUS sources are not public ?
@ShaneCCC I’m getting following output for gst-launch (for now fps is 1):
gst-launch-1.0 -e nvarguscamerasrc num-buffers=1 exposuretimerange="500000000 500000000" ! "video/x-raw(memory:NVMM),width=4032,height=3040,framerate=1/1" ! nvjpegenc quality=100 ! multifilesink location=./test.jpg
GST_ARGUS: NvArgusCameraSrc: Setting Exposure Time Range : 500000000 500000000
GST_ARGUS: !!! EXP RANGE: 500000000,000000, 500000000,000000
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Error generated. gstnvarguscamerasrc.cpp, execute:656 Failed to create CaptureSession
Caught SIGSEGV
Got EOS from element "pipeline0".
Execution ended after 0:00:02.086712276
Setting pipeline to READY ...
#0 0x0000007f864f2310 in __GI___pthread_timedjoin_ex (threadid=547585204720, thread_return=0x0, abstime=0x0, block=<optimized out>)
#1 0x0000007f865ae968 in () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0
#2 0x0000007f85b94000 in ()
Spinning. Please run 'gdb gst-launch-1.0 13732' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
And nvargus-daemon log:
=== NVIDIA Libargus Camera Service (0.97.3)=== Listening for connections...=== gst-launch-1.0[13540]: Connection established (7F8D0811D0)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: No override file found. ----
=== gst-launch-1.0[13540]: CameraProvider initialized (0x7f8892d9c0)SCF: Error BadParameter: (propagating from src/services/capture/NvViCsiHw.cpp, function openViCsi(), line 118)
SCF: Error BadParameter: (propagating from src/services/capture/CaptureServiceDeviceViCsi.cpp, function open(), line 307)
SCF: Error BadParameter: (propagating from src/services/capture/CaptureServiceDevice.cpp, function openSource(), line 355)
SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function openSource(), line 478)
SCF: Error BadParameter: (propagating from src/api/Session.cpp, function initialize(), line 263)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function createSession(), line 577)
(Argus) Error BadParameter: (propagating from src/api/CaptureSessionImpl.cpp, function initialize(), line 120)
(Argus) Error BadParameter: (propagating from src/api/CameraProviderImpl.cpp, function createCaptureSession(), line 258)
(NvCameraUtils) Error InvalidState: Mutex not initialized (/dvs/git/dirty/git-master_linux/camera/argus/src/api/CaptureSessionImpl.cpp:197) (in Mutex.cpp, function lock(), line 79)
(Argus) Error InvalidState: Element not found (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamerautils/inc/Vector.h, function remove(), line 172)
(NvCameraUtils) Error InvalidState: Mutex has not been initialized (in Mutex.cpp, function unlock(), line 88)
Only exposuretimerange=“500000000 500000000” failed?
I think when sensor configure as this value that cause the output timing to capture data from sensor.
Could you try set this exposuretimerange but modify sensor driver to set a normal value to cheat argus to confirm it.
there is the nano still I posted but I was reading that the way long exposure is done even on the pi is that the software is stacking shorter exposures not doing one long shot.
Raspistill actually has to take multiple images - to get exposure etc. Set. If you use a little python loop with capture continuous you can reduce the gap between images to <1 second. Also note you can use up to 10 secs exposure time.
I implemented long exposure in kernel driver basing on IMX477 driver for raspberry pi. The problem lays somewhere in nvidia software calling the driver API, I guess.
Would you be able to share your modifications to achieve 1.5 second exposures? On the stock Nvidia and Arducam drivers (currently unreleased but with full 4032x3040 support) I’m unable to get anything longer than ~0.35 seconds to work. The 0.4 second exposure time, which I saw on older 28.x Nvidia release notes was the longest exposure time supported, results in an invalid exposure value error.
Is there anything we can do to officially request support from Nvidia? The IMX477 sensor’s max exposure time is 120 seconds, and having support for long exposure (and generally more still photo capture support) would be immensely appreciated / needed by folks who are using Jetson as a photography (ie. not videography) platform.
Further along that previous point, the Raspberry Pi folks have designed their API to support both video and still workflows, each containing unique settings for their ISP (ie. still photos have less aggressive noise reduction, and possibly higher quality debayer tuning as it’s less time sensitive compared to video capture where timing is extremely tight). It would be great (and arguably needed by many) to see those kind of still photo features in the Jetson platform.
I modified the MAX_EXPOSURE_TIME in gstnvarguscamerasrc.cpp and that does allow me to increase the exposure a little bit more. From my previous limit of ~0.35 seconds I can now get to ~0.5 seconds, but pushing beyond that seems to actually go in the wrong direction (ie. 0.6 second exposure is darker than ~0.5 seconds). Would you be able to share your kernel modifications that allowed you to get to 1.5 seconds? But as you mentioned, 1.5 seconds is still very low, and we should be able to get to the actual sensor limit of 120 seconds in theory.
